| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| BHPian Join Date: Dec 2006 Location: Bangalore
| Hi, Yesterday, when I parked my car at office around 5PM, I left my headlight on (I do use the head light in basement, irrespective of the time of the day). When i returned to get the car back to home around 11PM, and tried to open the door with my remote key was not reponded. then realised that the battery id fully discharged. Called 24/7 number but no one was picking the phone. Then with some of my collegues try to start the car, by pushing, as no one had the jump cables, but couldn't start the car.Left the car in office and returned in friends car. Would request if you let me know 1. Will this 100% drainout of charge impact the MPFI functions? 2. Thinking of going back to office only on tuesday withMaruti service help, so is it fine if the car's electronic system to be in no power state for so long? 3. How safe is to jump start the car? 4. Does 100% discharge of battery requires a new battery. The car is just 2 months old. regards, -manju |
| | #2 (permalink) |
| Team-BHP Moderator ![]() | Never jump start an MPFI car. All its functions are governed by the ECU and no attempt should be made to alter this chain of command. You would also damage the exhaust/cat con. The power brakes and EPS also wouldnt work without the engine cranking up first The best practise is the user jumper cables to another battery to start the car.
__________________ If you lose your temper, you’ve lost the argument Last edited by theMAG : 10th February 2007 at 13:17. |
| | #5 (permalink) | |
| BHPian Join Date: Jan 2007 Location: Mumbai
| Quote:
| | #6 (permalink) |
| BHPian Join Date: Jan 2007 Location: Pune
| 2. Thinking of going back to office only on tuesday withMaruti service help, so is it fine if the car's electronic system to be in no power state for so long? >> Yes, it won't harm the car's electronic system if you keep the car idle, with a dead battery. But, I suggest you take a local mechanic with you to the office. Let him put in his spare battery, so that you can use the car over the weekend, and also go to the office on Monday. In the meantime, he'll re-charge your battery and give it back to you when it's ready (needs something like 10-12 hours of charging). Maruti Service station would just rip your money off, whereas your mechanic would do this for at most 100 bucks. 3. How safe is to jump start the car? >> I dunno what jump-start means. If you are referring to pushing your car till it starts, that won't happen unless you have battery power. It's okay to do this, if you have a low battery, but I think, you cannot do this with a dead battery. 4. Does 100% discharge of battery requires a new battery. >> Nope, recharging should suffice. And, BTW, you should consider buying the follow-me-home accessory. It shuts off the lights automatically after 1-2 minutes after the car is locked, so that you can safely find your way to the stairs in the dark. Or, just use the regular torch/torch in your mobile. |
| | #8 (permalink) |
| BHPian | [quote=manjubp;371564] 1. Will this 100% drainout of charge impact the MPFI functions? My Ans: Nothing will happen! 2. Thinking of going back to office only on tuesday withMaruti service help, so is it fine if the car's electronic system to be in no power state for so long? My Ans: As such there is no problem technically!! But aren't you concerned with the security aspect! Your car alarm (atleast) won't work if somebody try to steal your car!! Any body can put a battery and take the car away!! Tell the building security to take extra care of your car! 3. How safe is to jump start the car? My Ans: :"Jump start" means - using another battery and lengthy cables to start the car??? If yes..its absolutely safe if done by a technician!! "Jump start" means - pushing your car till it get started as you do in the older generation cars?!! If yes, don't even think of it! theMAG have already warned you about that. Also, one of my friend had a very bad experiance once! His timing got disturbed when timing wheel slipped a notch due to a week belt!! 4. Does 100% discharge of battery requires a new battery. My Ans: Not necessary!! You can use it after recharging it properly... better if you use new electrolyte!!
__________________ MISSED the action!!! :-( Guess another one has already started happening!! :-) |
| | #10 (permalink) | |
| Team-BHP Moderator ![]() | Quote:
My mistake, resultant of juggling multiple issues while posting at the same time.
__________________ If you lose your temper, you’ve lost the argument | |
| | #12 (permalink) | |
| [quote=nikkibike;371697] Quote:
Thanks for the caution about security. regards, -manju | |
| | #13 (permalink) | |
| Quote:
I think, I was too much into a customer meeting which was about to happen in an hour. regards, -manju | |
| | #14 (permalink) |
| Team-BHP Moderator ![]() | Park another car next to your swift, open the hood and connect +ve of that cars battery to your car;s battery and -ve to the -ve terminal. Crank, and your car starts. Its very simple. Let it idle for about 30 minutes or just drive around at good revs for about half an hour or so and your car battery will be charged. Alternatively you can spend some money and give the battery to a mechanic for charging.
__________________ Reclaiming.....! |
| | #15 (permalink) | |
| BHPian | Quote:
| Thread Tools | |
Similar Threads | ||||
| Swift Audio Set Up - Rs. 100/- K Budget -- Options ? | BHAGWAN | Ask the Gurus | 35 | 19th March 2008 14:56 |
| Swift crash in Mumbai leaves 2 dead | BunnyPunia | Street Experiences | 111 | 20th January 2008 10:20 |
| Start battery dead cars without jumper cables using static electricity | revvedup | Technical Stuff | 23 | 24th February 2007 23:13 |
| Which good battery for my swift | tabrez02 | Modifications & Accessories | 6 | 10th August 2006 11:29 |
| Battery dead! Help! | superavi | Technical Stuff | 7 | 1st June 2006 14:10 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441
