Old 20th March 2007, 23:00   #16
1100D's Avatar
Thanked: 2,503 Times
Originally Posted by Absar View Post
Even they refused to sell (or atleast SHOW me) the screwdriver for the headlight beam adjuster screws. Arrrrrgh! They've frustrated me!
-Absar
Go to any hardware store and ask for a T-20 screw-driver (star type). Generally it will be amongst a set of such props. U can use the same for the air-filter box and other things. Tell me if you need the location of the adjuster.
1100D is online now   Reply With Quote
Old 21st March 2007, 09:17   #17
Hello 1100D. Thank you so much for the hint. In fact, I already have the screwdriver for the air filter box, but its pocket sized one, and doesn't go inside the holes for the headlight adjuster screws coz of its thickness. And yeah I do know where they're located.. But actually, before I tried using a philips screwdriver, with difficulty, n didn't work.. Today i'll go and check at one hardware shop if possible and try to get one.
-Absar
Absar is offline   Reply With Quote
Old 21st March 2007, 10:19   #18
Jaggu's Avatar
Thanked: 8,685 Times
use a 10 size spanner, works fine, keep the low beam settings LT side max to LT and at max reach, RT side straight and Max reach, with 95/100 works really well atleats for my car it did, only while fully loaded back when ur on a upward accent high beam will be a lil too far but can be managed with low beam
Old 21st March 2007, 10:39   #19
WhiteKnight's Avatar
Thanked: 76 Times
I got 55/60w headlights with the car. It was so pathetic. So, I upgraded to Philips Rally 90/100w. It still seemed so bad.
hmmm...sets me thinking. I recently upgraded to 90/100 Philips Rally. What was surprising is that the car already had 90/100 bulbs, which I never knew. But the new wiring /relay/Philips Rally did wonders to the beam.
Reading that along with what @1100D and @Jaggu mentioned, I think the upgrade is not done properly in your case. Take the car to a good accessary shop/ Local garage and check the installation. There is also a possibility that you have got duplicate bulbs
WhiteKnight is offline   Reply With Quote
Old 21st March 2007, 16:50   #20
...any hardware store and ask for a T-20 screw-driver (star type).
Hey 1100D! I went to one hardware store in my locality, and when I mentioned, "A T-20 Screwdriver, star type" he nodded as in he understood, but when he went in and came, all he got was a screwdriver that was more like a Philips X screwdriver in which everyone has... just to check, i tried on the car, didn't work (i knew it). I left the shop immediately. I didn't even try to show him the screw of the car's headlight.
Gee!!
And Jaggu, I doubt heavily if a '10' size spanner would do the trick, the spanner wouldn't go inside the hole of the screw..
-Absar
Old 21st March 2007, 17:05   #21
Jaggu's Avatar
mine the head of the screw/bolt was outside the hole, so it worked
Old 21st March 2007, 17:23   #22
Lucky for you Jaggu. Whats the solution for me now?
-Absar
Old 21st March 2007, 17:53   #23
Jaggu's Avatar
a) get hold of specific screw driver with short handle
b) remove the headlight bracket, adjust beam and refit
c) take to dealer/workshop and get it done under your personal supervision
Old 1st April 2007, 15:18   #24
spatafarose's Avatar
I could suggest you a less expensive method. Focus your fog lamps in such way that they are focussed on the road with load. That could help you.
spatafarose is offline   Reply With Quote
Old 16th March 2009, 16:08   #25
Thanked: 77 Times
Default headlights galore
Have been going through this old thread and the subject is something close to my heart. I dont actually have an ikon but purchased a versa in 2003 and since day one have been having problems with the headlights- in terms of spread, intensity and penetration. Since i do a lot of intercity travel with my family on weekends i was looking for something safer. Did'nt want to mess up the electricals by putting a relay, so eventually got hold of a pair of 60/55W halonix+60 headlamps (manufacturer-phoenix lamps). they are surely better than normal halogens. Incase you have'nt carried out any modification till date would certainly recommend that to you. Imagine what it could do to your headlights incase you put 100/90W halonix+60 along with a relay...
atul,
Faridabad.
dycme4@yahoo.com
9717640084
ATUL SINGH is offline   Reply With Quote
Ford Fiesta (old) and Figo Rear Twist Beam & PS Hose - Service Program / Recall Firebird Technical Stuff 201 13th July 2016 22:14
Ford recalls 16,444 units of EcoSport over twist beam issue Aditya The Indian Car Scene 13 23rd November 2015 23:53
High Beam - Help Pls. kuppan Street Experiences 31 14th April 2015 07:44
How To : Tell the oncoming vehicle to use low beam headlight!! racingmachine Street Experiences 62 9th December 2009 22:56
Ford Ikon mod - fiesta head on ikon block? madhunm Modifications & Accessories 2 2nd July 2007 09:24
