Old 27th October 2013, 22:25   #631
Thanked: 13,387 Times
Default re: OBD (On-board diagnostics) for Indian Cars
Originally Posted by Dry Ice View Post
Bought a ELM 327 to hook up to the obd port in a Scorpio. Initial test run went smoothly. FE and DTE figures depend a lot on the value we put in while setting up the profile.
Congrats on the ELM 327. I agree as the values like HP, Torque, Instantaneous FE, DTE all depend on the vehicle profile value. One thing that I have noticed is the Weight of the vehicle that has to be enetered which includes - drivers weight, accessories, fuel quantity and weight it contributes etc, how will this remain constant and what must be entered is what I am confused always.
Now am on the look out for OBD apps on android. Tried Bosch one and Torque so far. Torque seems quite versatile and way more customizable.
I liked the Torque PRO App and using that presently. Tried a few others but the rest are not as good as Torque.
In the HUD mode though, there is sort of a double image formation on the windscreen, any solutions?
I didn't get this problem your facing. Do you have any picture of the problem you facing?
Anurag.
a4anurag is offline   (1) Thanks Reply With Quote
Old 27th October 2013, 22:38   #632
archat68's Avatar
Thanked: 239 Times
This is because the FE/DTE is calculated based of MAF sensor value. It is not actual FE calculation from the injected fuel volume.
archat68 is offline   (1) Thanks Reply With Quote
Old 27th October 2013, 23:13   #633
audioholic's Avatar
Thanked: 5,270 Times
. In the HUD mode though, there is sort of a double image formation on the windscreen, any solutions?
Happens because the image from the screen is reflected off two surfaces of the windshield, the outer and inner. This I have observed to be more prominent in my SX4 and less in the wagonR. Due to the thick glass, you can see two images one reflected from each surface. Not sure but I think this is unavoidable but can be minimised by keeping the phone slightly inclined towards the front of the car and the image projected to the bottom of the windshield as far as possible. Thats how I try to reduce this effect.
audioholic is online now   (1) Thanks Reply With Quote
Old 28th October 2013, 09:45   #634
Thanked: 2,388 Times
For now, I have put in the gross vehicle weight and that seems to be returning the FE what is commonly reported by other owners. So am guessing its working OK. The accuracy can only be verified once I get the FE from tankful to tankful.
Torque is seriously good. I am also considering buying it.
In HUD mode, the display is reversed on the phone screen, and that is reflected on the car windshield, its here that double image/reflection appears. Will try to take a pic today and post.
Right, that makes sense. Will try it that way and see. HUD is kinda cool otherwise the phone on a holder is an option always available.
Dry Ice is offline   Reply With Quote
Old 29th October 2013, 09:31   #635
Something like this, got this image off Google.
Also, what do you guys normally monitor? Torque just overwhelmed me with the amount of data it can display - and you can only fit so much on a 4.5" screen!
Old 29th October 2013, 10:50   #636
Ohh!Oxygen's Avatar
Thanked: 42 Times
Attachment 1159389
Torque is pretty good. As you said its really overwhelming. You really need some time to read and understand the basics. I use the paid version and this is what i I have configured.
I use 3 Screens.
Screen 1 : Raw Data Display Load, Intake
Screen 2 : Accel, Revs, Throttle, Speed, Boost, Coolant Temp,
Screen 3 : Baro, Trip KPL, Trip Cost, Dist Empty
Refer to Torque wiki for more explanation about the counters.
http://torque-bhp.com/wiki/Main_Page
Wikipedia Page for codes
http://en.wikipedia.org/wiki/OBD-II_PIDs
BTW I like the default carbon fiber theme with round metallic dials.
Cheers,
Ohh!Oxygen is offline   (1) Thanks Reply With Quote
Old 30th October 2013, 02:22   #637
So a Tab 3 or a laptop would have how much display in one screen?!
Screen 1: Pedal D, Pedal E, Revvs, Fuel Rail pressure;
Screen 2: Average CO2 and instantaneous CO2;
Screen 3: Intake air pressure, intake temperature;
Screen 4: Eco Widget
Screen 5: EGR, EGR Error
Screen 6: Volts (CM), Volts (Ad)
Screen 7: HP, Torque
Screen 8: Load, Revvs, Speed, Fuel rail pressure, Boost, Coolant temperature
Screen 9: 0-60 mph, 0-100 kph, 1/4m time, 1/8m time, HP (Hardly use this screen)
Screen 10: Emissions readiness s/DTC
Screen 11: Revvs, fuel flow, Pedal D, Pedal E, MAF, Speed, Fuel Rail pressure
Screen 12: OBD Speed vs GPS Speed.
