Thread Tools
Old 5th March 2007, 09:48   #1 (permalink)
Default giving new life to my indica
hey bhpians,
inspired by our fellow bhpian sam kapasi, who gave a good treatment for his lancer on completing 4 years:
http://www.team-bhp.com/forum/techni...tml#post359826
me too want to give a nice treatment for my indica.
here are the details of my indica:
  • 2003 indica V2 DLS,
  • odo: 54,000 km,
  • tyres: stock tyres nearing their end,
  • wheels: stock rims,
  • servicing done at 52,000 km with wheel allignment and wheel balancing; replaced front brake pads.
  • ICE: pioneer DEH-P7450MP, 300W coaxials in the rear, 100W in the front.
  • FE: 14 kmpl with AC(70-80%) in the city, 19kmpl with AC(90%) on highway.
  • headlights: stock.
  • no-fog lamps.
  • full body paint job in dec. 2006.
here are the things which i am looking forward to do:
  • tyres: upgrade to a set with out hampering the ride, comfort and Fuel Efficiency.
  • wheels: change to alloys after all the things are done just before selecting the tyres if the moolah permits.
  • there are some creeking sonds comming in the rear may be from the deck lid, want to fix them.
  • there is a play in the transmission, want to rectify it.
  • there is a slight sound from the front, figure it out whether its from the suspension or its the same problem as the previous one and fix it accordingly.
  • Performance, didnt quite like it in city driving with AC in the first and second gear, would like to increase the low end pulling power. So what will help?? Performance filter or porting or polishing might help with out comprosmising on the fuel efficiency. May be upgrading the fuell injectors might help. (does this help, with out decreasing the FE??)
  • liquids: guys need your help here.
  • oil flushing, go for semi-synthetic oil. (can i go for it for a deisel)
  • ICE: add an amp, a sub and a CD-changer if the CD-changer can support MP3 playback; put an external radio antenna.(manual)
  • the paint job was the poorest of all, may i can do a better job!!, will beat the $*it out of the service center guys and get it re-done.
  • there are some scratches around fix them up.
  • not happy with the current set of headlights, upgrade them too.
  • the current floor mats are not covering the entire floor properly, so change them too.
  • underbody anit-rust treatement.
  • clean the interiors with shampoo.(i think there is a 3M treatement for it)
  • fog lamps, never thought we need them here in our place. but yesturday, we were almost hit by an octavia comming in the wrond direction on national highway.
If I have missed anything, i could look into, please let me know guys.
Also can I know the costs involved for the total treatement. For the alloys and tyres, not looking for anything this great looking or stunning thing, for me its function preceeds style.
kkr2k2 is offline   Reply With Quote
Old 5th March 2007, 09:58   #2 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Here you go
1. Tyres: Potenza GIII 185/60R13. Perfect upgrade. No speedo errors, no problems, perfect functional upgrade. If you don't want directional, Goodyear Ducaro is a good tyre, don't know wether they make them now. Stick to 13 inchers.
2. Rear seat creaks. Get that checked.
3. Gear lever bushkit get worn out around 40-50K, you will have to get that checked. Ditto for the clutch cable.
4. Get the ball joint(Steering checked), its two of them R and L. Another culprit could be engine bedding, or fan bearing.
5.Nothing much can be done for performance, the only minor mod is a performance filter and/or free flow. Fuel pump setting also plays a major role.
6.Castrol edge will cost you around 2200rs. You can go for a higher grade mineral oil (API-CG,CH,CI instead of API-CF). Cost will be around 700rs. BP(MAK) makes an API-CI oil but not available easily
7.Go for 100/90 with Relay. Narva is good if you want white light, otherwise go for Osram silverstar or hella gold(these give yellow light though)
8.Interiors : Get them dry cleaned. Cost=500rs.
9. Fog lamps will not take care of octavias, for that buy a tempo traveller. Get OEM ones if you need them. I guess yours is the indica which has fog lamp enclosures
__________________
Old 5th March 2007, 10:29   #3 (permalink)
wolfinstein's Avatar
I agree with Tsk for the Potenza G3(Tubeless), They will serve well with your new alloys.
If you don't want to splurge too much on the Engine Oil, Rather go for GTD Magnatec from Castrol which is Semi-Synthetic and will cost around 800 for 4 Ltrs.
The Rear Parcel Tray can be replaced with an MDF wooden tray so as for a perfect fit, No squeeks anymore..!
New Mats will cost around 300, Just bought mine a few weeks back.
Also Along with Engine Flushing, Replace the Plugs, Brake Oil, Transmission Fluid ( Once you get the Play Rectified)-If these have been done on your last service you may leave it.
Also Get the Throttle Body Cleaned. And get the Fuel Tank Cleaned along with New Fuel Lines( Only if you suspect the quality of Diesel + have been driving too much on Highways)
Brake Pads changed and Disc Polished.
