Old 15th November 2013, 23:44   #691
devrajman's Avatar
Thanked: 116 Times
Default re: OBD (On-board diagnostics) for Indian Cars
Torque Pro App does allow the addition of custom PID's.
How can we know the PID and how to add?
Anurag.
Easiest way to add plugin or install app tweaked for a particular make-model which have detailed PIDs
http://torque-bhp.com/wiki/Plugins
Also they can add it in main app if requested:
http://torque-bhp.com/software/torqu...d-pid-support/
Short Video on adding custom PID (gives fair idea ):
PIDs can be found via forum search or Professional Diagnostic tools Ilike Autocom CDP / Launch X431 / etc) display PID information which are manufacture specific.
Found a informative forum thread:
http://www.ft86club.com/forums/showthread.php?t=23530
devrajman is offline   (1) Thanks Reply With Quote
Old 17th November 2013, 11:59   #692
joecherian's Avatar
Thanked: 78 Times
for those in chennai, if any one wants to try out the Elm 327 bluetooth obd adapter, i can share mine with you to confirm whether it works in your car, before actually ordering.
joecherian is offline   (1) Thanks Reply With Quote
Old 17th November 2013, 12:06   #693
Jaggu's Avatar
Thanked: 7,674 Times
Got one yesterday works like a charm with CRV, Polo GT Tsi. Would not budge on Gypsy MPFI 2000 model and Swift DDiS. Santro AT it connects to ECU but pretty much no readings coming up :P
Wanted it for the gyspy, so might put it in classifieds soon. Unless someone can help me with cracking the Gypsy/MUL code.
Old 17th November 2013, 13:04   #694
sara.ramli's Avatar
Thanked: 327 Times
Add me to that list.
Device that I possess: generic ELM 327 BT Adapter
Using it with: Figo 2012 Titanium
PM me if you want to try it out with your car.
sara.ramli is offline   Reply With Quote
Old 17th November 2013, 13:37   #695
Jaggu's Avatar
Update works with Chevy Optra 1.6L also Super duper tool this is, wished it worked with MUL vehicles
Old 17th November 2013, 14:34   #696
arjithin's Avatar
Thanked: 1,044 Times
Hi Rajan,
I'm not sure, but If I remember it right, the ELM327 + Torque combo does not work for '09 Ritz. I may be wrong though. Have you tried OBD Scope?
My 09 Ritz VXi works perfectly with ELM + Torque combo. The kmpl calculated values are way off, need to go through the whole thread to find out if it can be made better.
arjithin is offline   Reply With Quote
Old 17th November 2013, 14:41   #697
DRIV3R's Avatar
Thanked: 1,156 Times
It works with MUL vehicles too. Check with the Gen2 Swift/DZire/Ertiga.
None of the OBD BT connectors I know work with the old gen Swift and few other old gen cars.
DRIV3R is offline   (1) Thanks Reply With Quote
Old 17th November 2013, 15:09   #698
audioholic's Avatar
Thanked: 5,268 Times
Works with BS4 versions in most MUL vehicles. They are Alto K10, WagonR K10, Estilo K10, A-star, Ritz, Gen2 Swift and Dzire, Ertiga, Sx4(vvt version), as well as imported vehicles.
ELM has a list of protocols that it can support in which the above cars use EOBD ISO9141 or ISO15765 protocols. The older cars use a Japanese one which is not supported by default. ELM327 also supports two custom protocols with user programmable settings. If that works, we can get data manually in a serial terminal. I will try doing that sometime once my exams get over and check if it works.
PS I am looking out for a bluetooth version. If you are not keeping it let me know.
audioholic is offline   (1) Thanks Reply With Quote
Old 17th November 2013, 15:56   #699
Gannu_1's Avatar
Thanked: 9,906 Times
Jaggu, could you share the link for the OBD adapter you've bought? I would like to see if it works with the GT TDI. I don't see a reason why it wouldn't, given it worked for the TSI.
Is the location for the OBD port somewhere near the steering wheel? What application was used to monitor the data?
I'd be much obliged if you could answer my queries. TIA!
Gannu_1 is offline   Reply With Quote
Old 17th November 2013, 18:10   #700
Thanked: 13,387 Times
The software than can be used are Torque PRO or Fun2Drive which can be found on Google play store.
Anurag.
a4anurag is offline   (2) Thanks Reply With Quote
Old 18th November 2013, 10:46   #701
Thanked: 2,068 Times
Slightly off topic - the ELM 347bluetooth dongle when I fitted into my 2011 SX4 ZXI VVT BS4, this is how it looked - ugly! Its hinders into the A-pedal/ right foot movement and ingress/ egress.
Se how much it comes out -
Clearly, manufacturer never expected to drive vehicle with any such diagnostic things attached there! So if i have to just use this while vehicle is stationary, its not great use
abirnale is offline   Reply With Quote
Old 18th November 2013, 11:07   #702
Jaggu's Avatar
http://www.ebay.in/itm/ws/eBayISAPI....E:L:OC:IN:3160
This is what i bought. Polo port is similar to that of SX4 posted above, only thing its horizontal and not vertical in positioning. I used Torque application on Samsung Tab.
Get the one that i got, its much more compact, just the height of OBD connector and will not be on your legs way.
Will PM you.
Jaggu is offline   (1) Thanks Reply With Quote
Old 18th November 2013, 11:15   #703
Thanks Jaggu, but its an older version of protocols supported - v1.5. The one I bought has v2.1 support of protocols. So if I manage to sell what I have, I will get the mini one as you suggested.
Old 18th November 2013, 11:35   #704
Gannu_1's Avatar
Thank you! Placed an order for this one:
http://www.ebay.in/itm/221316882337
Unfortunately, I have a Lumia 920 (WP8 device) and the OBD apps. are a little finicky going by the reviews. My roomie has an Android phone and tab however. Let us see how this goes.
Old 18th November 2013, 11:37   #705
Jaggu's Avatar
If i remember correct it has app for Win mob also in the CD, i downloaded the paid Torque app and then later realized that is included in the CD enclosed
On Board Diagnostics (OBD) for Dummies a4anurag Technical Stuff 39 20th January 2017 20:39
Diagnostics, Spares, Service & Upgrades for European Cars - Euro Car Pitstop (Cochin) Games Goblin Other Cities 3 1st February 2016 13:36
TechSpec® : Understanding On-Board Diagnostics, also known as ECU, ECM, EMS dadu Technical Stuff 62 14th March 2014 15:30
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
req help with indigo sx (diesel) on board diagnostics shldn Technical Stuff 4 26th March 2006 20:11
