Old 4th February 2007, 13:50   #1
danlalan's Avatar
Thanked: 135 Times
Default Rear Suspension Change for the Ikon 1.6
Is there any way possible where as i can alter the suspension setup at the rear for my 00' ikon 1.6
The Factory setup is way to soft for my comfort..as in with 3people and luggage at the rear..its a scrapper at almost an bump on the road...
Can this setup be changed?
Will this effect the cars charateristics in any way...?
danlalan is offline   Reply With Quote
Old 4th February 2007, 13:56   #2
viper's Avatar
Thanked: 9 Times
Danny Boy,
Of course you can. Eat less chicken fried rice and you will be OK. On a serious note you can either stiffen existing shocks or go in for a Koni or similar branded setup.
Viper
viper is offline   Reply With Quote
Old 4th February 2007, 13:57   #3
Vid6639's Avatar
Thanked: 21,086 Times
This was changed in the NXT models. Seems it was a common complaint from all ikon owners. They shanged the suspension setup to prevent the car from squatting.
The worst part was is there were 3 in the back and there was a boot full of luggage the mudflaps would touch the road and scrape.
You could ask the ford guys how much replacing the dampers to the NXT will cost.
Old 4th February 2007, 14:48   #4
theMAG's Avatar
Thanked: 1,574 Times
3 options:
1. Stiffen exisiting shocks - viper should be able to do this for you
2. Replace with Nxt Ikon shocks - intermediate solution
3. Replace with Koni shocks - most expensive yet most elegant solution
Old 4th February 2007, 15:31   #5
Ford Rocam's Avatar
Thanked: 16 Times
if you are worried only about rear scrapping on bump on the road then ,
A simple cost effective solution will be add 1inch Spacer in rear should not cost more than 1000-1500/- max with labour, ofcourse there are other expensive ways to do.
Ford Rocam is offline   Reply With Quote
Old 4th February 2007, 21:22   #6
danlalan's Avatar
Thanked: 135 Times
ok ill go with vipers option1 and rocams option too...less chicken and a 1" spacer...
Why are car makers abandoning independent rear suspension? directinjection Technical Stuff 35 31st January 2017 01:57
Suspension change for Lancer Amey Technical Stuff 25 11th November 2011 11:46
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
is it time to change my front suspension?? zenopio Technical Stuff 8 4th March 2008 20:12
Gypsy suspension change Gypsy Modifications & Accessories 3 11th December 2007 19:27
