| Technical Stuff Want to know your Vtec, ABS or intercooling better? |
| | Thread Tools |
| | #1 (permalink) |
| Newbie Join Date: Feb 2007 Location: Ankleshwar
| We have converted one honda city to run on CNG. the kit fitted is italian Landi renzo. The car is running absolutely fine on CNG as well as petrol. Mileage is good pickup and acceleration is also good. But the problem is when it run on CNG it shows MIL light in dash. When we checked the ECU with scantool it shows error code which suggest mixture is too lean. When we checked the voltages generated by both the o2 sensors it gives 0.975 volt while running on CNG. Now we want that the MIL light should not glow when running on CNG. What can we do. We have tried to insert resistor of different values on the output of o2 sensor to reduce the output voltage to ecu but it's not working. Is there any way to solve this. Can we make some arrangement such that no change is made when it runs on petrol but when it runs on CNG the reading given to ECU is altered so that it doesn't glow the MIL light. While driving with scantool connected it was observed that the short term fuel trim remains high while running on CNG and long term fuel trim is low compared to the same when run on petrol. So how to reduce the short term fuel trim which is making th MIL ON on CNG. Kindly suggest some solution to this problem if anybody has come across Thanking you. regards, Rajeev Patel p_raj14@hotmail.com Ankleshwar, Gujarat. |
| | #2 (permalink) |
| BHPian Join Date: Mar 2006 Location: Phoenix, US
| What I know is that running too lean means you are running too hot also. And running too hot is not good for engine. I think the car needs a retune to burn CNG. There are guys here who can provide you good direction. Last edited by Pankaj401 : 13th March 2007 at 16:12. |
| | #3 (permalink) |
| BHPian Join Date: Feb 2006 Location: New Delhi
| If its a new kit, You need a Lamda controller with Stepper Motor, Basically it will Pump Required Gas only and is ECU Based Controller which is set using MUT or OBD..! Ocassionally, I did get Check Engine Error on my CNG XETA, Which was Lamda Error, Got the System Retuned, Lacking the Lamda as Shrimanker Bedini keep on delaying Lamda Control..!
__________________ " When was the last time, You did something for the first time " |
| | #4 (permalink) |
| Distinguished - BHPian ![]() | One should not fiddle around with O2 sensor & ECU, the kit you bought should have support to tackle such kind of problems please get in touch with the installer, putting resistor of different values without knowing its outcome is pure experimenting any wrong connection can result in permanent failure of O2 sensor or your ECU.
__________________ Cheap and reliable wont be fast, cheap and fast wont be reliable, reliable and fast wont be cheap. |
| | #5 (permalink) |
| Team-BHP Moderator ![]() | Watch the engine temps. As long as its within the safe zone, you are OK. I have seen many OHCs with gas kit showing check engine light.
__________________ The difference between the men and the boys....................is the speed of their toys. |
| | #6 (permalink) | |||
| BHPian Join Date: Mar 2005 Location: Minneapolis
| I have not worked or had experience with CNG systems but atleast I know that playing with signal to ECU is not the right way to supress MIL. Quote:
Either reset the ECU and let the ECU add the STFT to the LTFT on its own and see if STFT becomes stable. BUT this is obviously not working as it has already gone above acceptable range of LTFT. By the way can you check your IPW how long is it on for ? or if your OBD2 software shows IDC , how much IDC % your injectors are on for ? are they maxed out ? If it was a petrol engine ..u could have increased fuel by increasing injector size, fuel pressure with bigger fuel pump, used a piggback AF controller etc to alter fuel delivery with help of a wideband etc ...similar may be applicable in case of CNG.. ? (maybe similar) Basically try increasing your fuel/CNG supply.. (Try getting hold of a wideband AFR meter) Is there a way your CNG system understands/compatible/takes feedback from 02 sensor/obd2 port/ECU ? if NOT then Im confused how the system is designed to work on a existing MPFI engine.. ? | |||
| | #8 (permalink) |
| BHPian | your MIL light being on is a clear indication of an adjustment to be made for optimal performance make sure you fix the issue instead of using a workaround only coz you may spend less on cng but if you blow a cylinder or something then theres no point having CNG.
__________________ "Aerodynamics is for those who cannot manufacture good engines" - Enzo Ferrari |
| | #9 (permalink) |
| BHPian Join Date: Sep 2005 Location: bangalore
| I have'nt worked on CNG systems, but this seems like a normal closed-loop behaviour of the sensitive Euro 3 (and some Euro 2) spec ECUs. If ECU detects the afrs do not behave as per ECU predictions and actions, it usually throws a MIL. Nothing to worry about, unless something else is kaput. You might have to get a CNG kit capable of maintaing at least a stoich mixture, if not closed-loop controller, as wolfenstein said. Most of the LPG/CNG guys tend to go on the leaner side for efficiency, which should'nt be a problem with the typical non-stressed street engine. Last edited by rdkarthik : 14th March 2007 at 10:38. |
| | #10 (permalink) |
| Super-Admin | I guess the NHC does not come with a temp. gauge?
__________________ GTO Self-imposed limits are the only type that exist. Break them....then, make it a habit. Exceed.
| Thread Tools | |
Similar Threads | ||||
| Honda Accord on CNG!!!!!! | coolmob | Technical Stuff | 32 | 16th December 2007 13:04 |
| Maruti Zen MIL is on | Khimera | Technical Stuff | 16 | 21st October 2007 07:22 |
| Any feedback of Zeta running on LPG/CNG! | nikkibike | The Indian Car Scene!! | 2 | 5th July 2006 21:42 |
| Pedrossa shines but Rossi glows at Donington Park! | turbo_v12 | Motor-Sports!! | 7 | 5th July 2006 11:11 |
| custom Head light of honda | shriadi | Shifting gears | 0 | 19th May 2006 00:14 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430
