Old 29th August 2012, 20:55   #16
Default Re: MIL Light glows while running on CNG in Honda city
Originally Posted by ijeff View Post
I have been using CNG kit on my Lancer for last 1 year and absolutely no issues at all. I can't speak the technical language but the Engine or MIL light is ON whenever it runs on CNG. And goes off when I shift to petrol.
The fitter said that this is normal. I did an MUT setting / engine diagnostics recently at Aquest Auto - Mitsu *** and everything is normal ..all parameters I mean.
So i am not worried about that light being ON during CNG run.
It possibly only means a deviation from pre-set parameters which is designed only for petrol use and it recognises CNG as 'foreign'..
Does that help ? I could be wrong
Hey - I finally went in for the conversion - the results are quite nice - in the City, the City is giving 20-22 km/kg, and on a recent Pune trip without AC, it gave 33 km/kg (I keep telling people I am getting 40 kmpl city and 64 kmpl highway in "Petrol Cost Equivalent" I even bragged to a Honda Activa owner that my Honda is more efficient than his! )
Only one niggle remains - after I start the car, it tends to stall while switching from petrol to CNG - I have to revv it quite hard to keep it running, else the engine dies - the delay between petrol stopping, and CNG releasing, is quite high, it seems. The reverse switch (if i manually go off CNG) is slightly smoother, generally does not stall the car. Have you experienced any such niggles with your car?
pranav4x4 is offline   Reply With Quote
Maruti Baleno engine light glows? hulkonline Technical Stuff 24 14th January 2013 19:38
Oil check light glows in 118NE, AFTER removing key adhiraj Technical Stuff 4 31st August 2010 21:39
Matiz - Check light goes on while running sunil8089 Technical Stuff 25 20th November 2009 13:32
Matiz : Jerks and MIL lamp ON Tawwa Technical Stuff 6 9th July 2008 12:39
Maruti Zen MIL is on Khimera Technical Stuff 16 21st October 2007 07:22
