Old 8th December 2012, 12:27   #511
Catalyst_delhi's Avatar
Thanked: 148 Times
Default Re: Onboard diagnostics plugin with amazing features
Originally Posted by bharanidharang View Post
Disclaimer: Not sure if this is already posted. Please merge or delete
http://technabob.com/blog/2012/12/06...s-car-monitor/
Features look amazing. i am sure there are many uses for this. Will this work in India.
This will work on Fords for sure. Most of the OBD "dongles" do not have issues with a Ford. I have had good sucess with Renaults as well. Maruti not so good.
Catalyst_delhi is offline   Reply With Quote
Old 8th December 2012, 20:05   #512
silversteed's Avatar
Thanked: 1,503 Times
Older (Maruti)Suzukis yes. But the newer ones work well. 2011 and later models work just as fine as the others.
silversteed is offline   Reply With Quote
Old 9th December 2012, 16:40   #513
Thanked: 148 Times
Thanks Silversteed! Most of my friends ask if their car can connect , now i know. What did maruti change to make the OBD work?
Old 9th December 2012, 17:51   #514
vikram_d's Avatar
Thanked: 937 Times
They went from a proprietary protocol to a standard OBD2 protocol and this was when they introduced the K series engines.
vikram_d is offline   (1) Thanks Reply With Quote
Old 9th December 2012, 21:46   #515
Thanked: 17 Times
Default re: OBD (On-board diagnostics) for Indian Cars
Guys, can you help me in locating the OBD-II on my 2009 Getz? Below the steering wheel found this which doesn't look like OBD-II:
pamishra is offline   Reply With Quote
Old 9th December 2012, 23:35   #516
archat68's Avatar
Thanked: 266 Times
This is the fusebox.
archat68 is offline   (2) Thanks Reply With Quote
Old 10th December 2012, 09:26   #517
audioholic's Avatar
Thanked: 5,488 Times
Is anyone from bangalore ready to lend me an OBD device, just to check if it works with my cars, so that I can go ahead and by one for myself? I am looking for the scanguage type of devices. Even an ELM device would be good enough if I can look at data from my laptop. If any BHPian could lend me his device, I shall just plug it into my car and if it works, I will place an order for the same thing. I dont think it will work in my SX4 BS3 version, but I want to ensure it works at least in my wagonR. I dont want to order a product without knowing whether it works and then end up with a non compatible device.
EDIT: How about this one? http://www.amazon.com/ScanTool-42300.../dp/B002PYBZJO
Think it is a good deal is it not? Given that one will get the software bundled, the cost seems to be fine. Any inputs?
audioholic is offline   Reply With Quote
Old 10th December 2012, 10:18   #518
mercedised's Avatar
Thanked: 165 Times
What device/cable tobe used for Tata Safari Dicor 3.0L?
Old 5th February 2013, 14:22   #519
madhuperiasamy's Avatar
Thanked: 77 Times
Default Re: Suzuki Ritz Diesel ABS OBD Port
Originally Posted by Kannan View Post
mtnrajdeep, I have attached the OBD port of Suzuki Ritz Diesel (ABS). It's same as yours.
Going through this forum to identify compatible OBD Hardware and Software.
Can you tell me where I can find the OBD port in the Ritz ( VDI ABS) 2011 Oct Model
madhuperiasamy is offline   Reply With Quote
Old 5th February 2013, 14:35   #520
Note the area I've marked:
Probe with your hands, and you can find the OBD port there. Difficult to see it clearly unless you make room for yourself and bend down.
...I dont think it will work in my SX4 BS3 version, but I want to ensure it works at least in my wagonR...
The one in the link is fine. It looks like an ELM327 clone. Maybe you can search for ELM327 on eBay and get one. The K series engines are OBD-II compliant, AFAIK. So, it depends on when you bought the Wagon-R
silversteed is offline   (1) Thanks Reply With Quote
Old 7th February 2013, 10:39   #521
SalsaCorp's Avatar
Hi i have an ELM 327 OBD 2 connector, please let me know where can we meet this weekend and do some R&D. i stay in ramamurthy nagar
SalsaCorp is offline   Reply With Quote
Old 7th February 2013, 19:37   #522
Thanked: 77 Times
Salsacorp
Please specify to whom this message is directed. Else you can send a direct message to the concerned BHPian by passing the forum.
Old 8th February 2013, 10:25   #523
d_himan's Avatar
Thanked: 613 Times
After getting very excited initially seeing loads of real time data, I discovered the best practical usage for me.
Have the ELM 327 bluetooth permanently hooked on to the OBD II Port of my i10 AT.
I use Torque Pro on my el cheapo android phone to display:
a. Ambient Air Temperature - that roughly tells me what the temperature outside is
b. Fuel Efficiency (Instant, Trip, Distance to Empty).
This sorts out the one big problem I had with the car - no good MID.
d_himan is offline   Reply With Quote
Old 1st March 2013, 19:51   #524
Thanked: 77 Times
Finally got my OBD II dongle from Amazon. Smooth link up of my Maruti Ritz to my Galaxy Note running Android ICS.
Attaching a screenshot of the Torque app with the car in idling.
Old 1st March 2013, 21:01   #525
rajanprash's Avatar
Thanked: 35 Times
Hi, could you provide us a link of the same. Also is this on a Ritz petrol or Ritz Diesel??
rajanprash is offline   Reply With Quote
On Board Diagnostics (OBD) for Dummies a4anurag Technical Stuff 39 20th January 2017 20:39
Diagnostics, Spares, Service & Upgrades for European Cars - Euro Car Pitstop (Cochin) Games Goblin Other Cities 3 1st February 2016 13:36
TechSpec® : Understanding On-Board Diagnostics, also known as ECU, ECM, EMS dadu Technical Stuff 62 14th March 2014 15:30
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
req help with indigo sx (diesel) on board diagnostics shldn Technical Stuff 4 26th March 2006 20:11
