Old 11th January 2017, 22:10   #1306
VinodDevil81's Avatar
Thanked: 226 Times
Default Re: OBD (On-board diagnostics) for Indian Cars
Here's the image of my Swift ZDi accelerator position.
Attachment 1594037
Link to my thread with some more images
http://www.team-bhp.com/forum/long-t...ml#post3338199
Here's some information from Torque App forums on "Throttle Position"
https://torque-bhp.com/wiki/Throttle_Position
Thanks Anurag.
So it is ok to have non-zero values for throttle position at idling.
I am also relieved to know that at full throttle, it need not show 100% in all cases.
Your reply cleared many of my doubts.
What does the owners manual say?
I couldn't find the idle rpm value in the owner's manual.
That's why I asked a MASS service advisor.
He told me it is 950 plus or minus 50.
I am not really sure whether it is correct.
Can other WagonR owners please confirm this?
Because mine shows between 700 and 750 only ( at idling without AC) and it is running perfectly fine with this idling rpm.
No issues now.No stalling, and no excessive vibrations.And no unusual loss of power in lower gears.
Everything seems to be ok now.
So is it ok to let it be that way itself, or should I take it to service center again and do something to bring it up to 950?
VinodDevil81 is offline   Reply With Quote
Old 11th January 2017, 22:48   #1307
audioholic's Avatar
Thanked: 4,986 Times
Originally Posted by VinodDevil81 View Post
Thanks Anurag.
This is ok and I have observed the same in my earlier WagonR as well. The throttle position sensor voltages are calibrated to be used in a zone which ends a little earlier to the boundaries, hence you get a variation between 16% to 80s. However there is another PID in the OBD called as relative throttle position. This will give you a much more realistic figure of the throttle position with respect to the pedal input.
The idle RPM is not a fixed value and can vary upon various factors. Hence, as long as the engine isnt stalling, the ECU will have good command over the idling RPM. Try half clutching for a while and the idle rpm increases for a few seconds and after which it settles down. Erratic idling is a throttle body issue and sometimes a case of a clogged fuel injector. There is not much room to manually adjust screws apart from setting the accelerator pedal tension which can be visible near the air filter box.
audioholic is offline   (1) Thanks Reply With Quote
Old 15th January 2017, 17:10   #1308
Thanked: 32 Times
I am in the market for an OBD for my Vento, Following the thread looks like ELM and Vgate are the popular ones. However I am looking for something that comes with GPS.
Seems like the ones that come with GPS, come with an web interface and more for business tracking their vehicles and speed checks.
Any recommendations on OBD which supports both Torque interface and GPS ?
rauldsouza is offline   Reply With Quote
Old 9th February 2017, 15:55   #1309
redcruiser's Avatar
Thanked: 215 Times
Guys,
How about this device which is quite popular in US and is top rated in Amazon.
http://www.plxdevices.com/Kiwi-3-OBD...346002832.html
Anyone who has used this could you throw some light please.
redcruiser is offline   Reply With Quote
Old 20th February 2017, 06:24   #1310
Thanked: 313 Times
Hi All! I got an ELM adapter from amazon for my Alto AMT. I have the torque pro app, however the app is the problem. When i enter settings, it keeps going to the main menu/page. Doesnt allow me to make any changes or so. Torque lite works fine and other apps also works fine. Any suggestions on how to fix this?
Edit:
Here is the link for the ELM adapter that i purchased from amazon:
http://www.amazon.in/Android-Torque-...dp/B0198NFQ3A?
sairamboko is online now   Reply With Quote
Old 20th February 2017, 09:57   #1311
Thanked: 1,244 Times
Here we meet again!
I am assuming that you are accessing the settings while being connected to the car via Bluetooth using an Android phone.
1. Do you see a warning somewhere saying that you are using a cloned device? If the answer is yes, you could either junk the obd reader or the paid app. Free versions usually have an option to override the warnings.
2. Uninstall the app and reinstall it from play store.
3. See if there are any OS updates available for your phone.
The third option worked for me.
