| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian | My car is a 1992 Nissan Altima INLINE 6 Cylinder Manual Transmission "Carb" engine. The car was perfect since purchased. I am at the moment facing a very peculiar problem since 23rd January related to engine idling. The car starts with the first twitch of key cold or hot start not an issue. But in the morning first start the engine will turn over with hesitation and ONLY if given MILD throttle will it fire and then within 5 seconds of letting OFF the throttle it will idle well nothing erratic. after its warmup i drive about 1 km to the first signal and as i approach the lights to stop the engine will idle for say 20 to 30 seconds and then go so low so low so low as if it is going to stall and the engine will shudder the entire car and be that way unless I step on throttle and maintain it to give it that idle feel. Slot it in 1st 2nd 3rd 4th 5th and there is no finding of anything going wrong even engine is smooth. Do 100/120 and then come to next Stop and the engine will idle for say 20 to 30 seconds and then again start to run so low as if its gonna stall............. as above. I have checked Sparkplugs - OK 2 Coils - OK all hoses - OK Air Filter - OK clean no hose leaks Things I plan to do 1) Fuel Filter - replace 2) Carburettor - service (very worried on this as there are no good mechanics who can do a good job if the carb is removed cleaned and installed only 2 mechs who really know to do a skilled job - need Team BHP advice on this) Any of your comments advice will be much appreciated and I am more of the DIY type so let me have your suggesttions. thanks
__________________ 332kmph 1999 unrestricted GSXR1300R ROYAL ENFIELD MACHISMO 1992 636 RB20DET NISSAN |
| | #2 (permalink) |
| Team-BHP Support ![]() | 2 possible reasons.: Your engine seems to be running rich. Get the carb cleaned and the float checked. Also in carb engines there's a tiny valvepin thru which petrol is passed thru on the way to the carb. If this nozzle is clogged even with a tiny dust particle the petrol flow is obstructed and the engine starves - which if corrected by throttling will keep the engine running but flood the carb making it rich. Get this nozzle cleaned.
__________________ If you lose your temper, you’ve lost the argument |
| | #3 (permalink) | |
| BHPian | Quote:
Hi got the carb cleaned today. The carb was opened and it just seemed so complicated (TO ME) for a 14 yr machine. The carb has an auto choke, auto timing setup, and the factory pin screw was still intact which was hacksawed and a new springload screw was put in place by the mechanic / tuner. The carb only has one spring load screw to advance the idle speed (if needed). The setting for RICH LEAN is connected to the carb on the exterior face i.e. facing firewall fastened by 3 screws. On opening by just turning the small knob in it could be set to its very lean or very rich mix at present its set in between. amazing to me to find such tuning adjustment. The carb was never opened in 5 yrs since my purchase so i got the Fuel Filter changed too the old one was heavy and air was not blowing thru easily. Also installed a new PCV. The baby now is really hot with the gas pedal and I am really thrilled with the new feel not that it was bad but now i can see it happy at 50kmph in top with a light foot on gas earlier it had to be above 70kmph to be in 5th. At the moment the hesitation, stall feeling has gone off but will get to know a correct picture tomorrow morning on cold start (its 8C in bahrain - morning) and later in the day on a warm engine. thanks buddy.
