Old 22nd June 2010, 20:55   #16
kri$hna's Avatar
Thanked: 29 Times
14.6v is a bit high. Normal charging voltage is 13.8 to 14.4v. Higher voltages cause the electrolyte to evaporate and higher still will cause the +ve plates to buckle/deform. If high voltages persist over a period of time battery damaged is assured.
You need to want to get the regulator/rectifier plus the battery checked. Also check the car circuits for any parasitic drain when the ignition is off.
I went to United Motors (Bosch Car Service), where the battery tester was used to test the battery, the result was "Starting Capacity 60%", "Replace Battery"!!
So bought a BOSCH Silver battery for my baleno there itself. They have checked the alternator voltage and with engine idling, headlights & AC on, the voltage was around 13.6, which only engine idling it was around 14.3v. Mr. Dhiren Mehta says, The alternator of Baleno is made my Denso, which has very less chances of failure. Even the Bosch Tester tool says "Voltage Regulator Good" !! So I guess it was a bad battery from Exide.
kri$hna is offline   Reply With Quote
Key remote fob - Battery drain raveesh_k Technical Stuff 17 22nd April 2018 12:02
Battery Drain Issue with Toyota Etios: Boot Light Stays On mroptimist Technical Stuff 13 23rd September 2013 22:05
Does leaving phone charger plugged into 12V socket overnight drain battery? androdev Technical Stuff 27 18th December 2012 22:04
can a loose wire drain the battery? raj_5004 Technical Stuff 13 8th January 2009 09:12
