Old 27th July 2011, 14:26   #301
mayankk's Avatar
Thanked: 3,559 Times
Default re: OBD (On-board diagnostics) for Indian Cars
Originally Posted by Kimified View Post
Hi Archat,
I got my Bluetooth scanner today. But I don't seem to get it to work :(
I put it in the obd port. There are 5 lights on the device. The first one goes red as soon as I connect it.
Then I opened the torque application on my Android device. Searched for the scanner, got something as CHX. Did a connect and pair by using 6789 as the key. The pairing worked. But I can't seem to connect to it. It just shows 'paired but not connected in my device list'.
When I open torque application, it shows that the scanner is not connected. Any idea on what the problem might be ? Or am I missing something here ?
have you selected elm device in torques "more" menu?
i think the phone will not connect because it doesnt know what the device is(headfone/keyb etc).
but when you boot up the app, then it would(after youve selected elm).
mayankk is online now   (1) Thanks Reply With Quote
Old 27th July 2011, 15:23   #302
archat68's Avatar
Thanked: 290 Times
+1
Also try on your laptop with Scantool or similar software.
archat68 is offline   (1) Thanks Reply With Quote
Old 27th July 2011, 16:59   #303
Thanked: 381 Times
Hi Archat,
Could you post the link form where you got it and the final cost?
keyur is offline   Reply With Quote
Old 27th July 2011, 17:13   #304
archat68's Avatar
Thanked: 290 Times
Originally Posted by keyur View Post
See post no. 292 for details.
archat68 is offline   Reply With Quote
Old 27th July 2011, 17:24   #305
A350XWB's Avatar
Thanked: 620 Times
Default Obd
Originally Posted by SPIKE ARRESTOR View Post
OBD is the link between ECU and Engine
Spike, can you elaborate on the above sentence?
A350XWB is offline   Reply With Quote
Old 27th July 2011, 17:24   #306
Thanked: 381 Times
thats why got the wired elm327.
Hey Mayank, can you post a link for the wired 327?
Originally Posted by archat68 View Post
The ELM327 that I purchased off ebay stopped working in just two days. It doesn't connect to any BT device anymore :( .
Your device stopped working and I thought that Kimi had purchased it from a different place, so asked him (yours was 21$, his was Rs.780)
Old 27th July 2011, 17:32   #307
Kimified's Avatar
Thanked: 80 Times
+1
Thanks a lot. I had not selected the 'Paired device to connect to in the settings'.
Works like a charm now
Post 292 like archat68 said has the details and the link. It took 18 days to ship. Normal Airmail and not registered. Registered airmail costs 3 dollars more and that's why the difference in cost. I ordered from the same link which Archat gave me.
Kimified is offline   Reply With Quote
Old 27th July 2011, 17:33   #308
mayankk's Avatar
Here you go.
ELM327 USB Vehicle OBD-2 Scanner Tool - Free Shipping - DealExtreme
be warned though.
this is not for you to use while driving.
one, the cables are quite hefty, and combined length is about 10feet.
it WILL get in the way.
and you may brake a bit oafishly, and the lappy will slide across the front seat, and go and hit the hard footwell from where you have removed the mats for a wash right before you connected the unit and took the car for a drive to test the OBD readings....
mayankk is online now   Reply With Quote
Old 27th July 2011, 23:44   #309
Thanked: 381 Times
Hope the lappy is OK now - recovering from the shock
Old 28th July 2011, 00:10   #310
Kimified's Avatar
Thanked: 80 Times
Just connected the OBD scanner today and went for a drive. The readings seem pretty accurate. Throttle position and the percentage shown were almost spot on. The Rev counter too was spot on with the dash reading.
However, The speedo always had a 10% error. I think the readings we get from the OBD is the accurate one and the Speedo on the dash is calibarated to show a 10% error. (Just like the difference in GPS speed and the dashboard speed)
I was not able to configure the KPL. Has anyone tried that here. Is there any specific thing i need to configure to get accurate readings. It was showing kpl in the range of 2 to 4 (I have configured the engine capacity and the Kerb weight in the settings).
I don't know what the Boost psi reading is for ? Can anyone explain
The HP reading is missing in the free version. I'll buy the full version in sometime.
Old 28th July 2011, 00:38   #311
greenhorn's Avatar
Thanked: 1,509 Times
Dont tell me that you have a turbodiesel and you dont know what boost is!
Boost is the secret of your energy, in fact, OUR energy
Jokes aside Turbocharger - Wikipedia, the free encyclopedia
Old 28th July 2011, 01:16   #312
Thanked: 381 Times
Good one! Very apt here! OUR energy!
Old 28th July 2011, 01:50   #313
dhanushs's Avatar
Thanked: 4,473 Times
Torque has two speed readings. One from vehicle ECU, and one from GPS. The vehicle ECU reading will match the speedo reading, and the GPS one will have a certain % error (mostly it reads less).
There is also an option to calibrate both the speeds, to reduce error.
Old 28th July 2011, 03:19   #314
kailashnj's Avatar
Thanked: 279 Times
My elm device (bluetooth) does not connect. I am able to connect to the device but the device is not able to talk to the ecu.
Please help
kailashnj is offline   Reply With Quote
Old 28th July 2011, 07:28   #315
govigov's Avatar
Thanked: 522 Times
Please help
from where did you purchase this?
ebay? if so which seller?
govigov is offline   Reply With Quote
Diagnostics, Spares, Service & Upgrades for European Cars - Euro Car Pitstop (Cochin) Games Goblin Other Cities 4 14th May 2018 10:06
On Board Diagnostics (OBD) for Dummies a4anurag Technical Stuff 39 20th January 2017 20:39
TechSpec® : Understanding On-Board Diagnostics, also known as ECU, ECM, EMS dadu Technical Stuff 62 14th March 2014 15:30
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
req help with indigo sx (diesel) on board diagnostics shldn Technical Stuff 4 26th March 2006 20:11
