Old 5th November 2007, 09:46   #61
jerish666's Avatar
Originally Posted by revvedup View Post
once i had met someone who had modded his skoda octi tdi and asked him whether he had a free flow exhaust or not .He replied that he had not installed it because it would foul with the turbo in the car.I supose that the same may be true for the verna also since a turbocharger is driven by exhaust gases and though turbos have pressure cut off valves ,free flow exhausts increase exhaust gas velocity and this may not be tolerated by the turbos vanes especaille because it is variable turbo.Do this only with the help of an expert otherwise you will ruin your verna.
I already fixed Milltek Sport CAT-BACK - Non-Resonated in a skoda 1.9TDI here in Trivandrum(kerala).That skoda is having 125BHP,done 25000kms.I fixed the exhaust when his car was 3600kms.Still it doesnt have any problems.It is a fully moded skoda including front mount intercooler and changed the suspension also.So i dont think so it will foul with the turbo.
jerish666 is offline   Reply With Quote
Old 7th November 2007, 21:50   #62
yasw_anth's Avatar
free flow exhausts affect the engine on the long run ??
yasw_anth is offline   Reply With Quote
Old 7th November 2007, 22:21   #63
jerish666's Avatar
I dont think so it will affect the engine on the long run.
Old 8th November 2007, 00:43   #64
rohan_fonseca's Avatar
FFE would actually be beneficial to the engine in the long run if designed properly. Although not so good for the environment.
rohan_fonseca is offline   Reply With Quote
Old 8th December 2007, 10:57   #65
narayan's Avatar
Thanked: 1,339 Times
Default free flow exhaust maintenance
is there any specific maintenance required for the FFE ? how often does it need to be decarbonised ? i presume more often...
anything else to be done to keep the FFE at its performance best ?
i plonked a automech unit on my OHC 1.5 about 5-6 months back...
im already seing a drop in the response from the initial days - could also be a matter of "just having got used to it " syndrome....
but is there anything on the maintenance to be done ?
narayan is offline   Reply With Quote
Old 9th December 2007, 01:24   #66
@Narayan: Check air filter, throttle body if cleaning is required
. Reset ecu and see if there is improvement in performance. Keep an eye on the tyre pressures as well.
Old 25th December 2007, 17:03   #67
can i have RAC adress in Blore
sajurchristy is offline   Reply With Quote
Old 3rd August 2008, 22:42   #68
if free flow exhausts are available for diesel swift, where can i get it ?
and for what price ? is it available with the automech,i have asked many peoples about this so need best information!! AS SOON AS POSSIBLE!
CAR_GOD_666 is offline   Reply With Quote
Old 4th August 2008, 01:51   #69
Thanked: 17 Times
You don't need a complete free flow exhaust in a Diesel Swift because, it's got a Turbo inside.
You may try fitting an end can for some Purr Purrs! But not worth it in my opinion.
Old 4th August 2008, 03:02   #70
Shan2nu's Avatar
Thanked: 89 Times
The diesel swift would do much better with a petes box than intake and exhaust mods.
Shan2nu
Old 4th August 2008, 18:00   #71
Post Deleted by the Team-BHP Support : SMS / Slang is STRICTLY prohibited on this community. We would much appreciate your using full & proper english in posts, for the benefit of other forum users.
Please view our board rules carefully before proceeding any further.
CAR_GOD_666 is offline   Reply With Quote Received Infraction
Old 7th November 2008, 19:24   #72
ankitahuja's Avatar
Thanked: 46 Times
Posted this question in a different thread but got no replies. Hope someone will answer:
Can someone give a detailed explanation on what exactly is the role of the Mid Muffler AND Expansion Chamber in an FFE set up.
Is one of them used in place of the other or how does it work?
Old 20th November 2008, 00:40   #73
zerocritical's Avatar
Can someone pls tell me where is the best FFE jobs done in either Hyd or Blore? What would be the approx cost of FFE with fitting for my Swift Petrol?
zerocritical is offline   Reply With Quote
Old 25th November 2008, 10:55   #74
MudMover's Avatar
Thanked: 42 Times
Default Poor man's free flow?!
I had a query regarding the re/configuration of the tail end of the exhaust on my Estilo. The below are the snaps of the same. What I want to know is... will sawing off the pipe at the point marked, help in 'freeing the flow' in any way? Will it affect the aerodynamics of the car? Will it help in anyway
ATTACH]73476[/ATTACH]
MudMover is offline   Reply With Quote
Old 25th November 2008, 12:07   #75
Akshay1234's Avatar
Thanked: 7,239 Times
nope. it wont help you in any way.
Free flow exhaust!!! shalini_g Modifications & Accessories 1 27th June 2006 11:23
free flow exhaust muffler for ohc club_honda Modifications & Accessories 23 14th June 2005 04:10
Free flow exhaust tuner in Pune chetanhanda Modifications & Accessories 5 5th May 2005 16:10
free flow exhaust sanket12 Modifications & Accessories 4 29th June 2004 20:09
K&N Filter and Free flow exhaust gbharani Modifications & Accessories 2 19th April 2004 23:46
