Old 17th August 2005, 15:30   #46
Psycho's Avatar
Thanked: 95 Times
You can turbocharge any engine provided you have a mechanism available to provide more fuel under boost... hence in a diesels case change the pump pressure in reference to the boost. In cases of injected engines you will have to remap the chip's or use a tool like Pete's (this is only for crdi engines).
Old 20th August 2005, 16:02   #47
Turbo diesels need plenty of cool air, so a RAM air intake from the front of the grille is a better idea than stock factory air box setup, also a bigger air filter goes a long way, the other factor is that turbo diesels already are well muffled due to the turbo vanes taking off most of the exhaust boom, so bypassing the muffler gives you HP and mpg gain. The best benefit to all this is that your engine runs cooler as well, almost 10c improvement in most cases.
CRDI engines develop more power but at the cost of reduced engine and pump life due to the extremely high pressure environment, also for the newer reduced pollution CRDI engines, the ring land area has been pushed right to the top and thereby far more stress and lube issues.
To turbo charge a normal diesel engine, lower end stress and EGT is two of the bigges issues, ideally, turbo diesels need enhanced cooling of the pistons so oil squirters are must, also sodium filled exhaust valves are a must for the normal than hotter exhaust, the oil pressure as well as cooling system too has to be enhanced to accomodate the extra heat and lastly, a 10-15% extra fuel is needed from the IP with a boost apparatus for the pump.
Gurkha is offline   Reply With Quote
Old 23rd September 2005, 10:29   #48
Thanked: 22 Times
its interesting to know about turbo engines better than crdi, so do u think i make a right decision to purchase turbo diesel scorpio instead of the crde scorpio
raja_ys is offline   Reply With Quote
Old 24th September 2005, 12:14   #49
BUSA's Avatar
Talking
Nah the CRDe scorpio is more FE slightly and faster by 3 whole secs to 100! More drivable, better torque! What else do you want!
If i am not mistaken its available for a Endeavour
Old 24th September 2005, 12:36   #50
Thanked: 103,372 Times
But its still Mahindra tinkering with new technologies. An insider at a Mahindra workshop strongly recommends the regular Scorpio over the CRDe
Old 24th September 2005, 15:53   #51
GTO,
Good point, remember, the original Scorpio engine is the modded Peugeot XUD series engine by AVL, CRDI technology deals with very high injection pressure compared to IDI and even DI. I would wait for the CRDe to accumulate 60,000 hard driven miles before passing any kind of judgement on it.
Old 24th January 2007, 03:07   #52
Cool How diesel ignites in a diesel engine.
hey all,
I understand that petrol cars have spark plugs to ignite the fuel but what about the diesel cars? How does the fuel get ignited in this can any one help.
Cheers.
WILDTHING is offline   Reply With Quote
Old 24th January 2007, 17:27   #53
khanak's Avatar
Thanked: 130 Times
Originally Posted by WILDTHING View Post
hey all,
Cheers.
In a diesel engine the fuel gets ignited by compressing the fuel
Read more about it here.
Diesel engine - Wikipedia, the free encyclopedia
khanak is offline   Reply With Quote
Old 25th January 2007, 10:59   #54
nikhilv12's Avatar
it is not the fuel that is compressed, it is the air entering the engine, that is compressed. the air is compressed to a very high pressure, and rusults in a very high temperature, then diesel fuel is injected into the cylinder, in the form of a very fine mist, and due to high temperature, it explodes.
nikhilv12 is offline   Reply With Quote
Old 25th January 2007, 11:06   #55
nikhilv12's Avatar
and can anyone tell me, what can i do to my exhaust? i guess putting a free flow mufler, will make a lot of noise, i hav a normally aspirater diesel indica...
Old 6th February 2007, 22:49   #56
Akshay1234's Avatar
Thanked: 7,239 Times
can anyone tell me how i can get more power out of a diesel innova. theres no petes box available and there was some other tuning box but that cost 46k with no power or top speed increase only torque.
Old 13th February 2007, 10:03   #57
nikhilv12's Avatar
there is a petes tuning box for inova... check out their website.... other stuff that can help are better air filters and a free flow exhaust....
Old 13th February 2007, 14:14   #58
Default More Power for Diesel cars
Hi RTech,
How can the powerchip increase the power? I heard it gives wrong signals to the ECU and increases the output. Will it not damage the ECU and reduce mileage?
carlover98 is offline   Reply With Quote
Old 16th February 2007, 16:28   #59
Akshay1234's Avatar
the petes box is not available for the innova.. i will probably put in an air filter. but wont the free flow be very loud?
Old 18th February 2007, 21:09   #60
nikhilv12's Avatar
check this out...
Pete's
it will be louder not not very loud.....
ARTICLE: How to modify a diesel car for more performance GTO On modifying a car 331 13th April 2018 12:17
Turbo? NOS? Engine Swap? High CR NA build? How would you modify your engine? mclaren1885 Modifications & Accessories 61 13th July 2016 15:49
Bought Maruti Gypsy With Toyota Diesel Want to Modify Nahal Modifications & Accessories 15 6th April 2012 22:42
RTO Formalities for Engine change in Kerala (XDP4.9 engine to the XD3 engine) 4x4addict Modifications & Accessories 16 14th April 2009 21:51
