Old 20th February 2007, 00:54   #16
nitrous's Avatar
Thanked: 285 Times
Also having disc breaks to all 4 wheels without ABS is a suicide. The car will lockup more often than car with drums in rear.
Ha ha ha!!
I have a few friends who have four wheel discs on their cars and they are no way SUICIDAL.
I'd like Sideways to comment on this.He drives a car with the above setup.
Old 20th February 2007, 09:50   #17
msdivy's Avatar
Thanked: 885 Times
This is the reason all cars with disc breaks all around come with ABS.
NHC VTEC comes with disc on all 4 wheels and no ABS ( Honda City ZX - City ZX VTEC - Specifications ).
msdivy is offline   (1) Thanks Reply With Quote
Old 20th February 2007, 09:57   #18
sharathjeppu's Avatar
Yup. Incase of cars with rear drum breaks the ABS module is only connected to front wheels.
I have tried searching for some confirmation that ABS module connects to only the DISC Brakes and not the Drum Brakes and I haven't found any. It would be great if someone could point at some resources to confirm this. Logically I don't see why ABS cannot be used on Drum Brakes.
BTW, here's a write up on Disc and Drum Brakes and it also points out to why Drum Brakes are still used. It apparently boils down to the cost vis-a-vis the marginal improvement in braking for the rear wheels.
Automobile Brakes - A Short Course on How They Work
sharathjeppu is offline   Reply With Quote
Old 20th February 2007, 10:37   #19
So that makes the Honda City VTEC a "not so Safe Car". It does not come with ABS.
BTW, the specs says that only the front brakes in the car are ventilated disks while the rear wheel brakes specifies only as a "disc brakes". What's the difference?
Old 20th February 2007, 10:55   #20
msdivy's Avatar
Thanked: 885 Times
Evolution of Disc Brakes and 'ABS'
msdivy is offline   Reply With Quote
Old 21st February 2007, 06:13   #21
mithun's Avatar
Thanked: 58 Times
Completely agree with the above statement since the brake locking is more prominent in discs because of better stopping power than drums. And all the folks usually pump the brakes in emergency situations.
Old 22nd February 2007, 13:03   #22
Rehaan's Avatar
Thanked: 25,038 Times
Thats what i thought as well (eg. santro), but i have never seen any documented proof of it.... im not sure whether that is because i am incorrect, or because hyundai does not want to mention anywhere that its only ABS on 2 wheels
Not true adya, several cars have discs all around and no ABS. For eg. the W123 series mercs, and are incredibly well behaved under hard braking.
EDIT: also dont forget that there is a brake bias designed into the braking system of cars with all around discs, and hence chances are you will lock up one set of tyres before the other, which is the same way it would be in the case of 2 discs and 2 drums on a car.
cya
R
Old 22nd February 2007, 13:08   #23
Rehaan's Avatar
Also,
Check out this previous discussion > link (Disc Brakes for Rear Wheel)
AND, follow the link in post #25 of the above thread !!! Its a great resource.
cya
R
Old 23rd February 2007, 04:31   #24
adya33's Avatar
Thanked: 97 Times
This thread has been an eye opener for me.
Thanks for info guys, guess you learn something new everyday.
adya33 is offline   Reply With Quote
Old 23rd February 2007, 09:53   #25
Shan2nu's Avatar
Thanked: 89 Times
Having all-round discs doesn't make a car suicidal, if the brake balance has been set right.
No matter how powerful your brakes are, you finally rely on the tryes to do all the stopping.
Shan2nu
Old 20th August 2017, 16:40   #26
Thanked: 17 Times
Default Re: Why drums in rear and discs in front ?
The weight of the car is much higher on the front end than on rear end. Therefore, more stopping power should be applied to the front wheels than rear. This is the main reason for having disc brakes on front and drum on the back side. The good thing is that the drum brake pads lasts longer and it works quite good for regular road use. However, if you happen to take the car on track, it is better to equip with a disc brake setup even on the rear, since the temperature generated will be lower on the disk brake system.
JozfGT is offline   (2) Thanks Reply With Quote
Paint for disc brake pads & rear brake drums VC12 Modifications & Accessories 8 25th October 2011 17:18
Swift - Wheel Discs and Brake Pad problems ravi23 Technical Stuff 25 18th August 2010 15:07
130 bhp, VVT-i, Airbags, climate control and all round discs..here she is. nitroxx Test-Drives & Initial Ownership Reports 49 19th October 2009 12:00
Plan to have 40 GB of songs and 100 GB videos without discs shreyasma In-Car Entertainment 16 30th May 2008 13:36
Rear Discs on Zen arjab Modifications & Accessories 6 16th March 2005 10:06
