Old 17th January 2009, 10:33   #61
Thanked: 89,389 Times
"Wearing out the gears" at 25K? That's a new one. However, the Swift does have a weak clutch which is known to fail prematurely.
Old 17th January 2009, 12:07   #62
Atlblkz06's Avatar
Originally Posted by paranoidAndroid View Post
One of my friends who owns a swift (abt 2 yrs old/25k kms) gave her car for servicing as the car was making a sound like a jet taking off when she tried to take the car beyond 70-80.
Thats easy - keyword bolded
Hmm, transmissions can only go bad that quickly when mistreated. Maybe she powershifts when you're not looking? It sounds like the gears are damaged. Maybe she learned to drive on that car and ground up the gears? That is quite strange! What you say is correct though - even if she rides the clutch, the gears should be ok. Let me know how it pans out.
Atlblkz06 is offline   Reply With Quote
Old 23rd January 2009, 22:07   #63
Ravveendrra's Avatar
Thanked: 405 Times
a swift (abt 2 yrs old/25k kms) gave her car for servicing as the car was making a sound like a jet taking off when she tried to take the car beyond 70-80. The Maruti Service station guys told her that her clutch was worn out and so were the gears and this was probably because she was using the clutch too much while driving (coasting/cruising with the clutch pressed so that the gear isnt engaged).
I dont understand how this can happen.
Sounds like a rip-off to me too. Do what you would, if your doctor told you to get a heart transplant - get a second opinion!!
Best of luck
Ravveendrra is offline   Reply With Quote
Old 28th January 2009, 18:52   #64
It was a rip off (attempted atleast i guess). Next day her dad went down and fought it out with those guys. In the end they just replaced one of the bearings and its working fine now. Turns out one of the bearings was worn out and was making the noise. And the clutch they said is bad shape but would work for now, so my friend decided to stick to it for a while more. I drove it around a li'l bit and felt it was driving decent. Gotta run it for a while before we can know for sure that everything is fine i guess.
What material is the tranny made of, to last for so long?
paranoidAndroid is offline   Reply With Quote
Old 7th February 2009, 23:08   #65
AyAn!'s Avatar
Thanked: 850 Times
When a Merc SLR or some V8 muscles revs,there's a loud ticking sound after evry rev...what exactly is that?? Is it related to the valves??
AyAn! is offline   Reply With Quote
Old 1st December 2009, 03:20   #66
Thrust bearings are known to worn early if one doesn't take proper care of v8.
Also, there are only and only 2 types of cars, one doesn't need to double clutch and heal and toe, Automatic Transmissions and Nissan 350z/370z
Otherwise Double Clutching is still used. Even on the cars like GTR.
it_inspector is offline   Reply With Quote
Old 4th December 2009, 01:54   #67
IndrojitSircar's Avatar
Thanked: 113 Times
In some old buses and trucks they have the same system of double clutching.But one thing i have noticed in most of them and that is when they shift into first from nuetral i.e. at a stand still position the gearbox makes hell of a noise while shifting in.What is the reason behind this?
Old 4th December 2009, 06:17   #68
Thanked: 1,269 Times
While this is not so much of a subject while driving modern cars, it still works very well downshifting on bikes. I do it for every downshift on the Bullet, and the whole change goes a lot slicker. And anything that feels slicker saves wear and tear. On bikes the thing to learn is how to use the front brake and blip the throttle at the same time.
Sawyer is online now   Reply With Quote
Old 5th December 2009, 15:30   #69
Rehaan's Avatar
Thanked: 22,604 Times
Sawyer, are you sure your are talking about double-clutching and not just revvmatching?
cya
R
Old 5th December 2009, 16:45   #70
Thanked: 528 Times
Default Winger
I was surprised to know that Tata Winger doesn't have synchomesh and requires double clutching. Is this true?
Guna is offline   Reply With Quote
Old 5th December 2009, 18:25   #71
Thanked: 26 Times
I think he's talking about his thumb and finger technique!
Seriously, has anyone actually done a REAL double declutch. I was around when a firm I worked with took on a batch of the latest TMB 1210A's with synchromesh boxes, moving from the TMB 320A's.
We still did the double declutch drill though: force of habit.
Stripped and fixed about a 100 straight toothed constant mesh boxes, but never got to see the insides of THAT synch box, but worked with plenty others. Would love to see the insides of a Porsche box: they have a different system.
PS I'd be very surprised if the Winger had no synch on any but the reverse gearing.
IT, thanks for the heads up on the 370z. I think the 350 doesn't have that feature.
proton is offline   Reply With Quote
Old 6th December 2009, 06:58   #72
cya
R
My mistake and I am glad to see someone is awake! Rev matching is also useful in cars as an in between technique between the full monty double declutch to not doing it at all. Even with cars with synchromesh on all gears.
Old 6th December 2009, 08:22   #73
I think the sound of a car without synchro being double de-clutched with a little blip of the accelerator properly especially going around a curve is heavenly. This would be particularly sweet if the car was a Ferrari or similar car from the 60s. Of course those were part of the skills a racing driver of that period needed to have as he shifted gears with a non synchro gearbox.
Just an observation from someone who is from an earlier generation.
kuger53 is offline   Reply With Quote
Old 12th December 2009, 11:29   #74
ranjitss's Avatar
Some times I have noticed that even after flooring the clutch pedal on my M800 the 1st gear doesn't engage or is very hard to engage. However through experience I have learn't that if I release the clutch and then again press it the first gear engages as normal. My M800 is a 4 speed 2003 model and I believe it to have a synchromesh gear box.
Can the gurus through some light on this.
Have the other M800 owners faced this too?
ranjitss is offline   Reply With Quote
Old 23rd December 2009, 00:19   #75
navan49's Avatar
Thanked: 68 Times
Some times I have this problem with the reverse gear. Once I leave the clutch little and press the gear it stays in its position.
navan49 is offline   Reply With Quote
Thud Sound from Clutching Action atheistrical 4x4 Technical 6 29th October 2010 18:29
Does clutching save fuel or does more harm than good? skumar69 Technical Stuff 1 5th November 2008 17:55
Double Clutching... how many of us do this? any disadvantages? DaPilot Technical Stuff 2 13th May 2006 00:39
Half clutching !!! gchandra Technical Stuff 1 14th October 2005 12:37
