Old 26th January 2007, 14:36   #1
narayan's Avatar
Thanked: 1,356 Times
Default disc brake lock up in OHC
ive experienced this twice now in the last 1 month,.,..
i had not used the car continuously for 4-7 days. and on both occassions, when i started the car and set into motion, there was a good sound from the brakes ( i suppose ) as if they had been locked up and getting released when the car set into motion..
is this a normal occurrence or is it time to clean up the brake pads ?
narayan is offline   Reply With Quote
Old 26th January 2007, 14:38   #2
theMAG's Avatar
Thanked: 1,574 Times
I'd say your wheel bearings need lubrication
Old 26th January 2007, 15:20   #3
Thanked: 655 Times
If your car is parked in an open space it could be dust getting between the rotor and the pads. If its only when you start, and only for a few seconds, I don't think its anything to worry about.
jyobeb is offline   Reply With Quote
Old 26th January 2007, 15:50   #4
danlalan's Avatar
Thanked: 135 Times
hmmmm..i face that problem too...but only for the first few minutes.dont use the car much and its always parked in the basement..so no dust there.
danlalan is offline   Reply With Quote
Old 26th January 2007, 18:01   #5
Thanked: 279 Times
It happened on my old opel astra once. It was rather due to rain water finding the way into the rear brake drum and the drum locked up when I tried to move. You might check that as well
badri is offline   Reply With Quote
Old 26th January 2007, 20:12   #6
flipsyde's Avatar
Thanked: 62 Times
similar thing happened in my maruti 1000. sorta grinding noise for a while when i start the car and then it disappears in less then a km on the roll. took it to M A S S and lubrication fixed it.
i suggest u get it done soon. i was told ignoring the problem would have resulted in worn out bearing which cost quiet a bit to replace.
flipsyde is offline   Reply With Quote
Old 26th January 2007, 23:28   #7
A good washing with the wheels removed should solve the problem.
Had similar problem with my esteem but it was due to brake pads touching the disc due to dry "brake caliper pins", got it cleaned and lubricated, working fine since then @30k kms.
Sutra is offline   Reply With Quote
Old 27th January 2007, 00:37   #8
aah78's Avatar
Thanked: 1,752 Times
do you leave the parking-brake on when you leave the car parked for long periods?
if so, the noise could mean the parking brake locking up....
aah78 is online now   Reply With Quote
Old 27th January 2007, 01:08   #9
rahul_intlad's Avatar
Is this practice not recommended? Does it have any harmful effects?
I always engage my hand-brake/parking-brake for long periods,short periods ,even while waiting at the signals.
rahul_intlad is offline   Reply With Quote
Old 27th January 2007, 10:40   #10
narayan's Avatar
ya i do engage parking brake always when car is stationary...anyways giivng car for 60k service..hopefully ill know whats the problem..thanks guys
mod - req u to close this thread..thank u
Old 27th January 2007, 10:50   #11
WasavaTyres's Avatar
Thanked: 255 Times
Ditto rahul,in fact I had the same misfortune of having a locked up rear drum on the matiz after I'd parked her with the handbrake on for about a fortnight during the monsoon.It just wouldn't budge and had that scary noise everytime I tried to floor it out.Finally had to call a mechanic who took apart the drum,lubricated and put it back together.Upto that point I felt these things only happened to fiats n amby's :(
WasavaTyres is offline   Reply With Quote
Bikes - Anti Lock Braking system on Disc Brakes mail4ajo Motorbikes 10 2nd March 2015 11:40
Paint for disc brake pads & rear brake drums VC12 Modifications & Accessories 8 25th October 2011 17:18
Security : Gear lock, steering lock venkatrx Modifications & Accessories 11 25th January 2011 18:04
Disc brake clean-up/change for OHC weejai Technical Stuff 41 9th July 2009 21:14
Superbike Security Systems - Disc Lock / Chain Lock / Alarm Systems gsferrari Superbikes & Imports 3 3rd July 2009 01:45
