Old 30th January 2007, 21:52   #1
nikhilv12's Avatar
Default head shaving???
what is head shaving? is it same as porting and polishing? or if it is different than porting and polishing, what is the difference??
nikhilv12 is offline   Reply With Quote
Old 30th January 2007, 22:29   #2
theMAG's Avatar
Thanked: 1,572 Times
Dear Nikhil,
You'll find most of these topics discussed - TBhp being 3 years old. The search function is quite effective.
Example: http://www.team-bhp.com/forum/techni...polishing.html (Porting and Polishing!!!)
Old 31st January 2007, 03:38   #3
Rehaan's Avatar
Thanked: 25,038 Times
Nikhilv12,
theMAG has given you a link to porting & polishing, so you can read that and figure out what thats about....
Shaving the head on the other hand involves removing material from the head (in the range of milimeters), for increasing the compression ratio.
Read about increasing the compression ratio. (compression ratio)
cya
R
Old 31st January 2007, 23:32   #4
nikhilv12's Avatar
thanks guys.... i was having no idea what so ever about head shaving, so confused it with porting and polishing....
Life on a Razor Edge...Shaving the retro way Guderian Shifting gears 80 13th October 2017 14:47
Hi. I'm a diesel head. jyobeb Introduce yourself 5 26th July 2004 14:41
Man survives six nails driven into head S350L-E240 Shifting gears 8 10th May 2004 23:35