I know there are many overlap items in the screens I use but they keep changing as per usage and what I feel like checking. I love the App for it's user-friendly nature and the level of customization.
I have just downloaded another App called the 'Knock Detector". Will have to try how it works and does it give out any information.
Anurag.
Old 30th October 2013, 08:56   #638
Well that's a lot of screens! Tab3 or laptop would for sure display many more gauges than what can be fitted on a phone's display on a single screen - and still be legible.
For now, I have made this simple screen. Have to try it out in the car though.
The Rev counter is because the car is still in run-in mode and I have set an alarm if the revs cross 2200 rpm, let's see how it works.
Old 30th October 2013, 09:56   #639
skyfire2892's Avatar
Thanked: 156 Times
I have a nexus 7 and can fit lot of dials. I have got its cover stand and anti slip pad. So next time it will be standing right in front of me at the dash
Too bad the screenshot button is not working!
skyfire2892 is offline   Reply With Quote
Old 30th October 2013, 11:20   #640
Thanked: 83 Times
Originally Posted by kousik View Post
Before getting one of these ELM 327 for my Toyota Fortuner I had a quick google lookup, and surprisingly there are reports that Fortuner does not seem to be OBD-II compliant. Though a few pages ago I see a post "... Toyota - all ..." as compliant, a few threads elsewhere suggests it uses KWP2000/M-OBD and hence instead of a cheapo ELM, we need a more sophisticated & expensive reader (only affordable by service stations) to read the readings. A little more googling finds EFI scan, but that's $142 and obviously not justified as just for fun project.
Hi Kousik,
I am using Vgate OBDII adapter. It works fine on Hyundai i10, VW Polo, Ford Figo. But I am unable to connect it on Toyota Innova and Toyota Fortuner.
Just like to know if you have tried connecting ELM onto your Fortuner?
TIA.
Vishwas
vishwasvr is offline   Reply With Quote
Old 30th October 2013, 13:45   #641
bigben's Avatar
Thanked: 131 Times
Hi All,
Any luck pairing this with a 2009 Vista QJD?
Anybody in Hyderabad that can lend me their adapter to check if it works in my car?
Don't want to invest in something and later regret.
Thanks.
bigben is offline   Reply With Quote
Old 30th October 2013, 17:36   #642
Originally Posted by bigben View Post
Hi All,
I'm in hyderabad. We can meet up and you can try for your Vista and decide to buy a new or no.
Anurag.
Old 31st October 2013, 18:49   #643
kousik's Avatar
Thanked: 36 Times
Originally Posted by vishwasvr View Post
I am using Vgate OBDII adapter...
Not yet, though @devrajman has kindly offered to try one, I couldn't find time for the experiment. Actually after reading all the web forums, I'm not that hopeful but at the same time it wouldn't hurt to try. In my last short visit to US I tried to find one, but was confused about compatibility as i can't return it easily if that didn't work. Maybe one these days I'll try 327 myself and post the result, that'll close the issue for all.
kousik is offline   (1) Thanks Reply With Quote
Old 31st October 2013, 21:02   #644
Arun.K's Avatar
Thanked: 47 Times
Hi All,
Thanks.
Hi bigben, it doesn't work with 2008 and 2009 Vista QJD. But works fine in my cousin's 2011 Vista.
Anyway just give a try, in case if you are able to meet Anurag.
Arun.K is offline   Reply With Quote
Old 31st October 2013, 21:21   #645
Thanked: 83 Times
I read that Toyota uses m-obd (multiplex obd). So obdII is not compatible with Toyota.
Thanks for replying!
Cheers!
On Board Diagnostics (OBD) for Dummies a4anurag Technical Stuff 39 20th January 2017 20:39
Diagnostics, Spares, Service & Upgrades for European Cars - Euro Car Pitstop (Cochin) Games Goblin Other Cities 3 1st February 2016 13:36
TechSpec® : Understanding On-Board Diagnostics, also known as ECU, ECM, EMS dadu Technical Stuff 62 14th March 2014 15:30
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
req help with indigo sx (diesel) on board diagnostics shldn Technical Stuff 4 26th March 2006 20:11
