Old 21st February 2007, 19:56   #1
Default baleno clutch adjustment
hi,
As I am aware the clutch adjustment is done under the bonnet, on the adjuster nut on the clutch lever.
I was wondering if this is the only way or is there one located in the cabin near the clutch pedal.
and what is right way to adjust the clutch
I am not happy with the current settings since this needs to be repeatedly tightened every month.
Kiran
kiranpashtakar is offline   Reply With Quote
Old 22nd February 2007, 10:24   #2
s.prashanth's Avatar
Thanked: 60 Times
Kiran,
adjusting it in the engine bay is the only waty to do it, if your clutch requires constant adjustment, it could be because the cable has enlarged or the clutch is wearing out, I also have a baleno and the adjustment is done by myself whenever I feel a difference in pedal feel
s.prashanth is offline   Reply With Quote
DIY: Drive Chain cleaning & Clutch adjustment gearbox Motorbikes 5 8th February 2016 18:48
Booster Brake Adjustment - Is it possible? mail4ajo Technical Stuff 31 30th September 2015 21:31
Camber Adjustment query & Camber Adjusting Bolts? hell_rider Technical Stuff 18 2nd January 2009 22:43
Day/Night Mirror Adjustment - How does it work? turbofreak Technical Stuff 6 15th November 2007 18:35
Car Headlight Adjustment spacebar Technical Stuff 1 16th October 2006 10:55
