Old 7th May 2011, 20:26   #241
archat68's Avatar
Thanked: 290 Times
Default re: OBD (On-board diagnostics) for Indian Cars
Originally Posted by mtnrajdeep View Post
I tried with Swift D and Ritz D using an ELM327 bluetooth adapter and an android device and the torque app. It worked on the Ritz D but not on the Swift D. I also tried on A-Star and SX4 ZXi without success.
That's sad !! Don't know why a mfr like Maruti doesn't follow a standard protocol for OBDII!!
archat68 is offline   Reply With Quote
Old 9th May 2011, 22:33   #242
Kannan's Avatar
I am happy to hear that ELM 327 works with Ritz Diesel. I have been searching for a compatible OBD for Ritz Diesel for a very long time.
Since you have confirmed, I am planning to buy one. Can you give me the make, model and approximated price.
Kannan is offline   Reply With Quote
Old 10th May 2011, 10:10   #243
mtnrajdeep's Avatar
Thanked: 101 Times
Originally Posted by Kannan View Post
I am happy to hear that ELM 327 works with Ritz Diesel. I have been searching for a compatible OBD for Ritz Diesel for a very long time. Since you have confirmed, I am planning to buy one. Can you give me the make, model and approximated price.
I bought this from dealextreme. The link is: $26.03 - OBDII Bluetooth Car Diagnostic Cable - Black + Blue + Orange (DC 12V) - OBD/OBD2 Car Diag. Tools
I checked this on a Ritz VDi.
mtnrajdeep is online now   Reply With Quote
Old 10th May 2011, 19:58   #244
Kannan's Avatar
Hey thanks for the link. Just now placed the order
How long did it take to receive the shipment?
Thanks for the link again
Old 10th May 2011, 22:33   #245
mtnrajdeep's Avatar
Thanked: 101 Times
Took about two month since I ordered during Chinese New Year. You should get it within 3-4 weeks normally.
Old 26th May 2011, 10:27   #246
mayankk's Avatar
Thanked: 3,559 Times
I just hope someone can help me make sense of this.
all here seem to be well versed with OBD2.
I got the following readings from my car :
Car1 Polling Setup
|0
0101|MIL Status|20|1|0
0102|unused|0|1|0
0103|Fuel Sys Status|20|1|0
0104|Calculated Engine Load|1|1|0
0105|Coolant Temp|4|1|0
0106|Short term fuel trim 1|2|1|0
0107|Long term fuel trim 1|2|1|0
0108|Short term fuel trim 2|2|1|0
0109|Long term fuel trim 2|2|1|0
010A|Fuel Pressure|18|1|0
010B|Manifold Air Pressure|11|1|0
010C|Engine RPM|5|1|0
010D|Vehicle Speed|7|1|0
010E|Ignition Advance|14|1|0
010F|Intake Air Temp|4|1|0
0110|Air Flow|17|1|0
0111|Throttle Position|1|1|0
0112|Secondary Air Status|20|1|0
0113|O2 Sensor location|20|1|0
0114|O2 Sensor 1-1 Voltage|15|1|0
0115|O2 Sensor 1-2 Voltage|15|1|0
0116|O2 Sensor 1-3 Voltage|15|1|0
0117|O2 Sensor 1-4 Voltage|15|1|0
0118|O2 Sensor 1-5 Voltage|15|1|0
0119|O2 Sensor 1-6 Voltage|15|1|0
011A|O2 Sensor 1-7 Voltage|15|1|0
011B|O2 Sensor 1-8 Voltage|15|1|0
011C|OBD type|20|1|0
011D|unknown|0|1|0
011E|unknown|0|1|0
011F|unknown|0|1|0
EOP - end of Parms
5/26/2011 7:33:53 AM
105
##1
1,466976
6,466976
11,466976
15,466976
20,466976
24,466976
##3
1,512
6,512
11,512
15,1024
20,512
25,512
this is from a freeware OBD s/w.
and i can understand zilch from this...
help?
mayankk is online now   Reply With Quote
Old 26th May 2011, 20:22   #247
anku94's Avatar
Thanked: 33 Times
help?
