Old 14th February 2007, 23:30   #1
namit's Avatar
Thanked: 49 Times
Default Car starting query
Hi All !!
I may sound very foolish but have this query.
This is regarding the modern MPFI petrol cars wherein after the ignition is turned ON the car is supposed to be started only after the hissss sound goes off after 3 - 4 secs of turning On the ignition.
I have noticed this in Santro Xing, Aveo and Zen MPFI.
Any idea why this wait ... bcoz even if you dont wait for those 3-4 secs the cars still start but is there any damage / disadvantage in that case ?
Cheers.
namit is offline   Reply With Quote
Old 14th February 2007, 23:57   #2
rohitbagai's Avatar
Thanked: 226 Times
I dont think so if there is any compulsion. The sound you mentioned is of fuel pump and nothing else
rohitbagai is offline   Reply With Quote
Old 15th February 2007, 00:26   #3
sreenivass's Avatar
In my Petra I am supposed to wait until the fuel pump indicator goes off, generally takes about the same time 4-5 secs. The engine starts even otherwise, but it was not suggested by dealer.
My own observation, the car felt weak if I do not wait for that long and turn ignition on right away.
sreenivass is offline   Reply With Quote
Old 15th February 2007, 00:38   #4
The Wolf's Avatar
Thanked: 58 Times
Every time you start the engine the ECU performs a diagnostic check and once it indicates everything is fine you start the car to avoid any damage caused due to interrupting the engine check... Its more of a precautionary measure to give your ecu that time, nothing else however if you dont wait till the engine chk is complete and till it returns with a OK indication you are overlooking the error (if at all there is any) coz of which you might start n run the car while the ECU is indicating that something isnt right, now that has a potential to cause damage!
The Wolf is offline   Reply With Quote
Old 15th February 2007, 00:45   #5
namit's Avatar
Thanked: 49 Times
Is yours a Petra Diesel ?
Old 16th February 2007, 07:04   #6
mithun's Avatar
Thanked: 58 Times
But my advice is to wait a few seconds before the morning start. Let the car do it's own POST(Power-On-Self-Test) !!!
It will be beneficial for the car in the long run.
Old 16th February 2007, 08:03   #7
rr_zen's Avatar
Thanked: 268 Times
It is always a safe practice and a good habit to wait for the fuel pump go come on and then start the car. After all what would one accomplish in this world in a matter of 3 or 4 seconds ?
rr_zen is offline   Reply With Quote
Old 16th February 2007, 09:48   #8
esteem_lover's Avatar
Thanked: 451 Times
It is better to let the fuel reach the carb/injectors before you crank, this would probably help in starting your car at the first crank itself.
Old 16th February 2007, 12:04   #9
I have Oel Corsa. The manual says that one should drive immediately without waiting. No need to wait for anything!
cartech is offline   Reply With Quote
Old 16th February 2007, 14:00   #10
somebodystopme's Avatar
Thanked: 17 Times
Hey, this delay also happens on my esteem 97 carb model...Is it supposed to have an ecu too???
somebodystopme is offline   Reply With Quote
Old 16th February 2007, 14:22   #11
srishiva's Avatar
Thanked: 929 Times
The thread is talking about waiting before cranking the engine. You have already started your car !! so no need to wait
srishiva is offline   Reply With Quote
Old 16th February 2007, 14:56   #12
Thanked: 451 Times
Nope, no ECU. It has an automatic fuel pump which starts pumping the fuel as soon as you turn the ignition. if the fuel in the carb has evaporated, then the car will not start at first crank if you do not wait for the pump.
Old 16th February 2007, 15:35   #13
sreenivass's Avatar
Default 1.6L Petrol
It is not a diesel, it is a 1.6L Petrol.
What is the procedure for push-starting a car?? Deeps Technical Stuff 29 24th December 2014 15:28
Innova Purchase Query + Query on Price Increase by Toyota SanMan SUVs, MUVs & 4x4s 7 30th April 2008 13:13
Car(petra 1.6) Starting Problem - Review of Tata and Fiat service greatDrive Indian Car Dealerships 12 28th March 2007 11:39
Starting trouble and Musical Car COUGAR Technical Stuff 3 4th January 2007 05:48
