Old 7th February 2007, 12:56   #1
sankeerthreddy's Avatar
Default some play in the steering
hi guys, i have recently bought a OHC and when the steering is moved then it has a movement in upward and downward direction with an inch gap.so does it happen in all the vehicles,or is there anything wrong?
sankeerthreddy is offline   Reply With Quote
Old 7th February 2007, 19:02   #2
RacingForIndia's Avatar
Was this behaviour (steering) present before you bought the car?
Its very unusual though.
RacingForIndia is offline   Reply With Quote
Old 7th February 2007, 21:21   #3
Nope. Doesn't happen in all cars.
Is your steering adjustable? Perhaps it's not 'locked-in' properly, the way it should be. Call up the dealer/previous owner and understand its functioning from him/her. During my initial days of car-ownership, even I had got worried when the seat would move forward/backward when the car moved. Later found out that it wasn't locked-in properly.
amu1983 is offline   Reply With Quote
Old 7th February 2007, 21:26   #4
theMAG's Avatar
Thanked: 1,574 Times
The OHC definitely didnt come with rake adjustible steering. You have a problem. Was it ruled out beyond doubt that the car wasnt in any accident during its previous ownership(s) ?
Old 8th February 2007, 13:37   #5
esteem_lover's Avatar
Thanked: 451 Times
Now, how do you suppose he would know that ?
Old 8th February 2007, 13:59   #6
hellspawn's Avatar
Infractions: 0/1 (10)
how many kms has the car run??was it involved in any accidents??
the only posible explanation for the play in the steering wheel is that the steering column has been damaged orhas worn out.
the end of the steering column has some teeth on it which are used to lock in with th steering wheel.after sometime they get worn out.
the same thing happened in my zen as well and the fault was attributed to the wearing out of the steering column.it cost me 4k for a new one.so you should first gt your steering column checked.
hellspawn is offline   Reply With Quote
Old 9th February 2007, 16:53   #7
gbpscars's Avatar
test drive of course (the one that you do before handing over cash and feeling possessed by the OHC)
sankeerthreddy, you have a problem, the OHC's steering is not tiltable / rake adjustable.
gbpscars is offline   Reply With Quote
Loose Steering (Too much play in the steering) mithun Technical Stuff 5 23rd October 2012 12:35
Maruti Esteem - Non Power Steering to Power Steering udit78 Modifications & Accessories 14 4th May 2011 13:29
Skoda VRS steering play Frank Zappa Technical Stuff 8 23rd November 2010 22:32
Query on Steering Play in Tata Safari 2.2 VTT smsrini Technical Stuff 3 5th March 2008 17:28
Safari 2.0 TD - Bad Brakes & Steering Play abhishek2 Technical Stuff 4 19th February 2006 10:49
