Old 11th February 2007, 21:42   #16
esteem_lover's Avatar
Thanked: 451 Times
Car has come back, much fitter & stronger than before to take on these horrible roads. dont know the rates yet as i am yet to collect the bill. will let you guys know the exact amount for the spares as soon as i get the bill.
Old 13th February 2007, 12:50   #17
moralfibre's Avatar
Thanked: 6,533 Times
Hey Esteem Lover, got the bill? I am curious to know how it went.
Old 13th February 2007, 12:54   #18
Thanked: 451 Times
Check this evening after 8.00 pm. I should have got it by then, hopefully. My mechanic seems to be in no hurry to collect his payment. I have already reminded him a few times.
Old 14th February 2007, 22:26   #19
Psycho's Avatar
Thanked: 95 Times
And Psycho this question goes to you is getting the sturts reconditioned successful?
More often No than a Yes as it is dependent on the condition of the basic strut itself, shaft, seals, springs etc.
Old 20th February 2007, 12:58   #20
Thanked: 451 Times
The bill is finally here. This is the list of parts changed
1. Front Strut Assembly (MGP) - 2 Nos @ Rs.1,450/- each - Rs. 2,900/-
2. Rear Strut Assembly (MGP) - 2 Nos @ Rs.1,280/- each - Rs. 2,560/-
3. Lower Arm Assembly (MGP) - 2 Nos @ Rs.1,270/- each - Rs. 2,540/-
4. Joint Comp Rubber Bush (MGP)- 4 Nos @ Rs.15- each - Rs.60/-
5. Joint Comp Stabiliser Bar (MGP)- 2 Nos @ 102.50/- each - Rs.205/-
6. Re-bound Bush Strut (SGP) - 4 Nos @ Rs.378.50 each - Rs. 1,514/-
7. Strut Bearing & Bush (MGP)- 1 Set - Rs. 205/-
8. Grease - Rs. 40/-
9. Labour - Rs.1,300/-
Total Bill Amount - Rs.11,324/-
Old 20th February 2007, 13:39   #21
nitrous's Avatar
Thanked: 285 Times
What is the estimated life of this suspension job,John?
50,000 kms?
Old 20th February 2007, 13:46   #22
Thanked: 451 Times
My car has done 77000 & this is the first suspension work done. So, i guess it should be around 60-70k kms.
Old 18th February 2008, 17:05   #23
Xehaust's Avatar
Thanked: 74 Times
Hey,
I think my Astra's suspension needs work but dont know how much it should cost so have been putting it off for quite a while now. It has clocked over a lakh kms & i dont know whether suspension has been changed or not. Will try and find out.
Anyway, what would be the approximate cost? My car is pretty old so if it is a little high then i might as well let it be as its not unbearable or such.
Xehaust is offline   Reply With Quote
Old 18th February 2008, 19:47   #24
nitrous's Avatar
Thanked: 285 Times
Go to any good workshop and ask them what would be the cost-range for a suspension re-do on an astra. Ask him to give a minimum and maximum figure .
Old 30th December 2008, 18:57   #25
Mr_Bean's Avatar
Thanked: 142 Times
esteem_lover,data you provided was really informative.
My esteem is moving a bit to the left when i brake hard, but my mechanic says everything is fine, shocks would hardly require a change & frequent greasing would help . I guess I got to follow psycho's words of changing the entire assembly.
Mr_Bean is offline   Reply With Quote
Old 29th March 2009, 23:39   #26
HimuraKenshin's Avatar
Thanked: 183 Times
I got my suspension repaired too. The car was wobbling a bit at high speeds, (65+)
here are the particulars:
1 set linkage Rs 300
2 Front Lowering arm Rs 2450
4 Shock absorber kits 1300
1 rack Bush Rs 110
1 B-Rod Kit Rs 90
4 Shock Absorber bearings Rs 440
1 Set Rear break Liner (KBX) rs 450
1 set WLC assembly Rs. 210(dont know what this is, someone please explain)
2 Balance rods rs 480
4 Axel boots Rs 240
1/2 kg grease rs 100
1 Cotton waste Rs 10
Labour Rs 1200
Total: Rs 7380
The ride qualithy has improved a LOT after getting this done!
HimuraKenshin is offline   Reply With Quote
Old 3rd March 2010, 01:42   #27
monster2's Avatar
Hi Friends Then what is ball joint and tire rod here the Prices you mentioned I wanted to know the cost for same and Even the Clutch plate with Pressure Assembly.
monster2 is offline   Reply With Quote
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
Hardening esteem suspension techn0l0gist Modifications & Accessories 1 29th April 2008 21:52
95 Esteem Engine, suspension and chassis good condition IronWolf Shifting gears 0 2nd July 2007 02:25
Esteem Suspension invincible7 Modifications & Accessories 11 6th June 2007 19:58
Kindly Advise - Esteem Done 80k Needs Suspension + Cluth Plate passion4cars Modifications & Accessories 4 8th December 2006 02:13