__________________ 332kmph 1999 unrestricted GSXR1300R ROYAL ENFIELD MACHISMO 1992 636 RB20DET NISSAN | |
| | #5 (permalink) |
| BHPian | all was fine until yesterday evening today morning it failed to hold the idle speed without the throttle. the babe runs fine otherwise. Points noted: 1) at 80kmph in top if the throttle is pressed right down the acceleration is not smooth like it will buck a couple of times before actually delivering the power. Accelerator pump on carb was tested OK. any comments 2) the above happens in other gears too if the throttle is pressed full, gentle throttle response is perfect. 3) There is some kind of engine raise with each gearshift. The engine feels kind of raised as though throttle pedal is slightly depressed which last for about 2 to 3 seconds - Throttle cable is fine and loose not sticky at all confirmed. ur coments tbhp tech heads. Things done 1) accelerator pump checked 2) Vaccum leaks checked / all intake hoses 3) PCV changed 4) Fuel filter changed - fuel hoses all ok Things planning to do now FIRST - Timing set up 1) Anti dieseling solenoid on carb test 2) Auto choke if sticky test 3) EGR valve diaphgram test 4) Distributor area rotor etc let me know which to proceed on first or your comments as at the moment its quite hard to identify the culprit.1
__________________ 332kmph 1999 unrestricted GSXR1300R ROYAL ENFIELD MACHISMO 1992 636 RB20DET NISSAN Last edited by 2fast4u : 28th January 2007 at 10:36. |
| | #6 (permalink) |
| BHPian | hi tech guys help needed for carb based engine. After 3 visits to the mech the idle issue issue has been rectified and now the new problem which started today morning is car not starting on cranking up. Every time i turn the ign key it will crank the engine will kind of stumble shake violently and die. This has happened the first time today morning and theres no history of this happening before. It finally did start after 14 attempts and LIGHT throttle pedal was used as assistance in the last attempt to keep it running. After the 2 minute warm up the engine is absolutely fine and theres no sign of any problem it idles perfect and alls fine. Right now am at work so after a gap of approx 6 hrs i tried starting and it did crank but stalled, after 4 attempts similarly with Light throttle pedal as assistance it was fine took it for a spin 12 kms, turned off the engine restarted after 15 seconds started with ˝key turn, waited 10 minutes restarted ˝key turn all OK. The problem now seems to be cold starting, with engine warm its absolutely fine. I am looking at a choke open problem, sticky choke or a big vaccum leak (the last problem can be ruled out as all hoses checked, intake manifold secure, carb tightly secured, filter is new, distributor checked. your inputs please.
| | #7 (permalink) |
| BHPian Join Date: Jan 2007 Location: Pune
| I'm no expert (guess that goes w/o saying for most posts on internet forums), but many times the root cause is always something very trivial and easy to fix. It's just hard to find. I think, you should check 2 things first. 1. Is your battery/alternator ok? If the battery is down, or there's a fault with elec. system, not only will the car give starting trouble, at idling, the battery will act as a heavy load on the engine, causing the rpm drop and engine stalling. 2. There's a cable wire that gets pulled when you press the gas pedal. The cable then pulls smthing else (not your leg :-) ) which pumps more gas into the engine. Since, your engine isn't powering ahead on full throttle, my guess is, there's smthing wrong with the cable, and that's why your engine is acting funny on NO throttle and FULL throttle. Lemme know, if this helped. |
| | #8 (permalink) |
| BHPian | same problem today morning but attempts 5 and engine fired up with LIGHT foot on the throttle for about 20 seconds then its idling fine. amu@:the problem is not with battery and neither the cable. The throttle pump on the carb is also doing its squirting and release properly - checked, cable also is soft not sticky. The power delivery is fine otherwise there seems to be no issue when the engine is warm or even cold BUT right now it seems to be the DURATION between engine off to next start and I am zeroing on a carb flooding situation as when it starts there is quite some odour of fuel and some black smoke ONLY AT START. lets see what the mech can do based on the above info. I never have dreams but since my "stallion" is suffering i have started seeing the carb in my dream and what next i should check to get this leech cleared.
| | #10 (permalink) |
| BHPian | The mech checked yesterday and found the choke was not functioning properly, waited for engine to cool down and then he set the choke. Bingo today morning half key start , idling fine, acceleration good - same as it was before the problem started. I'm happy this thing has finally settled. Only will check to see if its FE is fine 9not a concern in this part of world but still) and also if its not running rich. the plugs are tan so all seems well. BTW this is a Hitachi down draft carb. Googling for a weber carb down draft 2 barrel. Psycho@ if u have some info or guidance much appreciated. thanks Will still change ALL the vaccum hoses that go to carb.
__________________ 332kmph 1999 unrestricted GSXR1300R ROYAL ENFIELD MACHISMO 1992 636 RB20DET NISSAN Last edited by 2fast4u : 5th February 2007 at 10:50. |
| Thread Tools | |
Similar Threads | ||||
| 10 Engine Idling "did you knows" EDIT: Myths & Facts added! | amit | Technical Stuff | 13 | 8th July 2008 07:46 |
| Engine dies during idling | mithun | Technical Stuff | 17 | 4th February 2008 10:25 |
| Engine oil issue. | sumitkalindi | Motorbikes | 7 | 10th September 2007 20:25 |
| Fiesta engine jerks and rpm varies while idling | tortoise | Technical Stuff | 16 | 13th March 2007 19:22 |
| Help on Innova Music System +Updates on Diesel Engine issue | pkp | Ask the Gurus | 4 | 16th May 2006 15:39 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
