Old 22nd July 2014, 15:09   #976
Thanked: 8,673 Times
Originally Posted by DerAlte View Post
While it seems feasible theoretically, in practice the toothed wheel mounted on the wheel (whose teeth the sensor senses) prevents the buildup.
Oh, it happens in real life, trust me. More often to your point a bad connection, but I ve experienced a few of these. Especially after a heavy built up of mud and or snow with some gravel in it. Car stops overnight, things seize up, freeze up and the next thing when you drive of in the morning, you have a problem. Very often misdiagnosed as a problem with the mud/snow. So they scrape of the mud/snow. Same problems persists, so they replace the sensor and whilst doing that actually fix the mounting problem because they will actually position the sensor with an appropriate gap. Very often nothing wrong with the sensor. Just has been displaced a bit and the gap has increased beyond what it can handle,
In fact there are patents out there on the way the sensor get supported/mounted to prevent this from happening.
Jeroen
Jeroen is online now   (1) Thanks Reply With Quote
Old 22nd July 2014, 17:04   #977
DerAlte's Avatar
Thanked: 2,879 Times
Default re: OBD (On-board diagnostics) for Indian Cars
... Especially after a heavy built up of mud and or snow with some gravel in it. ...
LOL Living in cities, where such things are unlikely to happen, sort of gives us the divine right to be blissfully ignorant of such things, and mercifully avoid analysis paralysis!
Old 29th July 2014, 23:20   #978
TheQuarterMile's Avatar
Thanked: 43 Times
Can anyone tell me what is the difference between these two models and which one to buy?
http://www.ebay.in/itm/SuperMini-ELM...3a3ef34&_uhb=1
http://www.ebay.in/itm/Android-VGate...cac88ad&_uhb=1
And also if any BHPian has a store on eBay can link me to it. Always good to support a fellow member
TheQuarterMile is offline   Reply With Quote
Old 30th July 2014, 03:55   #979
el lobo 6061's Avatar
Thanked: 1,009 Times
Get the supermini, as it is smaller in size. Both of them have same function, just the difference in size.
el lobo 6061 is offline   Reply With Quote
Old 30th July 2014, 06:44   #980
Thanked: 67 Times
This is a company in the United states whose product will give you a good idea about what OBD can actually do.
https://www.automatic.com/
I hope they make this available in India soon.
kenneyjacob is offline   Reply With Quote
Old 30th July 2014, 07:28   #981
Thanked: 14,349 Times
BHPian el lobo 6161 has answered your first query.
Here is the answer for the second one:
Find the below link to a BHPian's store and the item.
http://m.ebay.in/itm?itemId=161165289900
Anurag.
a4anurag is online now   (1) Thanks Reply With Quote
Old 1st August 2014, 14:36   #982
Thanked: 18 Times
Anurag.
Will this work for Tata Safari Dicor 2.2?
mandyrana is offline   Reply With Quote
Old 1st August 2014, 15:18   #983
When was it manufactured? Post 2009 ones it may work.
Anyrag.
a4anurag is online now   Reply With Quote
Old 1st August 2014, 16:39   #984
tsk1979's Avatar
Thanked: 16,015 Times
I got a similar device from China, and it mostly works for Tata Safari. Atleast the stuff I need (error codes, engine temp, rail pressure).
Use fun2drive app from bosch on your android phone.
Old 2nd August 2014, 20:51   #985
Thanked: 2,107 Times
A friend of mine has 2008 Indica Petrol - its a preowned. His car was overheating - the heating indicator gauge was about to break beyond max So he took it to the nearby FNG - they flushed the radiator with new coolant, new engine oil and the heating problem solved. But now a new problem at hand - the check engine light has come up!
I thought of helping him but need to know if the ELM 327 mini adaptor will work on his car? I have the adapter and works very well on my SX4. Not sure about if that will be compatible with his car or even his car is OBD II compliant!
Does anyone know top of their head if its worth calling him to my home and giving it a shot?
Actually, if someone has tried earlier on same model vehicle and know it doesn't work, I will avoid trying the ELM tool.
abirnale is offline   Reply With Quote
Old 2nd August 2014, 21:04   #986
Since you say it is 2008 manufactured, it week be OBD 1. So it'll not work.
Anurag.
Old 3rd August 2014, 01:42   #987
RSR
RSR's Avatar
Thanked: 4,549 Times
If it is a petrol Indica manufactured in 2008, then it is certainly OBD-II compliant. The protocol used is ISO 14230 KWP2000 (Keyword Protocol 2000). My earlier 2007 petrol Indica 1.2 Xeta uses this protocol, so it should be the same in your friend's car. The connector is located below the front passenger seat, and it may or may not have a plastic cover.
However, I have no idea if the ELM 327 mini adaptor will work or not, as I have not used it.
RSR is offline   (2) Thanks Reply With Quote
Old 3rd August 2014, 07:33   #988
Thanks RSR!
I just tried the mini ELM adapter and it worked! As you said the port was under the passenger seat. The fault code was decoded to be faulty sensors for radiator temperature. There was another code too - P0000. But no details. Upon lookup I did not find anything on it. So I assume it was because of the earlier code may be. Could that be?
Since I think the problem is sighted, next course of action suggested is to visit Bosch or similar reliable service center and get the sensors inspected, checked or replaced as needed.
I was tempting to clear the error codes and try through fun2drive app again. But then thought of not fiddling with it myself but a competent mechanic!
Thanks for the help!
abirnale is offline   (1) Thanks Reply With Quote
Old 3rd August 2014, 07:55   #989
RSR
RSR's Avatar
Thanks RSR!
You're welcome!
According to this site, P0000 stands for "No trouble code":
http://www.outilsobdfacile.com/data-...-code-obd2.php
There is absolutely no harm in clearing the error code(s), after noting it/them down. If the fault persists, the check engine light would most certainly glow again, and the same error code(s) would show up on diagnosis.
On the other hand, if the code was set because of the heating problem, and if this was sorted out successfully, the check engine light would not glow again, but only if everything is working fine.
In any case, I think the check engine light should stop glowing if the fault doesn't re-occur. So I believe the appropriate sensors do need to be inspected.
RSR is offline   (1) Thanks Reply With Quote
Old 3rd August 2014, 10:45   #990
tsk1979's Avatar
Thanks RSR!
The thermostat needs to be changed. This is a typical indica problem. However, if it still comes, after the thermostat and sensors change, it means that the car is still overheating, but not by much.
tsk1979 is offline   (2) Thanks Reply With Quote
Diagnostics, Spares, Service & Upgrades for European Cars - Euro Car Pitstop (Cochin) Games Goblin Other Cities 4 14th May 2018 10:06
On Board Diagnostics (OBD) for Dummies a4anurag Technical Stuff 39 20th January 2017 20:39
TechSpec® : Understanding On-Board Diagnostics, also known as ECU, ECM, EMS dadu Technical Stuff 62 14th March 2014 15:30
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
req help with indigo sx (diesel) on board diagnostics shldn Technical Stuff 4 26th March 2006 20:11
