Old 14th March 2007, 11:54   #1
manikjeet's Avatar
Thanked: 110 Times
Default Everything just went off
Yesterday i was driving in heavy rain i mean really heavy rain the roads were flooded. while i was driving suddenly the car engine shut down and the head lights when off and the stereo also shut down everything was got to 1 min or so as the car didn't have battery in it
after that i tooks the keys out and then put them in again the car started again without any hassles the stereo was resetted but the car worked fine
my question is that what had gone wrong and is it serious should i take her to a mechanic
manikjeet is offline   Reply With Quote
Old 14th March 2007, 11:57   #2
esteem_lover's Avatar
Thanked: 451 Times
Check if the battery terminals are tight. can happen if they lose contact with the battery.
Old 14th March 2007, 11:58   #3
nitroxx's Avatar
Thanked: 26 Times
battery terminals is the root cause usually.
nitroxx is offline   Reply With Quote
Old 14th March 2007, 12:41   #4
theMAG's Avatar
Thanked: 1,572 Times
In addition to the above suggestions, check the alternator that might have acted up due to the water.
Old 14th March 2007, 14:08   #5
Thanked: 10,994 Times
Was it powered by MS Windows?
Old 14th March 2007, 14:11   #6
goldie_malhotra's Avatar
Do you have an advanced security system installed ?
These can goof up at times
goldie_malhotra is offline   Reply With Quote
Old 14th March 2007, 14:32   #7
Thanked: 17 Times
Yes, Ajmat. Just an example of how cars would behave when powered by Microsoft.
Which car was it?
It is better you get your car checked up by some good mechanic. This should definitely not happen in a more serious circumstance like in middle of an overtaking move or so...
According to your explanation, it seems like your electrical system needs to be rechecked.
Old 14th March 2007, 14:47   #8
manikjeet's Avatar
Thanked: 110 Times
ya i have a advance security system installed
nd no my car is not widows powered
Old 14th March 2007, 14:50   #9
manikjeet's Avatar
Thanked: 110 Times
Which car was it?
i am sending her for a good service tomorrow
Old 14th March 2007, 14:55   #10
Dippy's Avatar
Thanked: 192 Times
It is definately the alternator. Happened to my Zen once. Stereo conked followed my headlights et al. Apparently the faulty alternator wasnt charging the battery
Dippy is offline   Reply With Quote
Old 14th March 2007, 15:00   #11
iraghava's Avatar
Thanked: 156 Times
Ahhh... and when is she due for a bad service?
Old 14th March 2007, 15:12   #12
manikjeet's Avatar
Thanked: 110 Times
do that everyday whenever i have time i go under the hood
what i meant was that she would be going for a service after a long long time after around 10000 km
i know its long but didn't get time and the car wasn't free
Old 14th March 2007, 15:38   #13
Thanked: 451 Times
What is the Security system that you have installed ?
Old 14th March 2007, 16:01   #14
nitroxx's Avatar
Thanked: 26 Times
if the battery is holding up still n theres no issues then it should be the terminals and alternator could cause problems too so go ahead get it checked or better yet do a full check
Old 14th March 2007, 16:34   #15
ajitkommini's Avatar
Thanked: 109 Times
If the battery was drained because of an alternator malfunction, how was he able to start the car again? Not able to understand this.
ajitkommini is offline   Reply With Quote
Everything you wanted to know about BMW v12 The International Automotive Scene 13 7th June 2012 09:46
She just went in ... (Restoration of 2001 CBZ) vikrut Motorbikes 9 9th March 2009 12:53
CEL/MFL Came on and Went off KSM-Vtec Technical Stuff 9 1st August 2008 11:58
Baleno Went off.... kiranpashtakar Technical Stuff 19 8th June 2007 13:10
