Old 14th March 2007, 19:48   #16
manikjeet's Avatar
Thanked: 109 Times
Originally Posted by ajitkommini View Post
If the battery was drained because of an alternator malfunction, how was he able to start the car again? Not able to understand this.
i am to shocked and very happy with my luck that the car started again or otherwise i would have been stranded.
Checked the battery terminals they are tight
Is the ecu malfuntioning
manikjeet is offline   Reply With Quote
Old 14th March 2007, 19:50   #17
manikjeet's Avatar
Thanked: 109 Times
this also happens when i read line my car that is when i go full out in 1 gear only
Old 14th March 2007, 21:04   #18
gbpscars's Avatar
ajit, yes, surprisingly no one asked this in this thread.
and also why would the engine die when it was running along with the electricals, even if the alternator conked off!!!
gbpscars is offline   Reply With Quote
Old 15th March 2007, 12:04   #19
ajitkommini's Avatar
Thanked: 109 Times
Could this be because of a short circuit or something? I remember the same thing happening to me once in a junk 800 i used to use in Delhi. I did later get the alternator fixed, but that was for a different issue (battery not charging). Never found out why the "blackout" happened.
ajitkommini is offline   Reply With Quote
Old 15th March 2007, 12:21   #20
headers's Avatar
Thanked: 454 Times
this could also happen due to a faulty earth wire..the terminal may not be secured correctly and tight!!
Old 15th March 2007, 13:47   #21
rishibravo's Avatar
Question
earth in DC ? I thought phases were only in AC supply...
rishibravo is offline   Reply With Quote
Old 15th March 2007, 14:11   #22
Thanked: 109 Times
'Earth' denotes a return path for electrical current and is a part of DC and AC circuits. It has nothing to do with phase (which, as you pointed out is only in AC).
Old 16th March 2007, 20:48   #23
gbpscars's Avatar
that is the ECU redline auto-cut out working.
which one of your cars did you try this on?
so some of us can be warned not to buy it as 2nd hand from you
Everything you wanted to know about BMW v12 The International Automotive Scene 13 7th June 2012 09:46
She just went in ... (Restoration of 2001 CBZ) vikrut Motorbikes 9 9th March 2009 12:53
CEL/MFL Came on and Went off KSM-Vtec Technical Stuff 9 1st August 2008 11:58
Baleno Went off.... kiranpashtakar Technical Stuff 19 8th June 2007 13:10
