Old 1st February 2007, 09:43   #1
nanu28's Avatar
Thanked: 60 Times
Question Squeaky disc brakes on 1.8TPI?
Hello People,
My car is a 1.8TPI Skoda, so it has all 4 disc brakes. My question is , sometimes there is squeaking noise when I apply the brakes...? I have tried using WD40 sometimes on 2 discs at a time(either front or rear) and this seems to put the problem away for a week to ten days but then it returns....
any ideas...? Thanks
nanu28 is offline   Reply With Quote
Old 1st February 2007, 10:42   #2
Raajiv's Avatar
Get your Brake Drum cleaned professionally as it might have gathered dust over long use.
Raajiv is offline   Reply With Quote
Old 1st February 2007, 10:54   #3
Akshay1234's Avatar
Thanked: 7,239 Times
i may be mistaken but i think only the rs has all 4 didcs.. the tpi rider has discs only in front. at least that was what was written in the brochure.
Old 1st February 2007, 11:05   #4
Rtech's Avatar
Thanked: 221 Times
Please do not do that! Adding a lubricant onto the actual brake discs is NOT the best way to get your car to stop!
I assume that you ar is relatively new? How many km's has it done? Skoda OE pads usually get fried within 25-30,000 km's, and the sounds could be the wear indicators coming into contact with the discs. However, as you said that this is an intermittent problem, I don't think it could be a case of pads wearing out.
Another possibility could be the actual material of the pad itself. Some pads are noisier than others. Nothing to worry about.
Old 1st February 2007, 11:13   #5
nanu28's Avatar
Thanked: 60 Times
Lightbulb thanks....
1. Yes I am sure it has all disc, and no drums. Maybe now one gets drums, but mine has all discs, for sure.
2. WD40, was tried once, and one week on the front and once at the back...wont do it again thanks.
3. The car has only done about 16,000 kms, so i dont think that break pads are woen out, and I usually dont ever need to break hard.
4. Any other RS or TPI drives face this? if so then I can be rest assured it is the material...
the noise is not loud but its annoying when you want to sneak up on people.....
Old 1st February 2007, 11:29   #6
Thanked: 10,995 Times
Squeal is due to pads vibrating with the piston cyliner and brake disc while in action. You need to coat the rear of the brakes pads with a little of type of grease called copper slip/ copper grease. Don't put too much for obvious reasons. Some vvehicles have a small shim fitted between the pad and pistons.
Another cause could be plenty of brake dust
Old 1st February 2007, 12:22   #7
nanu28's Avatar
Thanked: 60 Times
Can you elaborate a bit more on this process...?
think I might need to do this....
Old 1st February 2007, 14:40   #8
shuvd's Avatar
@ nanu28 - I face the same problem in my 1.8TPi. The service centre guys said its due to dust/grime accumulation on the discs. The squeaks stop after using the brakes for a bit. But it again happens everyday when I first start driving her
shuvd is offline   Reply With Quote
Old 3rd February 2007, 00:14   #9
I have Skoda 1.9 TDI....just done 9700 kms...when the car is moved out in the mornings or lyin idle after 2-3 hrs at low speeds there is brake squeal...Pointed this out 3-4 times to the dealership, they say its peculiar to all octavia's and comes from the front disc's...(the 1.9 TDI has a Disc/Drum combo)... all they do is clean any dust, but the noise will be back next morning.....
milin is offline   Reply With Quote
Squeaky brakes? xuv2390 Technical Stuff 14 8th February 2018 22:41
Bikes - Anti Lock Braking system on Disc Brakes mail4ajo Motorbikes 10 2nd March 2015 11:40
Squeaky noise from the engine rjstyles69 Modifications & Accessories 5 19th October 2007 18:45
Squeaky Wipers whatcanthisbe Technical Stuff 1 26th June 2006 13:32
Disc Brakes - can someone xplain them to me? Shan2nu Technical Stuff 17 9th March 2006 00:08