PS: The cost of these devices have come down a bit. I had paid close to ₹900 when I purchased mine. It came with a mini CD containing software for Windows PCs.
dailydriver is offline   (1) Thanks Reply With Quote
Old 20th February 2017, 10:22   #1312
Thanked: 313 Times
Originally Posted by dailydriver View Post
Here we meet again!
1. No warnings about cloned device.
2. Did that already. Sorry forgot to put that in the post.
3. no available OS updates for my phone right now.
Also the issue occurs even when OBD is not connected/turned off. The app simply doesnt allow me to change anything in the settings.
sairamboko is online now   (1) Thanks Reply With Quote
Old 20th February 2017, 10:36   #1313
Thanked: 72 Times
Infractions: 0/1 (5)
Dear All,
I own Hyundai Grand i10 and if i put the ELM OBD device plugged in will it affect the battery life or not
N4Nikunj is offline   Reply With Quote
Old 20th February 2017, 10:39   #1314
Being not allowed to change settings when not connected to the car is alright. However, it should be possible for you to do it when the key is in the ON position and the obd reader is connected to the car's ECU(meaning that the app has recognised the ELM device). Try doing it once with the engine running.
Is the problem due to the fact that yours is an AMT? I am clueless there. Let's hope someone will shed some light here.
Old 20th February 2017, 11:02   #1315
rmonie's Avatar
Thanked: 43 Times
Has anyone been able to use an OBD tool with the Mitsubishi Pajero 2.8 SFX?
rmonie is offline   Reply With Quote
Old 2nd March 2017, 16:00   #1316
Thanked: 16 Times
OBD Gurus, I have a Maruti Swift Vxi and would like to buy this OBD. Is it compatible with my car? Is it worth it?
https://flash.newegg.com/Product/9SI...c-dealnews.com
Pacific is offline   Reply With Quote
Old 7th March 2017, 10:42   #1317
When i enter settings, it keeps going to the main menu/page. Doesnt allow me to make any changes or so. Torque lite works fine and other apps also works fine...
Has the issue been resolved? Please update.
Old 7th March 2017, 11:03   #1318
Thanked: 13,345 Times
Which year is your car? If it is post 2012, it will work.
I suggest you to search eBay for this OBD-II reader.
Old 13th March 2017, 15:45   #1319
coolaks7's Avatar
Guys, need help in diagnosing the error codes on Maruti Ritz Petrol (1.2K series). Till yesterday, the car was working fine but this morning when I started the car, it was revving erratically. I reversed the car out of my parking space and as soon as I shifted from 1st to 2nd, I noticed engine check light turning on and RPM getting limited to 1-1.2k. Thankfully, I had an ELM 27 adapter lying around and upon connecting it shows the following error codes on Torque Pro App:
P0108- Powertrain: Manifold Absolute Pressure High Input
P2229- Powertrain: Barometric Pressure High
P0103- Powertrain: Mass or Volume Air Flow Circuit High Input
A quick Google search reveals, it is relating to MAP/MAF sensor. But how to identify whether the sensor has gone Kaput or is it a loose connection related issue.
coolaks7 is offline   Reply With Quote
Old 13th March 2017, 20:57   #1320
Check this thread for possible solution to check if MAF sensor is working or not
https://www.obd-codes.com/p0108
On Board Diagnostics (OBD) for Dummies a4anurag Technical Stuff 39 20th January 2017 20:39
Diagnostics, Spares, Service & Upgrades for European Cars - Euro Car Pitstop (Cochin) Games Goblin Other Cities 3 1st February 2016 13:36
TechSpec® : Understanding On-Board Diagnostics, also known as ECU, ECM, EMS dadu Technical Stuff 62 14th March 2014 15:30
Advantages of OBD 2 over OBD 1 Sprucegoose Technical Stuff 19 20th October 2009 06:44
req help with indigo sx (diesel) on board diagnostics shldn Technical Stuff 4 26th March 2006 20:11
