Old 22nd February 2007, 15:24   #1
Question Maruti 800 5 Gear MPFI problem
Hai,
I have a 2003 model M800 5 Speed model. When I start the car after a long time (like in morning) engine speed is normal. But after a little run, say about 2 km, the engine idle speed is very high, we may think the accelerator is pressed. And the Hazard indicator shows some error in engine working .
I showed the car at maruti service station, they told it is some problem with Throttle sensor, and they tried replacing the sensor. but that also failed. Then i showed at a local car workshop and they told it may be because some stuck in the throttle 'float' ( i didnt understand 'float'). What do you guys think ? Please suggest me. I already lost about 4000 rs replacing the sensor..etc.
Anoop
anoovis is offline   Reply With Quote
Old 25th February 2007, 23:15   #2
mithun's Avatar
Thanked: 58 Times
A vacuum leak maybe the probable cause. I assume so.....
The powertrain control module (PCM) will maintain normal idle speed and compensate for a small vacuum leak by closing down the throttle body air bypass. But if the leak is too large and the idle control system cannot compensate for the extra air, the engine may idle too fast. Common leak paths include the throttle body gaskets, intake manifold gasket, any of the engine vacuum fittings, hoses or vacuum-operated accessories. It is even possible that leaky O-rings around the fuel injectors may be allowing air to leak past the seals. Another overlooked item can be a worn throttle shaft.
The important thing to keep in mind about vacuum leaks is that they have the most noticeable effect at idle.
Old 25th February 2007, 23:33   #3
Thanked: 817 Times
Default "Idle" reply??
Idle in MPFI engines are controlled by and Idle Control Valve. In the M800 mpfi this is located just behind the throttle body on the firewall side..well more of less opposing the TPS...it has a couple of narrow rubber pipes leading to it from the air intake manifold.
The Idle Control Valve usually open only when the car is idling...sometimes dirt might get into it...you might try cleaning it at a garage. However in this case i guess you should have problems at the start itself.
I used to have a similar problem when my engine rpm seemed to continuously surge and fall at idle. But switching the engine off and switching it back on usually solved the problem. Later i figured out that it was related to the load perceived by the ECM. I could replicate this by revving the engine up an a low gear and move forward but never completely releasing the clutch.
drive on,
Shibu
shibujp is online now   Reply With Quote
Old 28th February 2007, 10:07   #4
Thank you guys I'll check these out at garage and revert back soon
M-800 mpfi idling problem. kingofmyworld Technical Stuff 12 23rd June 2010 20:14
Maintenance cost - Maruti 800 Carb and MPFI models vinfriend Technical Stuff 9 17th November 2009 12:16
Swift 2nd Gear Problem EDIT: Now first gear problem BUSA Technical Stuff 85 2nd September 2009 18:47
Maruti 800 MPFI problem tj123 Technical Stuff 0 30th March 2009 18:08
