Old 17th August 2014, 19:51   #16
Thanked: 14,602 Times
Originally Posted by IndigoXLGrandDi View Post
When the throttle was twisted more than 3-4 mm the engine would die. The engine needed some time to be stable. I would give throttle 2-3 mm (Approx) and gradually increase it depending on the behaviour of engine. If I feel that the Engine would be remain alive if the throttle is increased to 5-6mm, then I would slowly do the same. Then if I feel that engine has really awaken (this would take around 1min), then I would set off.
Looks like the petrol isn't reaching the combustion chamber with no throttle input.
I think this problem has got solved. But still keep watch on this and update.
The problem got solved on its own?
Anurag.
a4anurag is online now   Reply With Quote
Old 19th August 2014, 22:46   #17
IndigoXLGrandDi's Avatar
Thanked: 161 Times
Default Cold Start trouble in Scooty Pep.
This behaviour is only when the engine is cold. Once the engine is run for 1-2 kms, no starting problem arise after that.
Any solution on this? How to troubleshoot further?
Sorry, the problem is still there.
IndigoXLGrandDi is offline   Reply With Quote
Cold start vs warm start, is there a difference? Shan2nu Technical Stuff 6 18th May 2010 18:32
help me choose for 60% highway use 40% city use nawabnabeel SUVs, MUVs & 4x4s 43 7th April 2009 17:48
Driving with choke on - what damage can occur? archat68 Technical Stuff 9 13th December 2008 09:48
Four Choke to death in car DCEite Shifting gears 37 13th September 2006 20:31
Let me start my jeep... hianooo Introduce yourself 21 14th October 2004 11:15
