| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Senior - BHPian | It's bad times for me ... The bumper got hit twice, then a sidewall tear on the 3 week old F1s and now a broken headlight bracket - all in the span of a week. Bumped the right headlight into an ambassador's rear during a domino effect braking scenario. The headlight is fully functional , glass is intact. The only damage seems to be - the lower brackets which are attached behind the headlight assembly have broken. The one on top is fine. The bottom of the headlight therefore has been pushed into the body by about an inch. The beam is falling right in front. MUL workshop has only one solution - replacement. option 1 - EURO III headlamp with leveller ~12,000 !! Insurance will take care of 50%. option 2 - EURO II headlamp without leveller ~ 1,700 !! Insurance will pay nothing. Although I can go for option 2, it's bugging me to replace a EIII headlamp which is pretty ok functionally. Am planning to explore option 3 this Saturday. Option 3 - Go to a good roadside garage to fix the bracket. If it doesn't work out, I can always go for option 2. Awaiting your views and advise.
__________________ PIGZILNKILJBSCOMB Last edited by shuvc : 8th February 2007 at 16:54. |
| | #3 (permalink) |
| Senior - BHPian | Hey man, sorry to hear! Tell me, if Option 3 works, would your leveller be working still? If not, I'd go straightaway for Option 2 since at least you'd have an intact unit with no "quickfix" on it.
__________________ Land's end, journey's beginning - Safari Dicor VX 3.0L 4x4 |
| | #5 (permalink) |
| Senior - BHPian | hmmm .. let me try option 3 once .. on saturday .. meanwhile any other inputs are welcome .. @suman, the leveller is working even now .. all headlight/indicator functions are working fine. It's only the plastic bracket attached to the back of the assembly that's apparently damaged (it hasn't been opened yet). It's gone in an inch and is jammed there. That's why am feeling bad to throw away a fully functional 12K lamp for a 2K one.
__________________ PIGZILNKILJBSCOMB |
| | #6 (permalink) |
| Senior - BHPian | The only +ve for option 1 is that the insurance guy thought all the parking related scratches on the bumper were due to this incident - and said that bumper painting (worth 2700/-) will be borne by insurance ![]() But I guess i can get the bumper painted at a cheaper rate at a good paint shop outside.
| | #7 (permalink) | |
| Distinguished - BHPian ![]() | Quote:
Sad to hear that but how did you cut the sidewall on your new tyres?
__________________ There is a very fine line between "Hobby" and "Mental Illness". | |
| | #8 (permalink) |
| Team-BHP Support ![]() Join Date: May 2004 Location: Bangalore
| if you can manage to pull out the damaged leg and give it a good deal of araldate gum and leave for 24 hours and you should be fine but if the damage cannot be pulled out or recovered without opening the lamp unit go for option 2 also has anybody check out if option 1 leveling device can be removed and retrofitted to option 2?
__________________ The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin |
| | #9 (permalink) |
| Distinguished - BHPian ![]() | Hey Shuvc, if I get my head turning tomorrow, I may have a look at the unit. Maybe we can take it off once and show it to a person here who repairs plastic buckets. I guess he can do it.
__________________ ________________________ Every Ferrari is always a Fiat |
| | #11 (permalink) | |
| Senior - BHPian | Quote:
Got another contact - some Hyderbhai's garage on old park street.
__________________ PIGZILNKILJBSCOMB | |
| | #12 (permalink) |
| Senior - BHPian | Forgot to update the resolution. The headlight was taken out at a local garage. One of brackets/supports at the bottom was broken. The other partly cracked and bent. This was melted & straightened and the crack sealed with glue. They tried fixing broken support with glue too - however it couldn't take the load and came off again while fixing the headlight back. ![]() Apparently due to the absence of one support the right healight beam was still falling shorter than the left one. This was adjusted to a large extent by using the 'beam adjuster' on the unit (not the leveller control in the dash). So now it's been fixed for a total of Rs. 20 and running on 2 supports for the last 3 months ![]()
| Thread Tools | |
Similar Threads | ||||
| Replacing Headlight Bulbs? | udit78 | Technical Stuff | 0 | 12th June 2008 20:44 |
| Auto Innovations: Self-Repairing Paint! | Gordon | Technical Stuff | 19 | 21st May 2008 16:47 |
| What Diesel Sedan at 8L - 12L bracket? | shan_jp | Sedans | 29 | 2nd February 2006 09:25 |
| Relay for headlight | Akkiben | Technical Stuff | 7 | 14th December 2005 08:46 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
