Old 27th February 2007, 16:50   #1
Thanked: 75 Times
Default Indica Turbo --Screeching sound while starting??
I have an Indica Turbo since 2006 Jan.Off late i have observed twice or more,while starting the car a screeching sound comes for a minute and then disappears.No problems with the car or the drive.
Anybody else had had this problem?.Is the Indica Turbo a good vehicle in the long run?. Another question i have is can i leave the car unused for a long period(> 6 months).The last time i left it unused,the battery went dead.
werfish is offline   Reply With Quote
Old 27th February 2007, 17:20   #2
tsk1979's Avatar
Thanked: 16,422 Times
The alternator belt is slipping.
If you go to service center they will say its not.
so do what I did.
Record the sound on your cell phone and play it very close to service advisor's ear at full volume, that convinces them that it really screeches.
As for long periods, use search thread function, there is an entire thread about long term storage.
Old 28th February 2007, 16:04   #3
Thanked: 127 Times
Ditto with my Swift. However, during one emergency service (Battery Dead), the service guys from Pratham noted this, and they changed the alternator postion(which by design can be moved by adjusting a nut), from then onwards, I have yet to hear the Screeching sound while starting.
Hope this info will help you.
regards,
-manju
manjubp is offline   Reply With Quote
Old 28th February 2007, 18:09   #4
Originally Posted by werfish View Post
Did you or nyone grease the belt by any chance? if yes than try washing it with mild soap and warm water and let it run for a while and ensure that no lubricant ever is used on the belt.
pujaari is offline   Reply With Quote
Old 28th February 2007, 18:42   #5
Thanked: 75 Times
No.I havent done any greasing on it.Could it have been done by a Rat?.I have lots of Rats around the car at night.
Old 1st March 2007, 00:51   #6
Zappo's Avatar
Thanked: 2,081 Times
Oh my god... I just now read another gobbledygook about rats moving the alternator belt of a new skoda! Please... rats may gnaw at things but they do not do weight lifting and stuff.
werfish... its ok. A regular with many cars... this particularly happens on wintery mornings but otherwise also... once the car warms up it vanishes. When you take it for the first service tell them the problem. They will tighten the belt and the sound will vanish. It happened initially with my car as well but once it was tightened the problem vanished. Its no big deal.
Zappo is offline   Reply With Quote
Old 1st March 2007, 15:09   #7
mail4ajo's Avatar
Thanked: 261 Times
I had this issue for a while. What my brother did was poured little water on the belt for a few days and it disappeared. The belt might have expanded due to the heat. Not sure if this will work for you.
mail4ajo is offline   Reply With Quote
Old 2nd March 2007, 22:29   #8
Thanked: 75 Times
How do i locate this belt?
Old 4th March 2007, 14:18   #9
tsk1979's Avatar
Open the bonnet, stand in front of right headlight, and look down. You will see two pulleys and a belt. Its right next to a the timing belt which is covered and cannot be seen.
If you lean down on the right side of the vehicle then also you can see the pully. Its pretty visible.
Brake Pads "cheen-cheen" Screeching Sound While Braking vebmetal Technical Stuff 74 16th February 2013 07:26
Figo's screeching sound (and some other problems) solved! anilisanil Technical Stuff 7 4th September 2010 00:10
Screeching sound in Santro while turning Lalvaz Technical Stuff 8 26th June 2008 13:35
Screeching sound while steering Vinay DL Technical Stuff 4 28th November 2007 10:32
screeching sound from the rear while going over bumps... amitverma Technical Stuff 16 30th August 2005 14:29
