Old 23rd February 2007, 19:00   #1
Default Front window rattle
I bought a Swift VXi in November 2006. Off late when the front windows are rolled down and when i close the doors the windows rattle. This does not happen with the rear windows. What do I do.
Anand_A is offline   Reply With Quote
Old 23rd February 2007, 21:44   #2
bayuin2004's Avatar
there could have been a problem with the holder which holds the glass,just get the side pad opened and get it checked,but i wonder why the windows of both the doors have the same problem
bayuin2004 is offline   Reply With Quote
Old 23rd February 2007, 22:15   #3
Thanked: 111 Times
Originally Posted by Anand_A View Post
Do you have speakers installed in the doors?? If you do, then the window is hitting the speaker magnet when you shut the door. If not, you have to open the panel on the doors & tighten the cords that pull the window up & down.
mb_jg is offline   Reply With Quote
Old 19th November 2007, 01:13   #4
ported_head's Avatar
I had professional quality damping done recently after the Nandi Hills drive, that turned my car from a reasonable orator to a pure audience. Absolutely blissful silence and costed me 3 digits.
Please be giving more details.
ported_head is offline   Reply With Quote
Old 19th November 2007, 13:05   #5
theMAG's Avatar
Thanked: 1,574 Times
What are you wanting?
Old 19th November 2007, 13:11   #6
What you did, to quieten the symphony of multiple rattles in Swift? And that too for cheap?
Old 19th November 2007, 13:13   #7
Thanked: 11,067 Times
costed me 3 digits.
have n't you lost enough already?
Old 19th November 2007, 13:13   #8
srishiva's Avatar
Thanked: 933 Times
just 3 digits !! Give details on what material, where and how much please.
srishiva is offline   Reply With Quote
Old 19th November 2007, 14:03   #9
theMAG's Avatar
A thick contiguous sponge-foam sheet against all 5 door panels alongwith cramming cotton-waste into the cavities of the 5th - the dicky door. Rs. 800.
Got it done from Blueraven
No. You'd be surprised at the power of elasticity.
Old 29th December 2007, 16:07   #10
amit_mechengg's Avatar
Thanked: 1,556 Times
Default get windows regulator assembly changed
same thing used to happen with my alto
get windows regulator assembly changed.....free of cost if in warranty. or around 300-500 bucks
Rattle Removal Buffetfan Technical Stuff 102 30th September 2017 05:59
Power Window Failure? How to manually roll your window up lsp Technical Stuff 36 13th April 2014 15:24
Broken front left door window glass bkm Technical Stuff 2 23rd November 2008 22:00
Swift Diesel - Clutch Rattle at 2000km P1tBull Technical Stuff 14 7th February 2008 11:11
Sound/Rattle Deadening/Damping for front doors of Palio hydrashok Modifications & Accessories 6 27th August 2006 00:32
