Old 9th June 2007, 12:40   #16
Ricky_63's Avatar
Thanked: 394 Times
What is the total pie dia (double or single).
If you increase the pipe dia, you will get horsepower gainst esp at high rpms
If you increase the velocity(less pipe dia) low end torque gain is there.
Most cheap exhausts are designed for horsepower gains and making one for torque gains is a little more difficult.
If you use too wide an exhaust, it will rob you of low end torque(something to do with backpressure).
So in the end dual exiting or single exiting exhaust does not matter, all that matters is the exhaust velocity.
If gas flow area of single and dual are same, you will have same characteristics. Dual/single no difference if velocity is same.
The low end on my lancer is pretty low inspite of custom headers from Automech - how can I increase the torque at lower RPMs ?? I have a 4x2x1 setup for the FFE with a relatively silent exhaust note - the exit pipe is a twin 1.5" as is visible in my gallery. Any suggestions???
What is the advantage of Alloy Wheels? sbasak Tyre & Alloy wheel Section 12 11th May 2013 10:50
Loud Pipes face the Axe manson Superbikes & Imports 42 28th April 2013 09:03
Whats This- Pipes on a BEST bus?? Revvhead Commercial Vehicles 7 29th June 2006 18:13
lancer petrol or opel astra advantage?? nd4spd Sedans 3 28th December 2004 00:33