I agree normal Foglamps from Minda OEM will cost around 1000 and are pretty sufficient.
For Performance mods you could go for a Free Flow Exhaust System which will be in the range of 8000-12000, KN Filter ( I don't know if it will improve performance or not).
For Body Mods, You can replace the Headlights+ Taillamps with the New Indica V2 2007 Model, Even the Bumper is a direct fit with the New Mesh Grill and Sleek Look. This should cost around 7 K.( The clear lamp of the New Headlights will improve the Light dispersion and Brighten things better + Look better too, Same goes for the Tail Lamps they appear better and brighter)
@ Tsk, Sir When we do have the Next Meet in Delhi- Can I check out the Narva Lamps.
__________________
" When was the last time, You did something for the first time "
wolfinstein is offline   Reply With Quote
Old 5th March 2007, 11:21   #4 (permalink)
Here you go
Originally Posted by wolfinstein View Post
....If you don't want to splurge too much on the Engine Oil, Rather go for GTD Magnatec from Castrol which is Semi-Synthetic and will cost around 800 for 4 Ltrs.
.... replace the Headlights+ Taillamps with the New Indica V2 2007 Model, Even the Bumper is a direct fit with the New Mesh Grill and Sleek Look. This should cost around 7 K.( The clear lamp of the New Headlights will improve the Light dispersion and Brighten things better + Look better too, Same goes for the Tail Lamps they appear better and brighter)
thanx a ton tsk and wolfinstein.
Castrol...., is it made of castor-seed-oil ???
yes, i wil go with a new head-light set with that of the new indica v2. thats what i have been adviced by the service advisor too.
its a deisel my dear friend, with a free flow, wont it scare $*it out of everybody also will the car run clean with a freeflow w.r.t pollution.
any idea about the cost of the potenza tyres mentioned above?? i have been thinking about JK, as the current set lasted for 54,000km.
also the suitable alloys, plain simple alloys, no bling bling at all.
Old 5th March 2007, 11:43   #5 (permalink)
Castor Seed..! I really Don't know..lol
Ya the lights will go good, But replace the tail lamps also ( BTW which lights are you going with The V2 Clear type or the v2 2007 Clear Jewel Type, Also Since they will have the Headlight Adjuster system, You will need to install the switch and wiring to your dashboard, Or you can leave it set at one level)
Thats for you to take a call on..! ( Free Flow)
Potenza G3 tyres are great for all weather conditions and are tubeless so Almost no punctures ( I have G3 Tubeless in my Lancer, with 1 puncture in 1.6 years @ 12000 Km after new tyres) Infact once the Apollo wear out on my Indica XETA, I will also go for Potenza G3 and New set of alloys..something like this..! ( This is a Modded Indica done by Arush-Autopsyche) The alloys look great..!
On the pricing, The Potenza G3 costed me Rs 4000 +- @ 5 Tyres minus Discount on old tyres, but that was in 2005, I don't have the current price, TSK might provide you that bit. ( Mine were Tyres for the Lancer Sports-I'm sure they are priced much below for the Indica)
__________________
Old 5th March 2007, 12:20   #6 (permalink)
...BTW which lights are you going with The V2 Clear type or the v2 2007....
....The Potenza G3 costed me Rs 4000 +- @ 5 Tyres minus Discount on old tyres,
yes, castrol buys castor oil but dont know whether it is used as the main ingrediant. I heard from a three wheeler manufacturer that it is the best lubricant.
will be going for the headlight which comes with out the leveler. i think 90/100 is the best one, because on the highway with heavy vehicles comming in you will be blinded partially.
just 4000/- for 5 used tyres??? , man i think i must seriously look around for those.
how many kms were done by those before you bought them?
I am looking to run the indica for another 20,000 to 30,000 km before upgrading to a sedan.
Old 5th March 2007, 12:36   #7 (permalink)
The Headlight leveller is a motor fitted on the Lamp assembly itself, I think Post 2005 It was not available in the clear type lamps, But after BS3 norms it is made standard and enforced by Law, The 100/90 you're talking of is the Wattage Power of the Bulbs, I suggest you get New Headlights and Upscale the Bulbs accordingly, But do keep in mind the more powerful bulb you have the more Haziness risk for your new headlights and the oncoming traffic will have difficulties + Law recommends 60/55w bulbs.
The tyres now, It costed me Rs.3760(After Discount, Otherwise 4000 per tyre) for each tyre ( I bought 5) and I got around 1200 rupees off for my old tyres( 5 old Bridgestone OEM Potenza)
So I paid Rs.18,800 for 5 new Bridgestone Potenza G3 Tubless with 2 Free Balancing and Alignment Service for One year.
