Thread Tools
Old 12th March 2007, 17:55   #1 (permalink)
manikjeet's Avatar
Default Fuel guage needle going up and down
The fuel guage of my Alto lx has been playing some tricks lately.While i am driving or take a turn or a car goes over a bump the needle suddenly dip down and then slowly goes up again to the same level.
Once the needle was below the reserve and filled her with 500rs petrol and the needle went way up more than half the tank it happened only once.with 10l of petrol how can it show half a tank
i think the needle has become over sensitive.Is their anything that can be done because its becoming very irritating now.
Have searched and couldn't get a answer
__________________
MANIK NANDA
manikjeet is offline   Reply With Quote
Old 12th March 2007, 18:05   #2 (permalink)
low_bass_makker's Avatar
the fuel gauge works on the variable resistance in the fuel tank....the higher the fuel level the resistance is less so the gauge show full level...the variable resistance in the fuel tank is faulty....that is why it is showing incorrect readings......
__________________
156.6 db, naa....time is coming to cross it......
low_bass_makker is online now   Reply With Quote
Old 12th March 2007, 18:10   #3 (permalink)
planet_rocker's Avatar
ur fuel "tanky's" meter/leveler(gauge) is not working properly. we had the same problem in my dad's car.
solution: open the "tanky" and change / repair the meter/leveler(gauge) and any mech can do it. the petrol needs to drained out though. but u can always carry those big plastic jars and pour the petrol back when the leveler is repaired / changed.
__________________
Planet, Sonja, ETC - "Elements of Life"
RWD Rocks ... :)
planet_rocker is online now   Reply With Quote
Old 12th March 2007, 18:41   #4 (permalink)
harsh87's Avatar
you can also try getting the tanky cleaned while you get the meter repaired.
harsh87 is offline   Reply With Quote
Old 14th March 2007, 14:53   #5 (permalink)
Team-BHP Moderator
Jaggu's Avatar
check the wiring for fuel guage also, especially the grounding
__________________
The strength to change what I can, the inability to accept what I can't, and the incapacity to tell the difference. -Calvin
Old 14th March 2007, 15:02   #6 (permalink)
manikjeet's Avatar
Got it checked tanky cleaned the mechanic said it was the first time he had open a tanky of a alto
got the fuel pump checked now only dash instrument panel is left now i think the problem is with the panel
__________________
MANIK NANDA
Old 14th March 2007, 15:06   #7 (permalink)
Team-BHP Moderator
theMAG's Avatar
The sensor is faulty or the worm is weak.
__________________
If you lose your temper, you’ve lost the argument
Old 14th March 2007, 15:09   #8 (permalink)
manikjeet's Avatar
How much is the sensor for and what is a worm
__________________
MANIK NANDA
Old 14th March 2007, 15:37   #9 (permalink)
Team-BHP Moderator
theMAG's Avatar
Dont know abt sensor cost. A worm is a high-tensile spring that controls the movement of the needle in an analog meter. If the worm is weak, the needle roams - as might have been observed in old cars/vans/buses.
__________________
Thread Tools
Fuel Gauge Problem - Contessa & Esteem falcon Technical Stuff 10 10th August 2008 20:18
IKON 1.6 : Oscillating RPM needle Fiero Technical Stuff 11 18th April 2007 21:13
Drivers view of Road - How to guage pugram Shifting gears 3 19th September 2006 16:49
Auto Guage RPM with Gear Shift for Swift..!!! shuhaib Modifications & Accessories 2 1st June 2006 14:33
Electronic Fuel Pressure guage Ford Rocam Shifting gears 6 14th January 2006 16:36
Powered by vBulletin
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445
