Old 30th March 2013, 19:49   #556
Thanked: 84 Times
Default re: OBD (On-board diagnostics) for Indian Cars
Originally Posted by DerAlte View Post
I know. What I didn't understand was "current DTC search"! "Search" is not understandable in this context.
It was showing as "diagnostic search" while undergoing the process.
Regarding so many error codes I am clueless what to do now and where to get it done.
Honda Monk is offline   Reply With Quote
Old 30th March 2013, 20:32   #557
dhanushs's Avatar
Thanked: 4,119 Times
Originally Posted by Honda Monk View Post
Also seniors please advice how to erase the errors? Need to go to Honda A.S.S.?
Why are you so keen on erasing the errors?
IMO, the best way to go about it, would be to sort out the REASON for the errors one by one, and then clear the codes.
How did you check for error codes? Is it possible to post a screenshot? That way, what you are trying to convey will be clear.
Old 30th March 2013, 20:39   #558
Thanked: 84 Times
Thanks Dhanush for replying.
I had gone a regular check up, this time (after 2 years) I got OBD scan done and to my horror it showed 37 errors.
Through the same "Launcher" equipment he tried to erase the codes, although it was doing the process and at the end flashing the "DTCs cleared" but as soon as you re-run the DTC scan they all appearing again.
I am trying to clear the codes because the car is running fine.
Old 1st April 2013, 11:03   #559
searchingheaven's Avatar
Thanked: 1,358 Times
Which bluetooth OBD adapter is known to work with ford Ikon 1.3 2002 model? I just got a Galaxy S and would like to try it out with the Bosch fun2drive app.
searchingheaven is online now   Reply With Quote
Old 2nd April 2013, 20:57   #560
Thanked: 84 Times
Guys what should be the ideal reading for TPS and IACV ?
Is it car particular or generic for all.
Mine is Old Honda City.
Thanks!
Old 2nd April 2013, 21:29   #561
vikram_d's Avatar
Thanked: 937 Times
Thanks!
These readings are car dependent. Also with 30 odd DTC's I really don't think that your car would be working. There is something wrong with the reading process.
Old 2nd April 2013, 22:18   #562
Catalyst_delhi's Avatar
Thanked: 148 Times
Any OBD ver1.5 reader with bluetooth will work , works on my 1.6 ikon. tip : get the cheapest one off ebay. Mine was about 1.5k for wired and 2k for bluetooth.Basically ELM readers will work
Catalyst_delhi is offline   (1) Thanks Reply With Quote
Old 2nd April 2013, 22:58   #563
Thanked: 13,387 Times
Good tip buddy
Get the cheapest of the Ebay website. I got mine ELM 327 Vgate mini v2.1 for 1.5K.
Wired ones are a little more stable than the bluetooth ones I guess.
Anurag.
Old 2nd April 2013, 23:32   #564
dhanushs's Avatar
Just search for ELM 327 bluetooth adaptor in ebay/Amazon.com.
Will cost you ~15-20 USD.
Works like a charm!
Old 3rd April 2013, 00:23   #565
govigov's Avatar
Thanked: 453 Times
Has anyone tried this on a figo? Where is the OBD port located on a figo? I am trying to connect my scanguage to my friends figo and i don't know where the OBD port is.
govigov is offline   Reply With Quote
Old 3rd April 2013, 00:32   #566
dhanushs's Avatar
Yes, it wiil work on the Figo.
The OBD port is below the steering wheel. You have to open its cover and then plug it in.
Old 3rd April 2013, 04:37   #567
govigov's Avatar
Thanked: 453 Times
Thank you dhanush. I will try the same. is there some thing that i should take care of ? I think the protocol used is different, not sure though.
Old 4th April 2013, 21:35   #568
Works like a charm!
As suggested, opened Ebay today & searched for the adapter. Now my questions are:
1. There are n number of sellers, can anyone suggest a good one?
2. If a Tab has USB OTG functionality, can i use the wired adapter directly with the Tab. The torque app seems to have the wired cable facility.
Old 5th April 2013, 10:23   #569
silversteed's Avatar
Thanked: 1,469 Times
(image copyright: mediasplash)
I don't remember having to open a cover in the Figo. The port can be found under the steering column, a little bit towards the right, you can say, in line with the A-pedal
Look for a seller's reputation, and then order one.
I would prefer a Bluetooth dongle to a USB one, for the simple reason that I hate a clutter of wires. The USB connectivity works best with a laptop. Haven't used it with a tab with OTG, so I am not quite sure how the performance would be.
silversteed is offline   Reply With Quote
Old 6th April 2013, 12:31   #570
Thanked: 561 Times
i had purchased the OBDII ELM bluetooth device from DX.com. able to pair with 6789 on my Win7 laptop. but using ScanXL software couldnt connect to the device, my vehicle is Xylo. I even tried with OBDDoctor on my Nokia phone, its not connecting. kindly advise.
thanks,
pcpranav is offline   Reply With Quote
On Board Diagnostics (OBD) for Dummies a4anurag Technical Stuff 39 20th January 2017 20:39
Diagnostics, Spares, Service & Upgrades for European Cars - Euro Car Pitstop (Cochin) Games Goblin Other Cities 3 1st February 2016 13:36
TechSpec® : Understanding On-Board Diagnostics, also known as ECU, ECM, EMS dadu Technical Stuff 62 14th March 2014 15:30
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
req help with indigo sx (diesel) on board diagnostics shldn Technical Stuff 4 26th March 2006 20:11
