Old 22nd February 2012, 18:21   #406
Thanked: 58 Times
Default re: OBD (On-board diagnostics) for Indian Cars
Does the Getz 1.3 have an OBD port ?, If yes could you let me know where it is and what connectors to get...
trumpet is offline   Reply With Quote
Old 22nd February 2012, 18:31   #407
sushrutha's Avatar
Thanked: 324 Times
Originally Posted by dinu2506 View Post
As promised, here are some pictures of the V Checker installed in my Civic.
Dinu,
That looks cool. Does it Display KMPL ? coz I can see only LHK, LPH etc.
Can the speed(kmph) be caliberated/adjusted ?
And how accurate the device is ?
Old 22nd February 2012, 20:00   #408
dinu2506's Avatar
Thanked: 328 Times
Originally Posted by sushrutha View Post
Dinu,
It displays Litres per 100km and Litres per hour on idle. Actually, its only a mindblock, you get used to Litres per 100km quite fast and you will no longer be bothered about kmpl. Speed cannot be calibrated but the algorithm for Fuel consumption can be calibrated after checking the actual fuel consumption using tank to tank method. The correction factor can be entered to take care of the difference. This is a one time job and going forward it displays the correct consumption. I have done this and now it displays quite an accurate figure.
Lot of other data is available like battery voltage, intake air temp, coolant temp, throttle position, Ox sensor data and many more.
Its also got the feature to display error codes and also erase them, though I have not used them since I did not have any error codes displayed.
The display can be adjusted to display 6 out of the available information. There is a display mode for idle and a display mode for running (where you see the speedometer).
Other utilities include maintenance reminders, alarms for overheating (which can be tailored), alarm for overspeeding and utilities for measuring 0-100 acceleration times, time taken for a particular distance (eg 0-400meters) etc.
I feel its a VFM at around $100.
You can see the details at their site
A301 ? - ?????
dinu2506 is offline   (1) Thanks Reply With Quote
Old 23rd February 2012, 10:14   #409
sushrutha's Avatar
Thanked: 324 Times
A301 ? - ?????
So almost the same features as that of Scangauge II, but with added Performance monitors.
I feel it's worth when compared with SG II, coz of the graphical display + the price (sg II is almost $160).
Old 23rd February 2012, 11:19   #410
dynomite's Avatar
Thanked: 78 Times
Yeah - somehow I never liked the ScanGauge because the display is so simple.
Dinu - thanks for the photos
Though I guess mounting it on that sliding cover also means you give up the space inside it right?
I see you have a JVC 2 DIN system with the steering remote control - looks neat. But what is that other smaller control pod/switch, in the space under the headlamp adjuster dial?
dynomite is offline   Reply With Quote
Old 23rd February 2012, 11:59   #411
dinu2506's Avatar
Thanked: 328 Times
The sliding cover still moves and is functional, only thing it does not open fully. But the opening is big enough to fully use the storage space. No issue there.
The other control pod is the dial for adjusting the bass boost of the subwoofer monobloc amplifier.
dinu2506 is offline   Reply With Quote
Old 24th February 2012, 10:28   #412
dynomite's Avatar
Thanked: 78 Times
Before you order, make sure about the Metrics.
Seems like it displays only MPH & MPG(as per the pic n site).
What you really require is KMPH & KMPL.
I checked - and for anyone else interested, the Edge Insight CTS OBD II tool can display Metric units.
I got a hold of the user manual from here. (its about 2.8MB)
Page 34 clearly mentions that you can switch units to Metric.
The manual also outlines all the features, what's included in the box, firmware upgrades and so on.
Old 24th February 2012, 10:35   #413
sushrutha's Avatar
Thanked: 324 Times
Oh good then.
Frankly $400 is way too much for that device.
I wouldn't buy one for sure.
V-checker A301 looks more VFM (almost 1/4th of the price ) when compared with the Edge-Insight.
Old 24th February 2012, 10:52   #414
dynomite's Avatar
Thanked: 78 Times
Oh good then.
But then again, if one already has an iPod Touch, iPhone or iPad, you could still get a colour display, customisable gauges etc - by getting a Kiwi WiFi for $150.
I think the V-checker is VFM too - but the colour display is too good to pass up. I'm leaning towards the Kiwi Wifi tool.
Btw - did you get my PM?
Old 24th February 2012, 11:06   #415
sushrutha's Avatar
Thanked: 324 Times
Rather buy the below mentioned @ $16. Same as that of KIWI, but at 1/10th of the cost.
Elm327 bluetooth,Elm327 interface,bluetooth obd2
ELM327 Bluetooth OBD-II Wireless Transceiver Dongle¨C DealExtreme Reviews
Old 24th February 2012, 11:15   #416
dynomite's Avatar
Thanked: 78 Times
Pardon my ignorance, but isn't this tool specifically meant to be used with Windows PCs and or older mobile devices (pocket pcs) after the installation of some software?
Will this work with the apps like Rev, Fuzzycar or Dashcommand on iOS devices?
Old 24th February 2012, 11:23   #417
sushrutha's Avatar
Thanked: 324 Times
As per their website, it's compatible with
"Elm327 bluetooth for Andorid Mobile phone,Windows xp,Windows vista,Windows 7."
I don't have much idea about the apps you are talking about.
Old 24th February 2012, 11:49   #418
SuperBee's Avatar
Thanked: 61 Times
Is OBD-2 supported on a 2003 NHC? I have one of those wired ELM327 connector which can hook up to your laptop via USB, ordered from TomTop.
Also, has anybody beem succesful in making OBD-2 work with the old Swift, the 1.3L G13BB engine.
Thanks.
SuperBee is offline   Reply With Quote
Old 24th February 2012, 12:38   #419
archat68's Avatar
Thanked: 238 Times
Originally Posted by SuperBee View Post
I
Thanks.
Doesn't work with older Swift. Works with newer ones with K series engines.
archat68 is offline   Reply With Quote
Old 24th February 2012, 14:56   #420
govigov's Avatar
Thanked: 452 Times
Thanks.
The old swift is not compatible, however on a ritz diesel and the new swift, it is claimed to have worked.
govigov is online now   Reply With Quote
On Board Diagnostics (OBD) for Dummies a4anurag Technical Stuff 39 20th January 2017 20:39
Diagnostics, Spares, Service & Upgrades for European Cars - Euro Car Pitstop (Cochin) Games Goblin Other Cities 3 1st February 2016 13:36
TechSpec® : Understanding On-Board Diagnostics, also known as ECU, ECM, EMS dadu Technical Stuff 62 14th March 2014 15:30
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
req help with indigo sx (diesel) on board diagnostics shldn Technical Stuff 4 26th March 2006 20:11
