Old 21st August 2012, 00:08   #481
HimuraKenshin's Avatar
Thanked: 183 Times
Default re: OBD (On-board diagnostics) for Indian Cars
Hey guys,
I recently bought a MaxiScanMS509 from Autel.
unfortunately, it doesnt work with pre kseries engine maruti cars, so now i cant use it..
If anyone would like to purchase it, please email me on sambuddha1234@hotmail.com or PM me.
MODS: i am posting here, as i received an error while trying to post an ad in the classifieds section.
The item is completely new and has been opened only for testing.
HimuraKenshin is offline   Reply With Quote
Old 24th August 2012, 15:31   #482
Has anyone seen/brought this one?
Bluetooth V1.5 ELM327 OBD-II Diagnostic Scanner | eBay
at Rs. 2340/- I feel its a great buy.
I have a Ford Fiesta 2006 Model and wonder if it works with it. In any case its a worth a try for this price.
shanks
Mysore
myshanks is offline   (1) Thanks Reply With Quote
Old 24th August 2012, 17:17   #483
dhanushs's Avatar
Thanked: 4,473 Times
shanks
Mysore
Hi myshanks,
Login to ebay.uk or ebay.com, you'll get much cheaper deals. I got it for ~1200.
And, yes, it will work for Fiesta Petrol.
Old 24th August 2012, 17:26   #484
k2max6's Avatar
Thanked: 130 Times
Is there any OBD device available for the previous generation swift petrol. (not k-series) that can provide data via bluetooth to an app like torque on my iphone.
k2max6 is offline   Reply With Quote
Old 24th August 2012, 18:23   #485
Thanked: 183 Times
I am in the process of receiving the Autosnap IN 815, that is specifically made for indian cars. I bought it from aliexpress.com. Should receive it within a week. i hope
Old 24th August 2012, 21:51   #486
archat68's Avatar
Thanked: 290 Times
Can you give us the link?
archat68 is offline   Reply With Quote
Old 24th August 2012, 21:58   #487
Thanked: 183 Times
here you go:
++IN805 - AutoSnap
Old 24th August 2012, 22:45   #488
archat68's Avatar
Thanked: 290 Times
I bought this one. Yet to be shipped. Asked the supplier about 2007-2008 Maruti cars and he clarified that it'll work. Waiting with my fingers crossed !!
Wholesale Product Snapshot Product name is 2012 Top-Rated Free Shipping Multi Language Latest Version With M6636B OKI Chip Autocom Cdp Pro Cars(Wholesale and Retail)
Old 25th August 2012, 19:32   #489
d_himan's Avatar
Thanked: 633 Times
Hi myshanks,
I got mine for around $18 including shipping. Numerous HK based sellers - just place a max bid of $15-$18 in Ebay.com - very likely to win.
d_himan is offline   Reply With Quote
Old 25th August 2012, 22:19   #490
Thanked: 586 Times
Originally Posted by Hashim View Post
Yesterday I received my ELM327 bluetooth OBD2 scan device but when I connected it to my accent obd port, nothing happened, no LED glow on the device. I checked it on a Mahindra xylo which came in my friends workshop and it worked on it correctly, got connected to ECU.
I found that pin 7 was +ve and 4 and 5 was ground. When I checked the same pin on the OBD port of my accent it did show 12 volts but as soon as I plug the device the voltage drops to 0.8 volts and hence device did not work. What could be the reason of this drop in voltage?
this seems a direct hit for my Xylo! please share the link of the product, and software used, especially for laptop.
thanks,
pcpranav is offline   Reply With Quote
Old 25th August 2012, 22:41   #491
Hashim's Avatar
Thanked: 32 Times
thanks,
here you go
product link: OBDII Bluetooth Car Diagnostic Cable - Black + Blue + Orange (DC 12V) - Worldwide Free Shipping - DX
software used: Scanmaster elm
Hashim is offline   Reply With Quote
Old 13th September 2012, 08:53   #492
Catalyst_delhi's Avatar
Thanked: 148 Times
shanks
Mysore
I got it for 1300 Rupees , the USB version connected to a mini laptop with Proscan 5.0. I am attaching the outputs on a PDF here. p.s - I had issues with a leaking PCV hose when these readings were taken , has now been changed. Apart from that LTFT is about showing lean , Will have to understand this more. ( gurus please help)
Car: Ford ikon 1.6 Year 2000
Fuel : only petrol
No mods
Last serviced:6 months ago , Throttle body and IACV cleaned 5 days before reading.
Issues now after reading: High Load readings ( might have been leaky pcv hose)
Timing: looks high
Catalyst_delhi is offline   Reply With Quote
Old 18th September 2012, 06:20   #493
Thanked: 148 Times
This is the data output from the ELM 327 USB reader.
Attached Excel Files
Car Ford Ikon 1.6l
No mods
Why is my load values way high when there is almost no load , I was the only person in the car? Please help?
My other parameters like Coolant Temp , Spark advance/retard is as per service manual. Fan low speed at 101celcius.
My IAT is high as the snorkel which comes with the ikon is missing - Have to make one.
Otherwise car revs till 5k rpm
I am only bothered about calculated load values.
Thanks in advance
Ismail Ghani
Last edited by Catalyst_delhi : 18th September 2012 at 06:36. Reason: added 1 more file , added more text
Old 18th September 2012, 06:43   #494
vikram_d's Avatar
Thanked: 940 Times
Car Ford Ikon 1.6l
No mods
Thanks in advance
Ismail Ghani
Was the AC on. I'm asking as the RPM indicates that it was.
Old 18th September 2012, 08:47   #495
Thanked: 148 Times
Nope Vikram the A/C was off. I even disconnected the AC relay but the calculated load figures are the same. I have a feeling that my MAP sensor is off. Please tell me what you think.
Sensors - MAP , IAT , ECT , Cam . No MAF
Diagnostics, Spares, Service & Upgrades for European Cars - Euro Car Pitstop (Cochin) Games Goblin Other Cities 4 14th May 2018 10:06
On Board Diagnostics (OBD) for Dummies a4anurag Technical Stuff 39 20th January 2017 20:39
TechSpec® : Understanding On-Board Diagnostics, also known as ECU, ECM, EMS dadu Technical Stuff 62 14th March 2014 15:30
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
req help with indigo sx (diesel) on board diagnostics shldn Technical Stuff 4 26th March 2006 20:11
