Old 10th May 2007, 08:59   #16
abhilashvk's Avatar
Thanked: 31 Times
I thought Fusion and Palios had drive by wire technology...That is for the accelarator and nothing to do with the clutch, right ? (apologies for my ignorance!)
abhilashvk is offline   Reply With Quote
Old 10th May 2007, 09:02   #17
moralfibre's Avatar
Thanked: 6,532 Times
I doubt the Santro and Swift comes with a hydraulic clutch. It is Cable as far as I know.
Old 10th May 2007, 09:06   #18
Vid6639's Avatar
Thanked: 20,984 Times
Originally Posted by viper View Post
I think almost all Maruti's have cable operated clutches, OHC cable, Hyundai Accent & Getz hydraulic, Santro cable, Lancer cable, NHC cable, Optra hydraulic.
Lancer is a hydraulic clutch. moralfibre (not MF!!!) the swift and santro both have hydraulic clutch.
Old 10th May 2007, 11:58   #19
ported_head's Avatar
Swift Petrol is cable, Diesel is hydraulic.
ported_head is offline   Reply With Quote
Old 10th May 2007, 13:41   #20
Vid6639's Avatar
it is? okay then it must be, I trust you more than maggie.
reminder to self: beat up maggie for telling his swift had hydraulic clutch.
Old 10th May 2007, 13:46   #21
moralfibre's Avatar
I should have put it that way.
I still think that the Santro clutch is cable operated. Will confirm tonight when I go home.
Old 2nd June 2007, 03:32   #22
Gtea's Avatar
The Scorpio also has a Hydraulic clutch.
Btw.. Is it possible to adjust a hydraulic clutch like cable operated ones?
(at least to a small extent??)
Gtea is offline   Reply With Quote
Old 2nd June 2007, 09:41   #23
Thanked: 245 Times
You are right, Santro has cable operated clutch
Old 2nd June 2007, 09:52   #24
prabuddhadg's Avatar
Thanked: 46 Times
The erstwhile Baleno used to have a hydraulic clutch
prabuddhadg is offline   Reply With Quote
Old 3rd June 2007, 09:09   #25
gd1418's Avatar
Thanked: 656 Times
Tata Safari, M&M Scorpio, Totyota Qualis, Ford Endeavour and GM Forestor all have hydraulic clutch.
Can someone please list some cars that have hydraulic clutches and some that have cable operated ones ?
cya
R
Old 3rd June 2007, 11:18   #26
Before all that, in 1986, the humble Trax introduced hydraulic clutch in India due to their getting the license for OM616 and TX-17 ZF tranny which only takes OEM MB clutch which is hydraulic, mechanical clutches are history due to their being too hard, specially on high power engines with heavy pressure plates, although I would admit, mechanical clutches have better feedback and easier to take abuse. Even on my VFJ Jonga, VFJ had to mod the original Nissan finger clutch to a hydraulic pressure plate diaphragm type due to the HINO engine's low end torque.
Gurkha is offline   Reply With Quote
Old 3rd June 2007, 12:30   #27
Awaiting Email Confirmation
Thanked: 319 Times
Default Its a matter of playing it safe.
Have you all noticed that majority of cars if not all have fluid operated brakes. Cable does not give you any warning at all before it fails unless you are lucky enough to have slowly shredding brake wire, if at all, like the ones used in motor cycles. Even bikes are now adopting fluid brakes especially in the front as fluid leaks give you ample warning before it completely fails.
As far as heavy vehicles are concerned everyone without exception use fluid actuated brakes.( Gases are fluids too)
The fluid reservoir is usually the same for the brake system and the clutch circuit and hence you will be forwarned by the dash light in case of low fluid for both like in the FIAT group of cars.
In the not too distant future the only cable operated part of the car could be the bonnet, petrol flap and boot release and the hand brake system.
Bye and wear your seat belts.
drpullockaran is offline   Reply With Quote
Old 4th June 2007, 16:48   #28
benbsb29's Avatar
Thanked: 4,276 Times
Just to confirm, the iKON has a hydraulic clutch (dan thought it was cable operated in this thread). In fact, the service advisor told me all Ford's in India have hydraulic clutches.
benbsb29 is online now   Reply With Quote
Old 4th June 2007, 17:24   #29
The only trouble i have with Hydraulic Clutches is that they need they seem heavy all the time and need good lubrication for 'you to be happy'.
THE OFFROADER is offline   Reply With Quote
Old 16th May 2009, 22:15   #30
ezee's Avatar
Thanked: 207 Times
Hey guys do you know anything or any person about converting from cable clutch to hydraulic clutch. I drive Logan Diesel and that have a cable clutch, which is hardest among all, risk for knees.
Let me know if you anyone in Delhi, Gurgaon who can convert to hydraulic.
ezee is offline   Reply With Quote
Leather Steering Cover - Pros & Cons mithun Modifications & Accessories 31 12th July 2016 19:23
Maruti 800 STD & 800 DX..pros & cons ? shapath Technical Stuff 6 21st August 2015 11:32
Radial Tyres - Pros & Cons mithun Tyre & Alloy wheel Section 51 10th June 2013 12:41
pros & cons of buying RE Registered car shapath Hatchbacks 5 14th June 2007 19:37
Pros & Cons of low profile tyres? satish_appasani Tyre & Alloy wheel Section 16 17th September 2004 21:39