The OEM Bridgestone on my Lancer lasted us 50,000 Km with no issues except punctures post 30 K mark. I have been using Potenza G3 on the Lancer now for around 1.6 years and 12,000 km with No issues.
Bridgestone makes great all road tyres, although they become noisy at around 35,000 KM Tread mark..! But It really does not work as a disadvantage for the Superior performance they give..!
__________________
Old 5th March 2007, 13:48   #8 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Castrol is mineral oil.
As for magnetic, its API-CF, not the API-CG which many other brands have, like shell.
but since its magnetic, its supposed to be good for engine as you escape morning start damage.
As for bridgestone tyre noise, anybody who worried about tire noise on an Indica needs help.
As for potenza's they will cost you 4000/tire. You can get around 300rs discount/old tire.
As for free flow, it will make quite a din,but you get more power right. There is no free lunch so lose some and win some.
About the narva's you can check them out, but I suggest go to a dealer, fit various brands and see what is best for you.
My indica has fresnel type headlamp glass(non clear) so what works for me may not work for you.
For more tips, there is an auto lighting thread which has loads of info.
__________________
Old 5th March 2007, 14:10   #9 (permalink)
nitrous's Avatar
@Wolfinstein: Dude, dont take this the wrong way.
But, u dont know the difference between petrol engines and diesel engines and u're giving advice!
Pls dont make the mistake next time,bro.
__________________
Maruti - Everyone comes home with rattles!
nitrous is online now   Reply With Quote
Old 5th March 2007, 22:32   #10 (permalink)
@ Nitrous..! Sorry Bhai..what I meant was Glow Plugs..! and The Throttle, I don't know if it does exist in a Diesel,,I thought it must be generic..!
My Uno D have something Similar to the Throttle so thats where the confusion was..! But I guess Kk got the point..!
Of course I do know what a D and P engines are..! Just not all mechanism of the former..! lol
Hey Kk do post us the pics once you finalize everything..!
__________________
Old 6th March 2007, 08:39   #11 (permalink)
Team-BHP Moderator
tsk1979's Avatar
Why change the glow plugs if they are fine. All they do is heat up engine before start, and if they are fine, let them be. Usually they last around 50K and die slowly. There is lot of indication by way of longer cranking etc.,
__________________
Old 6th March 2007, 08:42   #12 (permalink)
....Law recommends 60/55w bulbs.
is it illegal for a indica to use 100/90 W bulbs, service advisor at autofin advised me to go for 100/90.
Old 6th March 2007, 09:22   #13 (permalink)
Su-47's Avatar
Hey tsk, What is this discount? Do we get this only when there is some life left in the tires?
Thanks,
Su-47
__________________
Never wrestle with a pig, for if you do, you will both get dirty, but the pig will enjoy it - Charlie Munger
Su-47 is online now   Reply With Quote
Old 6th March 2007, 09:48   #14 (permalink)
Team-BHP Moderator
tsk1979's Avatar
100/90W is illegal as per Indian law. Infact these bulbs clearly mention(if they are from reputed manufacturers) that these are not street legal. But many people get these.
Thanks,
Su-47
Unless your tires are completely bald you will get around 300/tire for your old tires.
__________________
Old 6th March 2007, 11:29   #15 (permalink)
Default bakra kisthon mein katenga
ok guys,
thats a long list of things to be done on my car. breaking the things-up into small jobs.
first part starting from tomarrow.
first, getting the gear shift bush-kit checked and also the head light thing, shall go for the clear-lens lamp indica v2 headlight assembly. will go for 60/55 as 100/90 is said to be illegal. shall put the pics of new headlights
@tsk,
why did you mention clutch cable in the same point as the gear level bush-kit. can it could be the culprit too.
i think the ball-joint also needed to be checked, as i see the steering is tilting towards the left.
one more thing, few months ago, there was a coolant leakage, took the car to a reputed local repair guy, first his assistant checked some housing saying the housing has to be replaced later the master said it can be fixed - tightened some screws, voila no more leakages till date, but he commented, the screws cannot be tightened if it happens again. But would like to get that checked too.
Thread Tools
Ferrari/Shell giving out free stickers! lamborghini Shifting gears 75 31st March 2008 19:15
Retrofitted AC giving problems rahul_intlad Modifications & Accessories 6 8th December 2006 14:47
HELP - Palio giving low FE and poor performance (1.6) lamborghini Technical Stuff 0 17th June 2006 18:03
What discounts are Hyundai giving? ajmat The Indian Car Scene!! 19 10th September 2005 22:15
Giving NFS 5 a new life......... Shan2nu Shifting gears 5 10th November 2004 04:49
Powered by vBulletin
Copyright ©2000 - 2008, Team-BHP.comAd Management by RedTyger
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
