Old 9th February 2007, 11:50   #16
Thanked: 20 Times
Hi Guys
I too am facing a bit of an issue with my car;
1) Starting the car in the morning - the engine doesnt crank, need to do it atleast 3-4 times before it starts
2) done 7462 kms on it with 1 servicing
3) Am going to be away for about 3 months and during that period the car is going to lie idle, what should I do to ensure that it is up and running when I return
4) Am looking to do a Teflon coating and also anti rust, have read in the forum that 3M is a good option should I look at both being done now or after I return?
Its a Tata Xeta - GLS and bought it in August 2006.
saildrive is offline   Reply With Quote
Old 9th February 2007, 12:07   #17
tsk1979's Avatar
Thanked: 16,422 Times
saildrive, get the solenoid valve checked.
As for parking for long term, disconnect battery terminals before you go.
Use the search function and you will find lots of threads about teflon coating and leaving car for long periods(check car care thread too)
Cleaned Air Filter. Now, hissing sound TaurusAl Technical Stuff 5 18th July 2016 23:18
Get your car cleaned & polished, while you shop at a Mall captain.torque Street Experiences 13 17th February 2014 16:07
100% removal of flushed engine oil DieselFan Technical Stuff 13 19th February 2009 20:10
Strange thing happened after i cleaned the sensor on intake amit_mechengg Technical Stuff 7 11th January 2008 00:52