Well, I haven't ever tried OBD, but it seems that the software is just giving you raw data from the OBD port. Why don't you try using a different software ?
anku94 is offline   (1) Thanks Reply With Quote
Old 26th May 2011, 20:25   #248
mayankk's Avatar
tried a GUI based thing just now.
but apparently, there arent that many sensors in the indian fiesta.
plus, the "yippe" bit -> no error codes!
Old 26th May 2011, 21:59   #249
dhanushs's Avatar
Thanked: 4,473 Times
I assume you have a diesel Fiesta?.
Well, On OBD Scope, my IKON gives out 20 gauges where Figo gives out only 15. I can relate it directly to the sensors.
In the PC, OBD spy and Scan Master is a cool software, give out average FE and even 0-100 timings.
btw, are you using Bluetooth OBD or via cable?
Old 26th May 2011, 22:18   #250
Thanked: 84 Times
Anyone found a reliable OBD Software which can accurately report Fuel Economy for Diesel Vehices?
Most of the SW works good for petrol vehicles but results are not reliable on diesel engines.
I've tried many including the paid version of DashCommand but the readings are a bit vague and inaccurate. The one which reported a reasonably accurate result was hOBD but its feature set and interface is primitive.
Digital Vampire is offline   Reply With Quote
Old 26th May 2011, 22:53   #251
mayankk's Avatar
aww.....
no i dont.
i meant that according to this OBD software, the indian fiesta doesnt have that many sensors.
The earlier one i used, "wOBD" gave a whole dump of text readings, about 15-20.
but was hard to make sense of.
tomorrow im gonna try freeDiag.
lets see.
although i have NO idea why i am trying all of them when already i have checked that there are no error codes...
just for fun's sake, i s'pose.
and i am using a wired ELM327 unit.
Old 26th May 2011, 23:13   #252
dhanushs's Avatar
... although i have NO idea why i am trying all of them when already i have checked that there are no error codes...
Well, the OBD reader is not always used to check error codes. I find it very much geeky or whatever and was literally glued to the monitor for about a week. The fuel efficiency, throttle position, 0-100 timings et al, make me go ga..ga ...
Try the OBD spy and Scan Master. They are good. Also, could you please do me a favor?. Could you please send me the drivers that have been installed?. I assume you are using a windows PC. Is it XP or 7?
Old 27th May 2011, 00:09   #253
akshay4587's Avatar
Thanked: 1,684 Times
Guys,i need some help here.
If i were to pick up a OBD scanner for an Accent,which one would it be?
And I would need one,that can be easily connected to a Laptop or may be an Iphone even.
Old 27th May 2011, 10:23   #254
mayankk's Avatar
wilco.
although the cd did have drivers, the detection and driver installation happened aape-aap, seemed like PnP, but the CD WAS in the drive, so windows might have picked the drivers from there itself.
It is on windows 7.
will send across the drivers.
PM me your email id.
whats the unit youre using?
@akshay4587: just one thing to keep in mind, whatever you get, try and spend a lil more and get a wireless/BT one.
The wire is a serious restraint.
Old 27th May 2011, 14:02   #255
dhanushs's Avatar
I'm not sure what ECU Accent sports. Is it a petrol or the CRDi?. In any case, if you manage to find out the ECU model, then most ebay sellers have a list of ECU's supported. Just check if yours is listed.
The wireless and bluetooth readers are the best for using in Android devices and iphones. When it comes to PC, wired are easier to configure. I have bought a ELM 327 device 3 months back, and till now Ive not managed to make it work in PC.
Diagnostics, Spares, Service & Upgrades for European Cars - Euro Car Pitstop (Cochin) Games Goblin Other Cities 4 14th May 2018 10:06
On Board Diagnostics (OBD) for Dummies a4anurag Technical Stuff 39 20th January 2017 20:39
TechSpec® : Understanding On-Board Diagnostics, also known as ECU, ECM, EMS dadu Technical Stuff 62 14th March 2014 15:30
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
req help with indigo sx (diesel) on board diagnostics shldn Technical Stuff 4 26th March 2006 20:11
