Old 8th February 2007, 08:30   #1
esteem_lover's Avatar
Thanked: 451 Times
Smile Time for Suspension Re-do for my Esteem
My esteem is going to the garage today for suspension repairs. She is 8 years old & clocked about 76K Kms. I will try & get a list of all the parts that are being replaced. If there is anything that i have to look for especially, please let me know.
Old 8th February 2007, 11:47   #2
Thanked: 451 Times
My garage has given me the list of items being replaced.
1. 4 Struts
2. 2 Front lower arm
3. Connecting Rods - 2
4. Bushes.
Is that all there is to the suspension ????
Guys, please let me know if there is any finer points that i have to look out for, please !!!!
Old 8th February 2007, 12:13   #3
n_aditya's Avatar
Thanked: 2,780 Times
Hey E_L if you've got the dough go for Koni FSD's (Struts) and stiffer springs in the rear... will improve handling phenomenally.
Alterntively you could try pedders. SAP / Electra will be able to give u more info.
All the best.
Old 8th February 2007, 12:25   #4
moralfibre's Avatar
Thanked: 6,532 Times
Originally Posted by esteem_lover View Post
1. 4 Struts
4. Bushes.
Does the esteem have 4 struts?
What do they mean by connecting rods? My friends Esteem is due for a suspension change and your thread will be great help for me. Thanks!
Old 8th February 2007, 12:43   #5
Thanked: 451 Times
Yes, the esteem does have 4 struts. I am going to the garage in a little while. Will get back to you regarding the connecting rods. (I think those are the rods that connect the lower arm to the struts, i am guessing)
@n_aditya : Thanks for the suggestion. i prefer to keep my car stock. I am changing to alloys & getting a new rear spoiler too.
Old 8th February 2007, 13:27   #6
ajitkommini's Avatar
Thanked: 109 Times
They're probably talking about tie-rods
ajitkommini is offline   Reply With Quote
Old 8th February 2007, 14:54   #7
Psycho's Avatar
Thanked: 95 Times
Those will be Tie Rod Ends Con Rods come inside your engine.
Old 8th February 2007, 15:04   #8
nitrous's Avatar
Thanked: 285 Times
John,who is doing the job and where are u sourcing the spares from??
Old 8th February 2007, 15:08   #9
2fast4u's Avatar
i guess people look at it the way tie rod threading is connected and say connecting rod.
2fast4u is offline   Reply With Quote
Old 8th February 2007, 17:32   #10
Thanked: 451 Times
All spares are from CARS India & the work is carried out by my trusted mechanic in Padi. (Asia Motors)
Old 8th February 2007, 18:38   #11
Mpower's Avatar
Thanked: 1,687 Times
Control Arm dosent wear out. You just need to change the ball joint and the bushes. The connecting rod could also refer to the sway bar link.
Old 9th February 2007, 01:31   #12
elf
elf's Avatar
Thanked: 9 Times
Have your steering rack checked while you're at it. Also check your steering column bushes - they wear easily & cause irritating rattles.
All the best.
elf is offline   Reply With Quote
Old 9th February 2007, 23:16   #13
How much? That's the first question you have to ask the mechanic.
My friend got his Zen's suspension re-done (changed the shock absorbers in the front+ the allied parts), and it costed him 10k. Even you should pay around that much.
amu1983 is offline   Reply With Quote
Old 10th February 2007, 22:14   #14
ankitahuja's Avatar
Thanked: 46 Times
Guys I am going to get the front shocks, tie rod ends and ball joints changed for my OHC Type 1 (not from HONDA). The price quoted is 7.5k, it this allright?
What else do I need to get checked, considering the car has clocked over 80k on the ODO.
Old 11th February 2007, 11:04   #15
pramodkumar's Avatar
Thanked: 947 Times
Hey esteem lover i did a suspension work but did not change the front and rear sturts. The ride was fine initially but soon the sturts were worn out and the ride is bad so let me know what is the price of a pair of orignal front sturts, since you must be buying them. And Psycho this question goes to you is getting the sturts reconditioned successful? and what will a pair of koni's cost?
NHC Suspension at 62,000KM - Want a better alternative to the OEM Honda suspension anandpadhye Technical Stuff 15 13th September 2008 18:56
Hardening esteem suspension techn0l0gist Modifications & Accessories 1 29th April 2008 21:52
95 Esteem Engine, suspension and chassis good condition IronWolf Shifting gears 0 2nd July 2007 02:25
Esteem Suspension invincible7 Modifications & Accessories 11 6th June 2007 19:58
Kindly Advise - Esteem Done 80k Needs Suspension + Cluth Plate passion4cars Modifications & Accessories 4 8th December 2006 02:13
