Old 17th April 2004, 20:01   #1
I read a lot about these 3 things on How stuff works, now i want to just clear some of my doubts, Guys plz hlp me understand the fundas clearly
You can use the HP either to Create more speed or Tourqe right, Tourqe is reqd to do Heavy duty work, if so why is emphasis given on tourqe when discussions abt cars are going on. I am royally confused plz explain.
kakx is offline   Reply With Quote
Old 17th April 2004, 20:40   #2
Shan2nu's Avatar
Thanked: 89 Times
Like you said, Torque is basically the pulling power of the engine. BHP is usually gained higher up the rev band.
If you were to relate torque and power to humans, i'd say torque is like strenght and power is like stamina.
A body builder (torque) can lift twice the weight, that an athlete can, but the athlete (power - bhp) can run twice as fast and maintain those speeds for a longer time. *
Power and torque are not directly related to engine capacity.
Whether you pull 550 pounds - across 1 ft - per sec or pull 1 pound - across 550 ft - per sec, you're still producing "1" bhp.
Race cars rely more on power than on torque. The F1 car for example produces around 400-500nm of torque which is less than most "supercars" but at the same time produces close to 1000bhp which no present supercar can match.
From what i've noticed, torque of a petrol engine is directly related to the displacement of the engine. A 1.6 ltr petrol engine will usually produce less than 160nm of torque, 3ltr engine produces less than 300nm. Note that i'm reffering to "naturally aspirated" engines here.
The Vtec which has more power can accelrate faster through the rev band and will reach a higher top speed but the Accent CRDi which has loads of torque can do more heavy duty work and will accelerate in 4th and 5th gears faster than the Vtec from lower rpm.
""why is emphasis given on tourqe when discussions abt cars are going on" this is becoz most drivers like to cruise at lower rpm in a higher gear and would preffer a car that car pull away without having to downshift, this is where torque makes all the difference.
Regards...
Shan2nu
Shan2nu is offline   (1) Thanks Reply With Quote
Old 29th April 2004, 00:43   #3
Shan2nu's Avatar
Thanked: 89 Times
Hey guys,
I found this very informative site on Power and Torque. There are some more interesting topics.
http://www.dur.ac.uk/r.g.bower/PoM/pom/node7.html
Regards..
Shan2nu
Old 29th April 2004, 05:06   #4
Thanked: 16 Times
Nicely explained Shan2nu, but ..
Why dont people talk about power to weight, as much? When it comes to talking performance.
Infact I dont see any MAGs publish Power to Weight Ratios of the cars they test.
I feel thats also very crucial.
Pferdestärke is offline   Reply With Quote
Old 29th April 2004, 12:01   #5
Thanked: 103,780 Times
Originally Posted by [b
Quote[/b] ]Why dont people talk about power to weight, as much? When it comes to talking performance.
Power to weight is one of the most important influences on the performance of a car. Autocarindia and Overdrive, both publish these figures in their road-tests.
Old 29th April 2004, 19:24   #6
hey gto.. how do you calculate power to weight ratio?
Sheruken is offline   Reply With Quote
Old 29th April 2004, 19:33   #7
Shan2nu's Avatar
Thanked: 89 Times
Power to weight ratio is maybe the easiest and cheapest way to make your car go faster.
Infact, instead of adding, all you have to do is reduce the weight of the car buy removing unwanted things.
Regards...
Shan2nu
Old 29th April 2004, 19:49   #8
Shan2nu's Avatar
Thanked: 89 Times
1000*power of your car / by the weight of your car.
For example for the vtec.
1000*106 / 985 = 107.61 bhp/ton
Regards...
Shan2nu
Old 29th April 2004, 19:52   #9
Quote[/b] ]hey gto.. how do you calculate power to weight ratio?
Formula - BHP/Weight multiplied by 1000.
Forf e.g. if you want to calculate the power to weight for a Tata Safari (hehehe, my favorite joke) the weight is 2040 kg and the power output is 90bhp.
Thus 90/2040 x 1000 = 44.12 bhp to the ton.
Old 29th April 2004, 20:16   #10
Oops, looks like we were typing on the dot Shantanu.
But same difference, nevertheless.
Old 28th May 2005, 18:32   #11
hot_rod's Avatar
Bravo well explained dude!
keep ip the good work!
hot_rod is offline   Reply With Quote
Old 18th June 2005, 20:10   #12
karthik247's Avatar
Thanked: 16 Times
guys while doing wheelspins, does torqur or BHP count more??
karthik247 is offline   Reply With Quote
Old 20th June 2005, 11:47   #13
I think it's torque. Am I right guys ?
skidrock is offline   Reply With Quote
Old 20th June 2005, 17:34   #14
kooldude's Avatar
[quote]
[quote]
hey shantanu can u explain both of these things a little better
kooldude is offline   Reply With Quote
Understanding Power, Torque, Gearing and Top Speed Harbir Technical Stuff 63 30th April 2018 05:42
What is the most important factor affecting speed? Power, Torque, or Gearbox? holysmoke Technical Stuff 27 5th April 2010 18:14
Addicted to speed and torque. Suggest a bike for me MutantX Motorbikes 34 20th November 2009 19:20
About Gear Ratios & their Relation to Tyre OD, Torque, Speed etc speedsatya Technical Stuff 90 8th April 2008 11:50
Speed Freaks - Watch your speed!! GTO The Indian Car Scene 18 14th July 2004 03:02
