Old 25th June 2013, 19:56   #91
blackasta's Avatar
Thanked: 1,223 Times
Default Re: Hyundai i10 wont start due to inactivity..Please help
Originally Posted by ecenandu View Post
OK, why would the fuel mixture be rich if push start the vehicle. Are you saying its because of the low battery voltage.
As long as ECU is able to identify TDC and related timing regarding injection and ignition, I don't see any difference between a push start and cranking using self motor in a car with reasonably healthy battery.
AFAIK push start does not immediately start the vehicle as self start does. The time lag allows more rich mixture to pass through the exhaust system.
All of this is read from online forums where people listed their experience - never tried this myself or know anyone personally who did and fried his catcon.
blackasta is online now   Reply With Quote
Old 25th June 2013, 21:21   #92
RM2488's Avatar
Thanked: 117 Times
What I find interesting is this- apparently there is enough power being generated to run the fuel pump, but not enough for sparking(thus the unburnt fuel in the catcon)?
RM2488 is offline   Reply With Quote
Indigo --battery light which stays on when start and RPM meter is dead virender Technical Stuff 11 17th July 2012 11:17
Battery Dead!! whitesquall Motorbikes 29 22nd September 2010 22:10
Indigo --battery Light on when start and RPM meter is dead virender Technical Stuff 1 12th April 2009 14:10
Start battery dead cars without jumper cables using static electricity revvedup Technical Stuff 23 25th February 2007 00:13
Battery dead! Help! superavi Technical Stuff 7 1st June 2006 14:10
