Thread Tools
Old 15th February 2007, 10:37   #1 (permalink)
Vic
Default tilt in santro xing !!
I own a santro xing XP 2003.I have observed, if viewed from the rear, my car tends to tilt slightly towards right.I consulted an authorised dealer who says that i shld change the shockers!
Is he right?.....though i have not faced any problems in driving....
what else cld be the resons for it?
pls advies...thanks !!
Vic is offline   Reply With Quote
Old 15th February 2007, 11:39   #2 (permalink)
Pls introduce yourself in the appropriate section. Everyone told me so; am telling you the same
"shock absorbers" or "shocks",... i think there are no "shockers".
ur mechanic is almost right by visual analysis.
it can either be the shock absorber or its springs.
but, am sorry i have no idea about the suspension system of Santro.
__________________
...looking forward to sit a few feet above mean road level and away from potholes...
gbpscars is offline   Reply With Quote
Old 15th February 2007, 14:01   #3 (permalink)
Dear ViC
I am sure you would have taken care of the following aspect:
An Asphalted road will have a camber and if you have parked the car on the RHS of the road and keep looking from the rear, you may see the tilt you are explaining.
Check this aspect on a flat surface before changing the shock absorbers.
If the shocks need replacement, it will be glaringly clear when you are driving because of road conditions.
if you are not facing this problem, I feel there is no need to worry.
Sukhesh
sukheshkumar is offline   Reply With Quote
Old 15th February 2007, 20:10   #4 (permalink)
ritayan's Avatar
Vic
Try to jerk your car, if it comes back to the original position in one go your shocks are ok.. if it keeps swinging.. then they might need a look into.. Hope it helps.
__________________
Vision without action is a daydream. Action without vision is a nightmare
ritayan is online now   Reply With Quote
Old 16th February 2007, 16:13   #5 (permalink)
Vic
Dear Sukesh,
Thank you for your reponse. I have tried that but it seems even when parked on a flat road , the tilt is slightly there. However i have not faced any problem in driving, so i guess changing the shocks will be a bad idea.
Thanks again ....cheers !!
Old 16th February 2007, 16:15   #6 (permalink)
Vic
Hi Ritayan,
i have tried that as well!....but to no avail :(
i guess i 'll continue like this, lets see....
Thanks...
Old 16th February 2007, 18:25   #7 (permalink)
vikram_d's Avatar
you could get you suspension out and check the height of each side shock absorber. that could tell you if anything is wrong.
__________________
One piece at a time.
Old 16th February 2007, 19:06   #8 (permalink)
ThE_DoN's Avatar
Check the condition of your tyres for uneven wear. If they are alright then i guess you have no problems.
ThE_DoN is offline   Reply With Quote
Old 17th February 2007, 11:36   #9 (permalink)
jkdas's Avatar
is it when you have someone weighing 100kgs sitting on teh right side?:P
ok jokes apart... how does teh car handle on straight lines?
__________________
~ I n d i v i d u a l l y , we are one drop. Together, we are an ocean. ~
Old 19th February 2007, 16:52   #10 (permalink)
Vic
hey jk ,
That was a nice one
Driving wise the car is a beauty !! its just that tilt that bothers me ....
Old 19th February 2007, 16:54   #11 (permalink)
Vic
hey Vikram....thanks..i'll surely try that
Thread Tools
Santro Xing A/T - Will it be phased out or not? HSV The Indian Car Scene!! 21 23rd June 2007 19:25
I.C.E for santro xing speedfreak Ask the Gurus 8 5th October 2006 16:10
Santro Xing XG greenh0rn Long-Term Ownership Reviews 5 27th December 2005 14:38
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461
