Old 25th February 2007, 13:34   #1
rahul_intlad's Avatar
Default Idling at signals,traffic jams
There have been threads regarding fuel consumption at signals and things like that, but I did not get whether we should let the engine idle at signals or turn off the engine in terms of damage to the engine.
In cities like pune the signals are not synchronized in many places and you keep getting a red at every intersection once you get a red at any intersection.This results in frequent switching on and off the engine.Also my driver keeps switching off/on the engine even in traffic jams.
Kindly advice if chances of damage to the engine are too large to offset gains in fuel saved.
rahul_intlad is offline   Reply With Quote
Old 25th February 2007, 13:41   #2
theMAG's Avatar
Thanked: 1,573 Times
Thumb rule - if the stoppage is for more than 30 secs, engine should be switched off.
Old 25th February 2007, 13:48   #3
Lets take two intersections maybe not that far apart,after switching on/off the engine at this signal,i reach the second intersection and find a red there too,now should i apply the 30 second rule here too.
Old 25th February 2007, 14:45   #4
theMAG's Avatar
This thumb rule applies to distinct stop/start situations and not where one set of stop/start seamlessly merges with another. In which case its better going on horseback anyway.
Nothing prevents a car from being switched off/on frequently except for the prospect of a blown starter.
Old 25th February 2007, 17:17   #5
danlalan's Avatar
Thanked: 135 Times
most traffic signals here have a wait time of over 120secs...usually we dont put the car off..the car idles with the a/c on or off...even in traffic jams..the car is kept on...unless your the first one at the signal and its over the above mentioned time then it is wise to switch off.
danlalan is offline   Reply With Quote
Old 25th February 2007, 17:36   #6
revtech's Avatar
Thanked: 35 Times
but while idling for a car that gives around 12 km/l what would be the fuel consumption per min while idling(with ac off)
Rev
revtech is offline   Reply With Quote
Old 26th February 2007, 01:05   #7
paras211's Avatar
Thanked: 57 Times
multiply the time i mean if u get 12kmpl at 4000rpm and if it takes 40 seconds for a km so 4 X 40 160 seconds
paras211 is offline   Reply With Quote
Old 28th February 2007, 16:53   #8
As per Maruti website, idling for a minute is equivalent to 1 km ride (doesn't say whether a highway ride or city), so if you idle for 12 mins, you'll burn out 1 litre of fuel.
Actually, I don't agree with the 1st statement. Let's say you put the car in 5th gear, and the road is leveled, and silk smooth, and your rpms are very modest (almost like idling), your speed would then be close to 50 kmph, which covers 0.833 km per min. So, if your car gives 12 kmpl, your idle time for 1 litre is 14 mins, not 12.
amu1983 is offline   Reply With Quote
Old 28th February 2007, 17:07   #9
I am not sure if this would apply for turbo charged Engines as the manufacturer recommends that the Engine is allowed to idle for a minute after every start.
arun_moorthy is offline   Reply With Quote
Old 28th February 2007, 17:38   #10
Equus's Avatar
Thanked: 169 Times
Hmm, I switch off only when its close to 90 or 100 seconds or so. Not the right thing, it seems like from this thread..
Equus is offline   Reply With Quote
Old 1st March 2007, 01:16   #11
mfb
I switch off when it's more than 60 secs and am not the 1st one in the que. The thread seems to talk about 30 secs.....isn't that amount of fuel be spent in restarting the car.
Let's hear the biggies.
mfb is offline   Reply With Quote
Old 1st March 2007, 01:38   #12
revtech's Avatar
Thanked: 35 Times
i just wanted to know how much fuel is used while idling. i NEVER turn my car off even if its close to 120 seconds cause i need my car on for my ICE to run smoothly.
Old 1st March 2007, 02:36   #13
rohitbagai's Avatar
Thanked: 226 Times
Arrey ...How come? Consider factors like while car is running engine has a load of its body weight, passengers, Wind thrust etc..etc. While engine is idling its virtually load less. So it will consume proportionately far less fuel.
rohitbagai is offline   Reply With Quote
Old 3rd March 2007, 00:15   #14
elf
elf's Avatar
Thanked: 9 Times
Easiest way to find out? Drain your gas tank completely, add a litre of fuel to it post that & then time it to see how long before it runs out.
elf is offline   Reply With Quote
Old 3rd March 2007, 07:16   #15
I never switch off the engine at traffic lights, jams etc. The A/C is always on in my car.
hrag is offline   Reply With Quote
Awful Traffic Jams from around the World nishantgandhi The International Automotive Scene 29 10th October 2015 02:09
GreenLight: Reduce traffic jams by eliminating 'right turns' at signals D4D Street Experiences 47 6th November 2014 09:40
VIP's and Traffic Jams kiranpashtakar Street Experiences 32 12th August 2014 16:57
Delhities beware: Surprise Autorickshaw strike can cause massive morning traffic jams sidindica The Indian Car Scene 16 17th August 2009 17:37
