Old 10th December 2008, 11:27   #106
clevermax's Avatar
Thanked: 445 Times
Originally Posted by akshay4587 View Post
Mobile method has never worked for me.
regarding 24 hr helpline i dont think these guys are active here.
Now the only option looks like to fetch the spare key from my hometown.
but then battery will be dead.
In case it doesnt crank,should I recharge the battery or try to jump start it?
Do not jump start your car, try to recharge the battery, or connect another one in parallel and crank. Jump starting may permanently damage your Cat-con.
clevermax is offline   Reply With Quote
Old 10th December 2008, 12:46   #107
condor's Avatar
Thanked: 4,896 Times
Try to plug the exhaust. See if the engine shuts off. When the engine shuts off, the central locking normally dis-engages.
Old 10th December 2008, 12:53   #108
Vivek.Martin's Avatar
I don't think the engine is on in this case. If it is, just pull the fuel pipe from the tank.
Vivek.Martin is offline   Reply With Quote
Old 10th December 2008, 12:57   #109
normally_crazy's Avatar
Thanked: 394 Times
Disconnecting the battery will not work ?
normally_crazy is offline   Reply With Quote
Old 10th December 2008, 12:58   #110
Technocrat's Avatar
Thanked: 2,589 Times
How will he access the battery NC ?
Old 10th December 2008, 13:01   #111
deepclutch's Avatar
Thanked: 110 Times
Smile
that mobile thingy got no logic behind!My bet is the scale method and it is the only way except spare key
deepclutch is offline   Reply With Quote
Old 10th December 2008, 13:31   #112
clevermax's Avatar
Thanked: 445 Times
Originally Posted by me_sid View Post
The remotes in general work on IR. and mobile doesnt. Can you throw some light on this.
You are very wrong my friend, as far as car remotes are concerned. They work on RF. (Radio Waves) ~500Mhz.
Tv remotes, on the other hand, work on IR.
PS:- I've seen many people pointing their remotes towards the car and lock/unlock. Well, there is no point in doing this, since they transmit RF through an Omnidirectional antenna and not directed beam of IR.
Old 10th December 2008, 17:20   #113
Thanked: 63 Times
Doesn't it harm the engine due to high back pressure ?
lambuhere1 is offline   Reply With Quote
Old 10th December 2008, 17:27   #114
condor's Avatar
@Lambu, it's kind of an emergency, right ? The engine should shut off quickly .. it's not like you are going to do that on a regular basis.
What if this happened in some remote area - would you look at the damage this method may cause, or try get to the keys ?
Yes, the other option is to let it run out of fuel so the engine will die.
(May be you could jack up the front end of the car to create an artifical scarcity of fuel supply to the engine)
Old 10th December 2008, 17:36   #115
vikram_d's Avatar
Thanked: 940 Times
Plugging the engine idea will not work. This is because in most of the systems, the unlock is connected to the key. When you switch off engine with the key the unlock works. Even if the engine dies by plugging the key will still be in ignition on mode. So the doors will not unlock.
Old 10th December 2008, 17:44   #116
dkamath's Avatar
Thanked: 116 Times
Hi condor, thinking that this might still not help in unlocking the doors, as the ignition relay is still on. Finding that the doors unlock when the key mode is switched from 'ignition' to the 'electricals' mode, atleast with the Autocop makes. Not sure about the others though.
I faced the door-lock issue about a fortnight ago with the doors locking themselves up despite the bonnet being in a raised condition. Have to check with the Autocop service centre, as a sensor/actuator is mounted on the engine bay(cross member?) too. The steel ruler method helped in unlocking the doors.
dkamath is offline   Reply With Quote
Old 10th December 2008, 17:52   #117
vikram_d's Avatar
Thanked: 940 Times
Which vehicle was this?
Old 10th December 2008, 18:01   #118
dkamath's Avatar
Thanked: 116 Times
Sorry vikram_d, was commenting on that post at the same time. And the car here is the Safari LX . The Concorde guys spent quite some time, and succeeded finally in unlocking the co-driver's doors.
Old 10th December 2008, 20:47   #119
The new RFID based keys prevent locking the car with key inside.
The car simply will not lock if the key is inside.
Similarly, the car will not start if the key is NOT inside
abhijitaparadh is offline   Reply With Quote
Old 10th December 2008, 21:04   #120
Tejas@perioimpl's Avatar
Thanked: 5,475 Times
A year ago, i harassed the life outta a towing "walla" to teach me how to open cars with a scale and i finally mastered the art for my cars atleast. So i buy an extra long metal scale in my car for emergency purposes.
And as murphy's law goes, the day i locked the keys in my car, i realised that the scale was in the car as well!!!
Fortunately, i had parked in my compound and just went home and got the keys, but DUH!!!
So, where to keep this handy scale? any bright ideas?
Tejas@perioimpl is offline   Reply With Quote
Being locked inside a car! SafeDrive Technical Stuff 85 6th November 2013 12:18
Have you ever played full volume of your ICE? Ever?? xingamazon In-Car Entertainment 27 5th January 2011 02:41
Car Keys Vid6639 Shifting gears 13 3rd March 2008 13:47
Locked the keys in the car bruce Technical Stuff 40 24th October 2005 01:18
