Old 23rd June 2013, 19:26   #136
Thanked: 59 Times
Default Re: What's a free flow exhaust ?
Originally Posted by shelleve View Post
Hi All,
I couldn't find any information about this through my search on tbhp. Mods please move this post to correct thread if I am posting it i a wrong thread. I have a polo 1.6 and the engine is very sluggish and I thought going with the basic mods i.e. a CAI and FFE will add that extra punch which is required. However, one question about FFE which I would like to ask is the O2 sensor. In Polo the O2 sensor is placed at the conjunction of all the 4 pipes coming from the cylinders. Now if I choose to go for FFE with 4X2X1 where would the O2 sensor be put. A lot of people mentioned that for them it was placed on 2nd cylinder or 1st cylinder, but thats not the right way of doing it. Is it? As that would cause some cylinders to run lean/ rich. Also if I put the same at the cross section where are the 4 exhaust pipes meet then will it not be too far from the cylinders, as the O2 sensor works on the exhaust gas temperature to trigger a voltage. Also, after installing FFE what will happen to the pollution check which I have to get done in Delhi, would that be hampered? Not really sure if my facts are correct here, but some guidance would be great. Also, please guide which FFE is the best, and where can I get it done in Delhi?
Your doubts are bang on, shelleve!
Positioning the o2 sensor in any other fashion than the aoem fitment is guaranteed to sense not the best readings for oxygen content in ex gas. So you are guaranteed to get lower efficiencies. Infact I am also running my GETZ on one with the lambda sensor on just one cylinder. My modifier shabber had already made one out for me and I did not gabble him with my lambda sensor knowledge and spoil his day!
And you rightly put it, all the AOEMS in euro 4 are running close couple cat cons for the only reason to get fast operating temperature for the thermocouple, they are all using zirconium catalyst for sensing oxygen! So positioning the lambda sensor in downstream is only going to delay the o2 signals to engine ECU and allow the engine to run on its standby logic which again deems that your combustion efficiencies go for a toss.
Passing Indian exhaust norms is a breeze, it still certifies u an euro 2, with 0.05% CO and 750 ppm HC which is a pity! Even my Carb ZEN passes it . So no worries on it!
gopa99 is offline   (1) Thanks Reply With Quote
Old 27th August 2013, 18:09   #137
Dodge_Viper's Avatar
Thanked: 461 Times
Hi Guys
My i10 is under warranty till 2014 hence I am avoiding to go for the entire FFE system since it will void the warranty.
Is it fine if I add just the muffler? (only for sound)
I agree that performance gain would be zero. But if I go in for muffler alone, will it void warranty?
Dodge_Viper is offline   Reply With Quote
Old 27th August 2013, 22:23   #138
tharian's Avatar
Thanked: 2,712 Times
Originally Posted by Dodge_Viper View Post
Hi Guys
Any part replaced or that is added and is not a OEM part will void warranty .
Warranty will come into picture when something goes wrong and the A** will connect that issue to a part which you have replaced or added which in reality is not even remotely connected .
My suggestion would be go for it. I got the exhaust and cold air intake done when my car crossed 10k kms and just over a year old.
Make sure you get it done at a reliable place.
tharian is offline   Reply With Quote
Old 7th October 2013, 18:01   #139
LOL_FWD's Avatar
Thanked: 154 Times
Hey fellas!
Can somebody tell me where exactly i can find information about the FFE? An E-Book or a website?
Information in the sense, the A-Z of how the FFE works, the pressure drop involved, thermodynamic changes, fabrication calculation etcetra?
I'm a final year mechanical engineering student and planning on building one of my own. From designing on computer to fabricating and then maybe testing (On a dyno probably)
Thank you in advance.
Cheers!
LOL_FWD is offline   Reply With Quote
Free flow exhaust!!! shalini_g Modifications & Accessories 1 27th June 2006 11:23
free flow exhaust muffler for ohc club_honda Modifications & Accessories 23 14th June 2005 04:10
Free flow exhaust tuner in Pune chetanhanda Modifications & Accessories 5 5th May 2005 16:10
free flow exhaust sanket12 Modifications & Accessories 4 29th June 2004 20:09
K&N Filter and Free flow exhaust gbharani Modifications & Accessories 2 19th April 2004 23:46
