Old 9th February 2007, 09:57   #1
vigsom's Avatar
Thanked: 604 Times
Default Bosch Wiper Blades - Bad Experience
After reading some good reports on Bosch Wiper Blades,I went in for a pair with great expectations.Sadly,the blades have proved to be the worst I have used so far.
While the rubber has still not started cracking , in less than one monsoon,they have started throwing streaks..very bad streaks.This is inspite of the best care taken.
I have used Syndicate blades from 1998 on different cars under the same usage conditions in the same territory with the same kind of maintenance.They have served me better.
Can someone let me know whom to address this to in Mico?
Old 9th February 2007, 14:01   #2
SUV
SUV's Avatar
What Car ? And where did u get the Blades from .. I have been using them for about 2 years now ... no problems till date ..
SUV is offline   Reply With Quote
Old 9th February 2007, 15:29   #3
kb100's Avatar
Hell Yes... BOsch baldes are BAD ... My OE blades lasted me three years - went in for Bosch replacements based on a friends recommendation - Horrible - they started streaking in less than a months time! - had them replaced with OE Hyundai ones - been a year since - still working like a charm!
kb100 is offline   Reply With Quote
Old 9th February 2007, 15:46   #4
flipsyde's Avatar
Thanked: 62 Times
i've been using bosch wiper blades on my maruti 1000 for the last 2 yrs..... works well. no streaking, no cracking nothing! its still going strong. mayb u landed up wit poor quality fakes!
flipsyde is offline   Reply With Quote
Old 9th February 2007, 16:42   #5
gbpscars's Avatar
beware of fakes! am sure you must have got one of them.
gbpscars is offline   Reply With Quote
Old 9th February 2007, 17:15   #6
vigsom's Avatar
Thanked: 604 Times
My car is a Versa..stock Syndicate blades lasted two full monsoons and packed up only in the third monsoon.By the way,the blades I bought are from the MICO dealer here.I ran a fair test through the packaging and am sure they are not fake.
For the wash fluid,I use a very dilute solution of Shampoo in water(say 5ml shampoo in 1 litre water).I have used the same "concoction" in all earlier cars..never a problem
Old 9th February 2007, 17:18   #7
quicksilver's Avatar
I bought two pairs from an authorised dealer and had the same issues. The blades work fine, but the streaks show up only after some time. I first tried them on my OHC and was so happy that I bought another pair for the Indica. 6 months later, I realised that there were minor streaks on both cars (which were running OE ones till then).
Back to the OE wipers now that work fine.... a lesson learnt there.
quicksilver is offline   Reply With Quote
Old 9th February 2007, 23:50   #8
ess_a's Avatar
OMG.. Today finally when my wiper blades could convince me that they needed retirement and I decided to go in for new ones, I see this thread. UUFF I had decided to go for Bosch, but now am in a little dilemma. Is there any one who will vouch for them OR should I stick to my Syndicate OEMs?
ess_a is offline   Reply With Quote
Old 11th February 2007, 05:40   #9
mithun's Avatar
Thanked: 59 Times
I would just recommend everyone to stick on to their OEM wiper blades, it's more than enough. There is no need for Bosch blades unless you are living in Chirapunji !!!
And never forget that the performance of Bosch wiper is not light years ahead when compared to the OEM ones....
Old 11th February 2007, 10:33   #10
Thanked: 655 Times
There are a lot of fake Bosch blades around. Even when you buy an original blade, make sure it has "TROPICALISED", mentioned on the packing. Have been using Bosch blades for over 15 years, but change them every monsoon. The best blades I have ever used, were a brand called TRICO. Sadly, can't find them anymore.
jyobeb is offline   Reply With Quote
Old 11th February 2007, 18:25   #11
flipsyde's Avatar
Thanked: 62 Times
u cant expect wiper blades to last more than 3 good monsoons. and besides bosch blades arent much more than the OE replacements.....for that price i think they're worth it.
you should be very careful about fakes. buy from reputed dealers.
Old 13th February 2007, 00:50   #12
Hi
My Esteem OEM syndicate wipers lasted me for about 5years. I changed them in this season as they cracked.
And Yes once again they lasted me 5years no kidding on this one.
Tnx n Rgds
P4C
passion4cars is offline   Reply With Quote
Old 20th March 2008, 16:01   #13
Wolffe's Avatar
The easiest way to take care of the blades is to keep upright when not in use,especially if the car is left in the sun.The rubber does melt & sticks to the windscreen.
I've read somewhere about wiping the blades with newspaper.Don't know if it works though.
Wolffe is offline   Reply With Quote
Old 20th March 2008, 16:36   #14
jkdas's Avatar
Thanked: 1,436 Times
Mumbai leads the list now. Kerala should be the next as its been raining of the last two weeks!
Why are we look for that?
Old 20th March 2008, 16:43   #15
ram_hyundai's Avatar
Thanked: 48 Times
A wiper blade throwing streaks would be due to several reasons.It need not be a defect at all of the blade.
ram_hyundai is offline   Reply With Quote
How to change wiper blades: A pictorial guide johy Technical Stuff 15 1st July 2018 11:34
Need Info on wiper blades for Verna. live2drive Modifications & Accessories 20 22nd September 2009 12:40
New Bosch Wiper Blades Squeeky..! wolfinstein Technical Stuff 32 1st October 2008 16:30
Accent Viva-Wiper Blades Issue mobike008 Technical Stuff 16 21st February 2008 01:09
