Old 24th February 2007, 07:45   #1
moralfibre's Avatar
Thanked: 6,144 Times
Default Esteem Brake problem
Last evening I was driving my friends '98 Esteem VX and noticed a weird problem with it. I was at a traffic light, resting my leg on the brake pedal, suddenly I noticed slight and gradual movement of the brake pedal downwards. And after an interval, the brake pedal was completely down and the brake wasn't holding the car until I let go the pedal and pressed it again (Just like we pump the brakes sometimes).
I got scared to drive the vehicle thinking the brake booster has gone for a toss and is not holding the pressure down. Tried to brake slowly while driving and noticed that the pedal went dead if I slowly pumped onto the brake. Pulled over to the side on an empty strech of road and tried to brake hard and the brakes worked. The brakes are working absolutely fine when I dont mildly push the pedal. If I have to use the brakes I need to brake hard and the car works. I did not observe any loss in braking efficiency when I used "pump the brakes method".
Could someone please help me with rectifying the problem before I take the car to a service station. My stupid friend has been using the car saying this is normal behaviour and I dont buy that. The brake pedal going down completely is an issue and this happens at idle and also when the car is in motion. The car has new brake pads in the front as well as the rear and they have been used only for 3000 kms.
Old 24th February 2007, 09:27   #2
viper's Avatar
You may have a vaccum leak somewhere in the brake system most likely the booster. Please tell your friend to have it checked as it may be dangerous.
Viper
viper is offline   Reply With Quote
Old 24th February 2007, 09:53   #3
moralfibre's Avatar
Originally Posted by viper View Post
How do I perform a leak test on the booster? Any pointers? I would like to check it myself before I hand it over to the service guys.
Old 19th March 2007, 11:49   #4
moralfibre's Avatar
Due to sheer negligence and poor maintainence my friend did not get his brakes checked, result was a brake failure on Saturday.
He got the entire brake booster assembly replaced for Rs. 3600/- and I asked him to get new oil and pads too. Finally the brake problem is fixed and we feel confident driving the car!
Old 19th March 2007, 12:10   #5
nitrous's Avatar
Thanked: 282 Times
The same thing has happened to my Sumo, a couple months back.
And yes, it was the booster.
What I dont understand is when the brakes are ineffective,why isn't the brake warning light on the instrument panel coming up?
Old 19th March 2007, 12:13   #6
moralfibre's Avatar
The brake warning lamp lights up only when the brake fluid goes low on the car. Wish manufacturers hear you nitrous!
Old 19th March 2007, 12:15   #7
esteem_lover's Avatar
Thanked: 445 Times
That lights up only when there is shortage of brake oil. Come on, nitrous, this is not a merc.
Brake fluid/Parking Brake Indicator light- Is this a problem? santosh.s Technical Stuff 10 7th June 2017 14:02
Paint for disc brake pads & rear brake drums VC12 Modifications & Accessories 8 25th October 2011 17:18
Disk Brake to normal brake change? ramki067 Motorbikes 10 7th August 2008 14:19
Only brake OR clutch+brake swiftcrazy Technical Stuff 8 10th July 2007 23:19
Which is the right Sequence Clutch-Brake Or Brake-Clutch ankura12 Technical Stuff 2 9th July 2007 10:02
