Old 14th March 2013, 21:23   #541
searchingheaven's Avatar
Thanked: 1,360 Times
Default re: OBD (On-board diagnostics) for Indian Cars
What cable is to be used with Ford Ikon 1.3 2002 model, since i dont want to use bluetooth? Where can i buy the cable? Where is the port located and what is the port(OBD I or II)?
searchingheaven is offline   Reply With Quote
Old 14th March 2013, 21:26   #542
dhanushs's Avatar
Thanked: 4,473 Times
Here you go, the port location: http://www.team-bhp.com/forum/techni...ml#post2414522
In case you want to use a cable, you might as well buy the wired (to serial port) OBD adapter.
Old 14th March 2013, 21:33   #543
Sorry, but i didnt exactly understand it. What is a wired OBD adapter and could you provide a example? Can i use the Torque app with it?
Old 14th March 2013, 22:29   #544
kamal.sn's Avatar
Thanked: 81 Times
Nothing for now Sir. I'm also eagerly waiting for a proper app like torque, for iOS.
I came across this when i was searching of some OBD app like torque for IOS :
https://itunes.apple.com/in/app/dash...321293183?mt=8
Also, a different adapter which provides a wifi access to OBD will be required as apple has restricted access to bluetooth services (or the apple bluetooth stack doesnt support bluetooth serial protocol) and ELM327 (bluetooth) will not work.
http://dx.com/p/obd-multi-scan-wifi-...l-white-179625
kamal.sn is offline   Reply With Quote
Old 14th March 2013, 22:52   #545
sara.ramli's Avatar
Thanked: 327 Times
Yes, Dashcommand is popular for iOS. There is even an Android port available in the Play store. The customization options available in Torque are what matters to me though. But agree that preferences could differ.
sara.ramli is offline   Reply With Quote
Old 15th March 2013, 05:21   #546
silversteed's Avatar
Thanked: 1,649 Times
The ELM327 comes in a wired form as well. Instead of Bluetooth, the external interface is a wired Serial line. The dongle will have a cable that would connect to a Serial port.
You cannot connect the OBD adapter to the mobile phone or tablet, but you can certainly connect it to your laptop with a serial port/USB-Serial dongle, and then use the bundled app.
silversteed is offline   Reply With Quote
Old 28th March 2013, 14:46   #547
Can anyone tell if Santro 2007 model is OBD/OBD2 compliant? If yes, where is the OBD port located. Thanks a lot in advance.
vishwas_bhp is offline   Reply With Quote
Old 29th March 2013, 18:14   #548
Thanked: 24 Times
Originally Posted by zmint View Post
but I am unable to connect to my vehicles ECU.
The software I tried are Scantool.net, Diginoto 4.03, ProScan 5.9, & Scanmaster.
The Scanmaster ELM shows only the battery level, with the following output :
Help me connecting successfully.
Hi
Sorry for Qouting such a old post but this is the only one for MANZA that i could find and it points as if the protocol is not supported by MANZA.
I used a generic Bluetooth adapter (ELM327 , OBDII) from Amazon (bluetooth version) and connected nexus 7 (fully updated) with torque (free) and Car Gauge Lite and it worked with both of the softwares.
Btw, my Manza is a OCT2011 BS IV version.
amit_arya is offline   Reply With Quote
Old 29th March 2013, 19:30   #549
Thanked: 84 Times
Fellas I am having a peculiar issue.
I get OBD done for my Old Honda City (02) today. There were two kinds of DTCs irst being current DTC and other Intermittent DTC.
current DTC searched few error codes but when we tried erasing them, the machine shows process being done but the codes didnt get get erased. We redone the error check and they again showed current DTC search. What could be the issue?
Are we doing the right way?
Honda Monk is offline   Reply With Quote
Old 29th March 2013, 19:44   #550
vikram_d's Avatar
Thanked: 940 Times
What are the DTC's that are showing up? Based on what the error code number, we may be able to help you.
Old 29th March 2013, 20:00   #551
dhanushs's Avatar
If there is a hardware problem, like a sensor not working. Most times, the error will not be cleared.
btw, what is the error code (#) ?
Old 29th March 2013, 20:03   #552
Thanked: 84 Times
Well to be honest first I was shocked to see 37 error codes all together. I didn't remember all but to specify there was air pump fault, cylinder misfire, heater sensor fault, IAT error.
The CEL light is off. The car is running fine with occasional or negligible missing (when speeding up from low (20-30) speed).
Cylinder misfire showed with 2nd and 4th cylinder.
One more thing I did just to check, I removed the MAP sensor which turned on the CEL but it was not showing in the OBD.
I also took TPS reading it sowed 0.66 then adjusted TPS and increased the figure to 1.72. I hope its right figure!?!
Roomi
Old 30th March 2013, 17:46   #553
DerAlte's Avatar
Thanked: 2,879 Times
... There were two kinds of DTCs irst being current DTC and other Intermittent DTC. ... current DTC search. ...
... 37 error codes all together. I didn't remember all but to specify there was air pump fault, cylinder misfire, heater sensor fault, IAT error. ... Cylinder misfire showed with 2nd and 4th cylinder. ... I removed the MAP sensor which turned on the CEL but it was not showing in the OBD. ...
Would be illuminating to know the exact error codes, like @vikram_d and @dhanushs have asked.
* Your engine could definitely do with some shake up - spark plug cleaning and gap setting, removing and reconnecting sensor connectors, etc.
* Some error codes are associative - removing a sensor need not throw up and error code, since the controls would use a replacement default and get on with life
* Didn't understand the following:
- "air pump fault",
- "heater sensor fault",
- "current DTC search"
Old 30th March 2013, 18:18   #554
Thanked: 84 Times
- "air pump fault",
DTC - Diagnostic Trouble Code
There are two kind of DTCs (a) Current; (b) Intermittent.
The first 3 points i wrote exactly as it was shown, even I am not pro in this so seek help here.
Also seniors please advice how to erase the errors? Need to go to Honda A.S.S.?
Old 30th March 2013, 18:29   #555
DerAlte's Avatar
DTC - Diagnostic Trouble Code ...
I know. What I didn't understand was "current DTC search"! "Search" is not understandable in this context.
Diagnostics, Spares, Service & Upgrades for European Cars - Euro Car Pitstop (Cochin) Games Goblin Other Cities 4 14th May 2018 10:06
On Board Diagnostics (OBD) for Dummies a4anurag Technical Stuff 39 20th January 2017 20:39
TechSpec® : Understanding On-Board Diagnostics, also known as ECU, ECM, EMS dadu Technical Stuff 62 14th March 2014 15:30
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
req help with indigo sx (diesel) on board diagnostics shldn Technical Stuff 4 26th March 2006 20:11
